Hi guys, so I mentioned in a few threads that I would be making a new build in the coming months. Currently I am at RPI so all the parts are back at my house in their shipped boxes. I have a parts list for you guys as it stands, I will probably be buying a few more parts as it goes along. You can expect a finished product by the middle January '09.
Case Parts:
1 x Sunbeam Multi Fan Power Port (MFPP)
1 x Lian-Li Armorsuit PC-P80 / Black / Full Tower Case (PC-P80B)
1 x Dual 12" Cold Cathode Kit - Ultra Bright UV
1 x Yate Loon D12SL-12 Blue UV Reactive 120mm Fan
1 x 120mm Mountain Mods Hard drive rack (Sky White)
1 x Sunbeam 5.25 Rheobus - Fan Controller Black
1 x Lian Li Power Supply Bracket Extender for Chassis
Liquid Cooling Parts (Have & Purchased):
1 x D-Tek Fuzion v1 Cpu Waterblock No Nozzels
1 x Swiftech MCW-30 Chipset Waterblock
2 x EK Radeon HD4870 VGA Liquid Cooling Block - Nickel Plated
2 x Swiftech MCP-355 18w DC pump
1 x Petras DDC-T01s Acetal Pump Top
1 x XSPC Laing DDC-1T/1TPlus MCP-350/355 Acrylic Replacement Top w/ LED Port
LED Color: Purple / UV LED
1 x Termochill PA120.3 Radiator
2 x Swiftech MCR-320-QP Radiator
1 x Bitspower UV Mesh Radguard 360 (3 x 120mm) - UV Blue
1 x Chilled PC Black anodized Thermochill radgrill
2 x EK-Multioption RES 250 Rev 2
1 x Swiftech MC-RES- MICRO
4 x Bitspower Ultimate G 1/4 Thread 3/8" ID x 5/8" OD Compression Fitting
2 x Bitspower Chrome G3/8" Barb Fitting - 3/8" ID
10 x Bitspower Chrome G1/4" Barb Fitting - 3/8" ID
10 x PrimoChill PrimoFlex PRO LRT Tubing 3/8"ID 5/8" OD - UV Blue
10 x PrimoChill PrimoFlex PRO LRT Tubing 3/8"ID 5/8" OD - UV Green
2 x Feser One Non Conductive Cooling Fluid - 1000 ml - UV Green
2 x Feser One Non Conductive Cooling Fluid - 1000 ml - UV Blue
4 x FrozenCPU Lighted Crystal LED Plug G1/4 UV
Things I need: (feel free to contact me for a trade, I have an e6600 cpu that could trade [or trade+ cash] for a pump).
1 x Pump for chipset/PWM loop.
1 x PWM Waterblock for DFI LT x38
1 x T80 Lian-Li replacement case top for PC-P80
(do you guys thing a A70 solid replacement top panel could be plasma cut to fit the PC-P80 ???)
Since I have been at RPI the thing I have been looking forward to the most has been the machine shop, today I went down to check the place out and I was pleasantly surprised. I found out that I have access to a CNC Plasma cutterfor cutting any 2d design I would like down to 2/1000 accuracy. I have nearly unlimited free access to this cutter and it is going to meld perfectly with my build plans
. I also have access to numerous manual mills, a brand new CNC Lathe and many Manual Lathes.
The case internal frame is going to be painted Matte White (cant decide whether to powdercoat or spray paint white) and I will be following a theme of blue LEDs and UV blue items inside the case.
The first time I will be home to pick up parts for the case is October 10th. In the coming week I will be posting side panel designs and asking for opinions. I hope to bring you guys a top notch, all out build that will go down in the record books![]()
