Post Edited to eliminate unnecessary steps... ![]()
Hey Everybody,
As Ya know, I had some Multi-GPU issues and managed to get them resolved. One of the long-term solutions was making and installing a "VGA Dummy". Very simple and easy to do, so I thought I would share some pix, and put the links in one thread.
Shadowtester's links:
VGA Dummy
FAH folding Forum
Google Diagram:
As stated in the prior thread (linked above): Radioshack apparently does not carry "75 ohm" resistors, but any resistors from ~50-150 ohms will work from what I understand. What I do know is that Radioshack carries 68ohm resistors and they do work.
Instead of using a VGA plug and then having to attach that to a VGA to DVI adapter--I couldn't foresee any reason why I couldn't just use a DVI to VGA adapter.....so, that's what I did:
As can be seen in the picture, I alternated the orientation of the actual ceramic resistors in order to create a "built-in" seperator or divider to help keep the leads from contacting each other.
So far its working Great!I've rebooted with the dummy installed and got exactly what I needed:
Crunching XS:
