XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Computer Cases
Reply
Old 09-24-2008, 02:10 PM   #1
Dangals
Dangals's Avatar
Cable Sleeving Guide
Well after a few requests on OCAU I put together a rough guide to cable sleeving - now before you get too critical I did say rough .
PLEASE NOTE that you do this at your own risk - I take no responsibility for burnt out psu's, mobos etc
Now before we get started there is one thing I MUST point out and that is that most power type cables tend to inter-twine - in other words the cable that is in the left most hole at one end may not be in the same position at the other end. I HIGHLY recommend that you take your time and do each cable one at a time (if you are grouping cables make sure you label them accordingly so you do not forget their order) because if you get the order incorrect when you go to power up the next time there is a very good chance you will see the magical black cloud!!
Recently the guys over at MurderMod have release two sleeving kits that I believe are the absolute Cats Pajamas of sleeving. Nothing comes close to the quality of the MDPC-X sleeving and they have made it so easy for the end user to get all the various sizes you need for you to sleeve and entire system. There are two different packs that contain various lengths of sleeve with the Psychopack being the better of the two.
MurderMod Sleeving Kits
However I should mention that the sleeving used in this guide is all 1/8" Techflex PET like this (due to having done this all a few months before the MurderMod sleeving was available)
http://www.performance-pcs.com/catal...roducts_id=122
or for the Aussies
http://www.gammods.com.au/store/inde...ath=7_20_18_28
The majority of the heatshrink was 1/8" as well.
http://www.performance-pcs.com/catal...roducts_id=206
again for the Aussies
http://www.gammods.com.au/store/inde...ath=7_20_21_51
First thing first and that is you need to decide what exactly do you want to sleeve. Are you going to just do the 24 pin cable? Or are you going to do the pcie, fan, molex and the whole shebang. Next step is to work out if you are going to be doing them individually or in groups. This then helps you work out what size sleeving is going to suit your needs. For individual power cable sleeving and fan sleeving I find that 1/8" sleeving is perfect. But once you start moving into groups it all comes down to how many per sleeve you are trying to do.
Now there are many different types of sleeving out there as well as kits that give you different lengths/sizes with their appropriate sized heatshrinks as well. These are good but you may end up only using one size and the rest will just sit there. The other option is to buy it in the size that you want and the desired quantity. For sleeving in Aus its hard to go past gammods as they have a large range of sleeving in all sorts of sizes and colours as well as the heatshrink to go with it. Or the more expensive (but oh so worth it) option has arrived with the launch of the MurderMod site which now sells the mdpx sleeving (of Million Dollar PC fame). This sleeving is slightly thicker and is less likely to show the colour of the cable it is hiding. Again as mentioned previously there is no better sleeving available on the market at this time (My Opinion).
Now that you have selected your sleeving size/colour options you are going to need some tools to remove the pins from the various plugs.
For all non molex type plugs you can use tools like the ACRyan one below but I found that they have a tendency to break fairly easily. Actually the easiest thing to use is some standard staples....yes staples
I find that two together once bent into shape are a perfect fit for removing those pesky plugs and if you break them...simply get a couple more:thumbup:
What you do is simply place either the pin remover or staples in the end of the plug like so
and then push them in as far as they go (this is where you are likely to break the tools) and then pull on the cable. You shouldn't need too much force but some are a little harder to remove than others.
example of two removers one broken
Just pull on the appropriate cable
To demonstrate your goal at this step Moogle drew up the below diagram to better help explain the process (image courtesy of Moogle @ Hexus.net)
At this point you can measure up and cut the sleeving to cover the length of the cable - NOTE - that you will need to allow slightly more sleeving than what appears to be needed as when you slide the sleeving over the cable it looses some length as it expands to fit the sleeving.
The next step from this point is you take some heatshrink cut to an appropriate length so that when you heat it up it will cover both the end of the sleeving but a section of cable as well. You take this and slide it onto the cable followed by the sleeving.
Once you have moved the sleeving almost to one end guide the heatshrink over the end of the sleeving so that there are no stray wires sticking out.
Now this part will require some nimble fingers and patience if you are using 1/8" heatshrink with 1/8" sleeving as it takes a little bit to get the heatshrink on. But once it is on there it is less likely to come off than if you had used a larger size that doesnt shrink enough to get a firm grip.
