XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mobile
Reply
Old 08-22-2008, 04:20 PM   #1
FUGGER
Xtreme Owner
FUGGER's Avatar
Send a message via MSN to FUGGER
Cyberpower Extreme M1 E0 Quad
http://www.cyberpowerpc.com/system/Gamer_Xtreme_M1/
Retail $2299
Intel Extreme Core 2 Q9300 QGNG E0
Intel Extreme Core 2 X9100 QBEE C0
Intel Montevina PM45 mobile platform
4GB DDR3 SODIMM
17" 1920x1200
ATI M88 Crossfire 3870
ICH9M SATA Raid Controller
RAID 0 Seagate ST9160823AS
ESATA Port
Blueray DVD
HDMI + Displayport
Bluetooth
Authentec Biometric
Avermedia TV Tuner
High Definition Audio
Optical Audio out
2MP digital camera
HDSD Media
Backlit Keyboard
Piano Black Finish
This model will also be known as the OCZ Whitebook, oddly the site pushes the Corsair memory as an upgrade option.
Designed to be a mobile desktop and doubles as a gaming machine, it cannot go long without being plugged in so if you are looking for something a bit more lap friendly this machine might not be for you.
Showing it around at IDF most people commented on the finish and finger prints, this doesn't bother me but if that is a concern this is a fingerprint magnet.
Weight is 11.5 pounds not including the power brick, daily travel might be a problem for some, lan events or someone who needs the graphics horsepower on the go this will do very nicely.
Pretty much every feature possible is in the Extreme M1, I expect to switch over to solid state hard drives when available to increase battery life in power saver mode.
In power saver mode I get about two hours battery life if I dont run 3D and crossfire. Watching a full length movie is possible on battery, I have done it.
Overclocking I can reach 500Mhz overclock on both cores without any special cooling, the system must be on a flat table for proper air flow. This should be normal for others to hit. 1Ghz overclock on both cores is possible with added cooling, I will be using a 8K BTU AC unit for my high speed runs.
No issues with the video cards overheating other than the back plate must stay on, removing it will cause the GPU's to fail.
Intel Xtreme Tuning Utility is operational and works with the XTU enabled bios. XTU gives you more options that what is available in bios. You can adjust vcore, vmem, memory timing, FSB, and multiples. You must save to bios and reboot for changes to take effect, you can change FSB without rebooting.
There is no ability to change NB voltage and I seem to max out at 312Mhz on this sample. I will push harder once under AC blast.
Im going with low speed benches first and I will update with high speed benches. No AC assist, ambient air. I will be adding more benches, bandwidth to Cinebench. I will swap back to X9100 for 4Ghz + benches.
__________________
Intel Core i7 965
Asus Rampage 2 Extreme
Nvidia GTX 295
Corsair Dominator 6GB 1800C7
Intel X25 SSD
FUGGER is offline   Reply With Quote
Old 08-22-2008, 04:37 PM   #2
[XC] riptide
Dak's Son
[XC] riptide's Avatar
Send a message via MSN to [XC] riptide
Just add LN2
__________________
Originally Posted by 3Z3VH View Post
A fine line divides "Ghetto" and "Extreme" !
De gustibus non est disputandum
[XC] riptide is offline   Reply With Quote
Old 08-22-2008, 04:42 PM   #3
TheGoat Eater
insane~mentally hilarious
TheGoat Eater's Avatar
Send a message via ICQ to TheGoat Eater Send a message via AIM to TheGoat Eater Send a message via MSN to TheGoat Eater Send a message via Yahoo to TheGoat Eater Send a message via Skype™ to TheGoat Eater
I WANT - looking for a new laptop and this could be it - Damn this thing is good
__________________
http://thegoateater.com/
Using, Overclocking, and Testing MSI Products
TheGoat Eater is online now   Reply With Quote
Old 08-22-2008, 04:44 PM   #4
Knight
Knight's Avatar
How can MS give it a 5.7 with that type processor.
Great post Fugger. Glad to see the new stuff role out.
__________________
Intel | Q6600
ASUS | P5Q-Deluxe
G.Skill | 2x2GB PQ
Nvidia | 8800GTS 320MB
Seagate | 2x320GB 7200.10 Raid 0
Corsair | 520W PSU
Knight is offline   Reply With Quote
Old 08-23-2008, 02:10 AM   #5
dinos22
teamau.net
dinos22's Avatar
i thought you tested the quad core chip
maaaaaaaaaaaan if someone told me a few years ago i'd be looking at mobile quad core laptops i'd tell them to wake up and smell the coffee heheheh
__________________
Team.AU
Got tube?