Once you have done this end you can either use a heatgun or the missus hair dryer to heat the shrink up so that it keeps the sleeving in place. Do the same at the other end and once that cable is done simply click it back into place within the plug like so.
Now trust me when I say that at first you will probably find it a little difficult and you will probably get frustrated. But if you persist you can get some excellent results.
Here are some quick examples of some I have done recently.....
__________________
My Build Log:
Dangals is offline   Reply With Quote
Old 09-24-2008, 02:11 PM   #2
Dangals
Dangals's Avatar
Now what about those Sata Cables that have plugs at various intervals along the cable??? No Problem
An example of the plug most power supplies use
Now what you do is use something thin but sturdy - standard tweezers do the trick nicely - you slide the edge of the tweezer under the rim of the plug and simply pop the top off like so...
Once you have done that the cables simply come out and you end up with this
Now all you need to do is work out how far apart the plugs need to be in order to get the cleanest lengths of cable and arrange the plugs appropriately. Then while the cables are still detached from the plug simply apply your sleeving as demonstrated in the post above and try and get them as close to the plug as possible to avoid and "colour" of the cable showing.....
To get the cable back into plug requires a little force as when you put it back in it actually cuts the exterior of the cable (which is great as it saves you from having to buy wire strippers!!!)
Now here is one I did earlier
Ok another thing that is relatively simple to sleeve are fans. Now there are two types of connectors for fans. You have the three pin and the molex. Three pins are more common on your after market fans as opposed to stock fans that tend to come with cases which are usually molex.
I will start with the three pin:
What you will need is something thin that can push in the pin of the little connector at the end of each cable. Since breaking the pin remover I have been using it but you could also use a paperclip, tweezers, really anything which as a thin but fairly sturdy end.
When you press in gently using you selected tool - simply pull back on the apporpriate cable and it should come straight out.
Now excuse the hands
To give you an idea of what it is that you are trying to achieve Moogle drew up the following diagram which illustrates the above step (Picture courtesy of Moogle @ Hexus.net)
Once you have removed all three cables you can apply your chosen sleeving + heatshrink combo. Now it is possible to use 1/8 sleeving on the cables for fans - but it is next to impossible to use 1/8" heatshrink. You need to use the next size up for your sanity (trust me I did 2-3 fans with 1/8" and I nearly lost my mind )
Before you reinsert the cables into the plug you will need to raise the tab you pushed in when you removed it. Easiest thing to use here is a good old stanley knife, just gently easy it in and bend it back out again. But remember to be gentle as they can break off if too much force is applied.
again here are some that I prepared earlier
EDIT:
SATA Data Cables
Ok well I finally got my hands on the sleeving I wanted to use for my Sata cables (big to Charles_h for getting these for me) so as I was doing them I took a few pics to help explain what to do. The sleeving that I am using is 3/8" Techflex.
Ok so first thing is first determine how long you want your heatshrink to be and cut 2 pieces the same length. Feed both of them over one end of the cable like this
Now you may just make out that the corners of the plug have been shave to stop them from catching on the sleeving as I pass it over. To do this I simply used a razor blade and shaved a little bit of the point off.
Then the next step is to guide your sleeving over the end. Now this bit is a little tricky I found that the best way was to place the sleeving at the end of the connector and then bunch it up which stretches it enough to go over the plug and from there you can guide it down the rest of the length of cable.
Then guide your shrink down to the desired point on the connector like this
Then using your favourite heating device (hairdryer ) heat the shrink till it grips. Now the shrink I am using here is 3:1 gluelined which gives it an excellent grip and I dont think it will be coming off anytime soon.
__________________
My Build Log:
Old 09-24-2008, 02:23 PM   #3
LogAn'sRun
LogAn'sRun's Avatar
Nice Guide dangals, this will be great for beginners and folks that ask about sleeving jobs and stuff.
Some additions might be to link some of the various types of sleeving in your first post and perhaps heatshrink as well. Another suggestion would be to mention some standard sizing depending upon the job that you want to do. Oh, and a very big warning "try at your own risk, not responsible for burnt psu's mobos etc etc".
With those added in, I could see sticky in your future!!!!!
__________________
They say the definition of madness is doing the same thing and expecting a different result.
Howlin' Pelle Almqvist
Project Log Completed: v1000 - very first mod
LogAn'sRun is offline   Reply With Quote
Old 09-24-2008, 02:37 PM   #4
BlueAqua
I am Xtreme
BlueAqua's Avatar
Nice sleeving guide!! I've sleeved a bunch of cables but picked up some new tricks from this. Thanks Dangals
Do you use a hot knife to cut the sleeving? I don't have one but was wondering if it was worth it.
BlueAqua is offline   Reply With Quote
Old 09-24-2008, 02:38 PM   #5
Dangals
Dangals's Avatar
Thanks for the compliment.
Changes made to first post.
Thanks BA
I have no experience with a hot knife - I just used a regular razor blade (changed blades after a while so it was still sharp.)
__________________
My Build Log:
Old 09-24-2008, 03:18 PM   #6
BreeSpree
BreeSpree's Avatar
Very nice guide. Should definitely get a sticky. Maybe finish the guide with a miniguide on various ways to shrink the heatshrink, and how to do it. Examples may include an open flame, heatgun, I've heard people using a hairdryer.
__________________
Current Computer| Modified SwordM | EVGA 680i A1 | 3x EVGA 8800GTX | Q6600 @ stock | 4 gigs Corsair Dominators 1066 | WD Caviar 1TB 7200rpm | Liquid by D-Tek and Ek
Friends don't let ANYONE use Thermaltake
Conspiracy Theorists FTW
Join Us http://www.xtremesystems.org/forums/...php?groupid=25
My 680i A1 is not responding... WTF
BreeSpree is offline   Reply With Quote
Old 09-24-2008, 03:28 PM   #7
BoogerB
Nice. I'm having hell with my TX750 on the 24pin. stapels, pins, needles, etc, no dice.
BoogerB is offline   Reply With Quote
Old 09-24-2008, 03:29 PM   #8
charles_h
I am Xtreme
charles_h's Avatar
Fantastic Guide Dangals!
Most of the Weller Soldering Gun Kits come with a cutting tip.
I find them more of a PITA tho... you tend to get honkin' long goo-threads when using them to cut. I find the cutting tip useful after I've cut sleeve with scissors - you can use the flat side of the tip to gently sear the end of the sleeve which is usually enough to prevent fraying.
charles_h is offline   Reply With Quote
Old 09-24-2008, 10:57 PM   #9
.Logic
Nice guide Dangals
Cheers
__________________
.Logic is offline   Reply With Quote
Old 09-25-2008, 12:00 AM   #10
twwen2
twwen2's Avatar
Hey nice work Dangals, i saw this back home at OCAU too.
I'm sure it'll be of use to many people
__________________
Originally Posted by b@llz0r View Post
i didnt have a girlfriend before i got into watercooling....
... now I have a cat.... her name is mittens
HW: E8600@4GHz||DFI JR-P45 T2RS||ATi HD4870||4GB Corsair 8500C5DF||640GB WD6400AAKS||Vista Home Premium x64
WC: EK Supreme||EK-NB S-Max||EK-FC 4870||PA120.3||DDC3.2+Petra's top||EK 150 res
Sense and Sensibility [My build log]: http://www.xtremesystems.org/forums/...d.php?t=201235
twwen2 is offline   Reply With Quote
Old 09-25-2008, 12:39 AM   #11
Dangals
Dangals's Avatar
Thanks Charles! you are the one that inspired me to give this a go with the build you did for FC so it is you that should get the
Originally Posted by .Logic View Post
Nice guide Dangals
Cheers
Thanks mate
Yeah figured that it should be here as well. There will be a few additions to this one though....more to come.
Is now stickied!!! YAY - my very first sticky sorry couldn't help myself.
I will add a section on heatshrink to the guide - I indeed use a simple hairdryer....my partner kept wondering where hers kept dissappearing too
PM me if you wish.