Gigabyte X58-UD5 Testing
dinos22 is offline   Reply With Quote
Old 08-23-2008, 08:30 AM   #6
m0da
m0da's Avatar
Send a message via AIM to m0da
only $2300? That seems nice a very nice deal!
__________________
m0da is offline   Reply With Quote
Old 08-23-2008, 02:31 PM   #7
Lestat
I am Xtreme
Lestat's Avatar
Send a message via AIM to Lestat Send a message via MSN to Lestat
pretty nasty temps for a laptop.... looks more like the mac books that would set your leg on fire.
i think they have a long way to go to get proper cooling.
(i hope to heck they are not using the typical single heatpipe on the core)
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
Lestat is offline   Reply With Quote
Old 08-24-2008, 03:19 PM   #8
eXceededgoku
eXceededgoku's Avatar
Send a message via MSN to eXceededgoku
Where did you get the Intel Xtreme Tuning Utility? Been looking for it for a while now...
__________________
Core 2 Duo E6600 @ 3.2Ghz (400Mhzx8) 1.52V (set in bios, 1.47v after droop)- worst C2D ever | 4GB GeIL PC6400 4-4-4-12 @ 800Mhz 4-4-4-12 | Gigabyte DQ6 @ 1600Mhz | Sapphire 1024MB HD2900XT @ 858/1153 | Enermax Infiniti 650W | Silverstone TJ07-B with custom watercooling (CPU/MOBO/GPU) | Vista Ultimate x64 | BenQ FP241WZ
eXceed TJ07 worklog/build
eXceededgoku is offline   Reply With Quote
Old 08-24-2008, 05:57 PM   #9
STEvil
tl;dr
STEvil's Avatar
Send a message via ICQ to STEvil Send a message via MSN to STEvil
any pics of the heatsink units?
You should be able to drop the volts too for the Q9300, i'm over 3600mhz @ 1.2v (and less) on my E0's.. though they're 771 I guess.
__________________
Heatware - 01.01.08; AND 110.9%
Dead Z7S-WS? Click!.|||XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 14 of 16 (Thats nearly $10,000 in dead motherboards).
All along the watchtower the watchmen watch the eternal return.
Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
STEvil is offline   Reply With Quote
Old 08-26-2008, 11:14 AM   #10
an0nym0us
Xtreme Cruncher
an0nym0us's Avatar
man that laptop looks sickkkk
__________________
Team XS WCG. Work it harder, Make it better, Do it faster, Makes us STRONGER!
Q9400 @ 3.80ghz | Thermalright Ultra-120 Extreme |Gigabyte GA-EP45-DS3R | 2gb G.Skill DDR2-800 @ 1040 | 2x WD Velociraptor in RAID 0 | 1tb WD SATA | Gigabyte GTX 260 896mb | Seasonic M12 700w
E8400 @ 4.05ghz | Scythe Infinity |GA-G33M-DS2R | 2gb G.Skill DDR2-800 @ 900 | 2x Raptor 74gb in RAID 0 | eVGA 8800GTSC 512mb |OCZ PowerSteam 520w
QX6700 | Coolermaster HSF | GA-P35-DS3R | Team Xtreem D9 2gb | 1x 160gb WD HDD 4x WD Caviar Black HDD in RAID 5 | ATi 9200SE AIW | PCP&C Silencer 750w
XPS M1330 Laptop | T7500 2.2ghz/4mb/800 | 3gb DDR2 667 | 250gb SATA | 8400M GS 128mb
FOLD FOR WCG!
an0nym0us is offline   Reply With Quote
Old 08-26-2008, 11:38 AM   #11
metachronos
metachronos's Avatar
That is ing awesome, never thought I would want a cyberpower anything, but I guess pigs can fly.
metachronos is offline   Reply With Quote
Old 09-07-2008, 12:21 AM   #12
FUGGER
Xtreme Owner
FUGGER's Avatar
Update
Sub Z and higer overclock, benches coming.