__________________
My Build Log:
Old 09-25-2008, 01:24 AM   #12
reberto
reberto's Avatar
Send a message via AIM to reberto Send a message via Skype™ to reberto
Nice job I'm not a fan of sleeving each individual wire on the 6/8 pin connectors myself but it still looks great!
reberto is offline   Reply With Quote
Old 09-25-2008, 02:48 AM   #13
bluc
Thanks gives me good idea how these pins work got a fair bit of custom sleeving coming up soon on my custom case
__________________
Xclio A380 black
acer 24 inch P241WB
Q6600 GO @ 2.88ghz on stock cooler
Gigabyte X38_DQ6
2GB kingston ram
250 WD HDD
my first custom case build
bluc is offline   Reply With Quote
Old 09-25-2008, 08:48 AM   #14
elite.ire
Banned
Send a message via ICQ to elite.ire Send a message via AIM to elite.ire Send a message via MSN to elite.ire Send a message via Yahoo to elite.ire
awesome idea with the staples m8, Im going to sleve all my cables when i get some funds and time thanks a million for the guide !
elite.ire is offline   Reply With Quote
Old 09-25-2008, 08:56 AM   #15
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
@ dangals
I noticed you use a very small amount of heatshrink at the end of you sleeving, do you find (as I have in the past) that the sleeve easily pulls out of the heatshrink??? or is it a different situation when sleeving single wires compared to 2-4 at a time?
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 09-25-2008, 10:35 AM   #16
dualbrain
MDPC
dualbrain's Avatar
With 3:1 (or better) Shrink of the right size, this is not a problem. Get a diameter that just goes over your "victim". About adhesive-shrink there are different opinions by everyone. I prefer non-adhesive shrink. With 2:1 shrinkrate shrink you will rarely get a tight grip on the sleeve. Avoid 2:1 is true for all I guess
Dangals: Nice job you are doing here for the english speaking community
My friend Charles: It is nice to celebrate cables, make them a design element and not to hide them anymore ... after how many years of ugly colored cables? 30 ... 40 ... ? Thank you for having brought individually sleeved wires to the screen with the murderBox back in December07 (?) when you did the 24pin-ATX.
Here is my addition to the trend that already became a massive one in Germany:
__________________
dualbrain is offline   Reply With Quote
Old 09-25-2008, 10:40 AM   #17
Zw_Roodbaard
Zw_Roodbaard's Avatar
Nice guide for the newones Dangals It's very handy when you never sleeved something in your modding career :P
Maybe I try to sleeve my sata powercables but I think that isn't so easy as it looks.
__________________
"Amicus Plato — amicus Aristoteles — magis amica veritas"
Zw_Roodbaard is offline   Reply With Quote
Old 09-25-2008, 11:18 AM   #18
SpazBoy357
Nice job, Dangals! Grats on the sticky!
The one line note on my "Project Plan" that used to read "Sleeve PSU cables - Red" has been moved to its' own page and is now many, many lines thanks to you.
SpazBoy357 is offline   Reply With Quote
Old 09-25-2008, 11:18 AM   #19
Scubar
I am Xtreme
Scubar's Avatar
Yea i would like to sleeve some Sata cables but i cant find the right Sleeving and Heatshrink to use.
__________________
Gaming Rig
Case: Silverstone TJ-07 LCD: 32" Samsung A656 CPU: i7 920 D0 w/Swiftech Apogee GTZ Mobo: Foxconn Bloodrage RAM: 6GB OCZ Blade
GFX:
HIS 4870X2
w/EK Nickel/Acetal FC Block Power Supply: Corsair HX 1000W Sound Card: Auzentech X-Fi Prelude HDD: 60GB OCZ Vertex HDD: 2x1TB Samsung F1
Media Rig
Case: Zalman HD160XT+ LCD: 40" Toshiba XF355D CPU: Q9450 w/EK Supreme LT Mobo: Asus Rampage Formula RAM: 8GB Geil Black Dragon
GFX:
Gainward 8600GT SilentFX
Power Supply: Corsair HX 620W Sound Card: Auzentech X-Plosion HDD: 500GB WD Caviar Black
File Server
Case: Custom Built Torture Rack CPU: E8200 w/Ultra-120 Exterme Mobo: Asus P5QL-EM Ram: 4GB OCZ Platinum
GFX: Onboard Power Supply: Corsair HX 620W HDD: 250GB Seagate HDD: 2x1TB WD Caviar HDD: 2x1TB WD Caviar
Scubar is offline   Reply With Quote
Old 09-25-2008, 11:41 AM   #20
JaYp146
JaYp146's Avatar
I'm going to be linking a friend here ... he almost b0rked his PSU after narrowly avoiding a big sleeving error on his 24pin ATX connector. Looks like the OP knows what he's doing ... xD
JaYp146 is offline   Reply With Quote
Old 09-25-2008, 03:46 PM   #21
BreeSpree
BreeSpree's Avatar
Yeah, showing us how to sleeve SATA cables would be nice. I myself can't figure out how to fit the dang heatshrink and sleeving over the big connectors. I've seen it done though, just don't know hwo they do it. The sleeving possibilities are endless. Other sleeving curiosities I have include how to sleeve liquid cooling tubing, as I have also seen that done before, but again, have no idea.
__________________
Old 09-25-2008, 05:07 PM   #22
Dangals
Dangals's Avatar
thanks for the kind words guys
Originally Posted by SNiiPE_DoGG View Post
@ dangals
@ sniipe_dogg - as mentioned by dualbrain it is all about getting the shrink in the right size - now for the ones that I did nearly everything with done with 1/8" sleeving and 1/8" heatshrink - so therefore it is a really snug fit when you heat it up. Also as DB mentioned you can get glue-lined heatshrink as well which helps minimise the chance of a "blow out".
@ Dualbrain - wow another legend popping in - I love the work you do with MDPC - hopefully one day I will have a machine worthy of joining
Just out of curiosity what is that thing that you showed??
It is actually not that bad - just remember to take your time and you will be fine
thanks guys - makes this all worth while
In regards to the sleeving of sata (data) cables that will be covered in an upcomming section to this guide - just have to finish off some other things first and then it will be added
In regards to the sleeved tubing - the only person I have seen pull that one off is Charles_h but that is something I will probably never do as working out where a leak is coming from would be nearly impossible due to the tubing being completely covered.....plus I tend to use black tygon anyway - no need to cover that up.
__________________
My Build Log:
Old 09-25-2008, 05:26 PM   #23
zlojack
zlojack's Avatar
Awesome guide and just in time for me to do this for my new build! I was feeling somewhat daunted by the process, but this breaks it down nicely!
Thanks!
__________________
RIG 1 (in progress):
Core i7 920 @ 3GHz 1.17v (WIP) / EVGA X58 Classified 3X SLI / Crucial D9JNL 3x2GB @ 1430 7-7-7-20 1T 1.65v
Corsair HX1000 / EVGA GTX 295 SLI / X-FI Titanium FATAL1TY Pro / Samsung SyncMaster 245b 24" / MM H2GO
2x X25-M 80GB (RAID0) + Caviar 500 GB / Windows 7 Ultimate x64 RC1 Build 7100
RIG 2:
E4500 @ 3.0 / Asus P5Q / 4x1 GB DDR2-667
CoolerMaster Extreme Power / BFG 9800 GT OC / LG 22"
Antec Ninehundred / Onboard Sound / TRUE / Vista 32
zlojack is offline   Reply With Quote
Old 09-25-2008, 06:41 PM   #24
Navig
Navig's Avatar
Great Guide.
One thing that I will do to prevent "blow-ups" (ie the heatshrink pulling off the end of the sleeving), especially if you cannot get perfect tight fits with your heatshrink:
At the end of the sleeving, I'll add a little collar of electrical tape--only about 0.5cm in width, and only 2 times around the sleeving. The heatshrink goes over this collar--when shrunk down it will grab it, and not slip off.
This really isn't necessary for cables not under any particular movement stress--like the individual wires depicted above.
But if you are doing multiple wires within the sleeving, like the classical 4-wire molex cables, that are often jostled or moved, generally a collar of some sort is necessary.
Navig is offline   Reply With Quote
Old 09-25-2008, 07:59 PM   #25
dualbrain
MDPC
dualbrain's Avatar
Hey Dangals No problem to get on MDPC (soon I have time for it again). I will have no choice if you have a perfect system up to the smallest screw, superb color balance, nice shapes, dynamic "flows" of shapes ... and of course - no cable uglyness. The photos are an issue too. I love beautiful computers and so I will not hesitate to take a perfect one online. Thank you for your very nice words
The sleeved thing on the photo:
It is just something that I gave to some friends as a surprise: http://www.youtube.com/watch?v=l8lnN...eature=related
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