__________________
Intel Core i7 965
Nvidia GTX 295
Intel X25 SSD
Old 09-07-2008, 06:19 AM   #13
Oliver
keep pushing it
Good to see your pushing it Charles
Oliver is offline   Reply With Quote
Old 09-10-2008, 07:31 AM   #14
-Acid-
Xtreme Cruncher
Send a message via MSN to -Acid-
Thats one nice laptop !!!!
If we tryed to get one like that over are side of the pond it would cost that in Ł alone
just how long would the battery last charles and hour or so
-Acid- is offline   Reply With Quote
Old 09-18-2008, 07:21 AM   #15
Revv23
I am Xtreme
Revv23's Avatar
Send a message via AIM to Revv23
Haha this is sweet but so impractical.
Revv23 is offline   Reply With Quote
Old 09-18-2008, 08:48 AM   #16
MightyAA
You might also follow a thread over at the guruofgaming forums. Killernotebooks got their hands on one and has started playing. He calls it the Nagamaki (it's a OCz Whitebook).
Typically, he also overclocks. He also does bios mods, os tweaks, core logic software, custom cooling, etc. Here are his benches so far.
He's been working on tweaking the gpu's drivers. So far on Crysis, he's up to:
stock: Run #1- 1024x768 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 25.83
best runs so far: Run #1- 1024x768 AA=No AA, 64 bit test, Quality: High ~~ Overall Average FPS: 48.525
and larger resolution with his latest
Run #1- 1900x1200 AA=No AA, 64 bit test, Quality: High ~~ Overall Average FPS: 30.8225
MightyAA is offline   Reply With Quote
Old 10-02-2008, 02:59 PM   #17
FUGGER
Xtreme Owner
FUGGER's Avatar
An update
__________________
Intel Core i7 965
Nvidia GTX 295
Intel X25 SSD
Old 10-02-2008, 03:05 PM   #18
cadaveca
Banned
Send a message via Skype™ to cadaveca
Will they RAID in there?
cadaveca is offline   Reply With Quote
Old 10-10-2008, 10:45 AM   #19
MightyAA
Just a quick update what Killernotebooks has been upto since they've gotten the production models.
He's now cnc machining new heatsinks to shed heat better. Fighting with OCz since their 1333 ram isn't working on the production model. He's working with Arima and OCz because the QX9300 has bios issues.
Anyway, he's got it overclocked and expects to get a bit more out of it in the next week or so. As it stands, he's got it upto 15,143 3dMark06 on air with just a multiplier overclock.
And a more normal overclock I'm guessing will be his product's overclock at 3.00 GHz
He's going to post temp screenies later, but he's done the 9100 oc'd to 3.33 GHz and got 75 degrees at full load with his new heat blocks.
Old 10-10-2008, 01:12 PM   #20
fragmasterMax
fragmasterMax's Avatar
Send a message via AIM to fragmasterMax
I just figured out this had 3870's in crossfire.
i was wondering why the 3dmark scores where so high.
Sweet notebook.
__________________
Permanent parts: CM 690 with ten ~110 cfm .7A fans hooked onto a Rheobus fan controller. silent/off at idle. scythe orochi antec neohe550 psu,
My budget system:
e8400:ep45ds3l:g92 8800
Heading to boot camp: (Not the kind for your Crapintosh.Combat medic/EMT 68w Jan 21rst Out in Aug
How To: SAVE POWER
Do you have "Broken" hardware?
I'LL BUY IT
As Los Alamos director J. Robert Oppenheimer watched the demonstration, he later said that a line from the Hindu scripture the Bhagavad Gita came to mind:
"I am become Death, the destroyer of worlds."
Test director Kenneth Bainbridge in turn said to Oppenheimer, "Now we are all sons of b**ches." wiki
fragmasterMax is offline   Reply With Quote
Old 10-10-2008, 01:34 PM   #21
Gautam
Captain Jinx
Gautam's Avatar
Send a message via AIM to Gautam Send a message via MSN to Gautam
Originally Posted by FUGGER View Post
An update
You're getting owned Charles.
__________________
I put on my shoes before I put on my pants.
Gautam is online now   Reply With Quote
Old 10-17-2008, 09:04 PM   #22
TheGoat Eater
Yep - he has them in RAID 0
__________________
Old 10-20-2008, 11:07 AM   #23
lha
lha's Avatar
OMG that almost better laptop tha my PC!
I am so jealous to YOU FUGGER!
lha is offline   Reply With Quote
Old 11-05-2008, 01:51 PM   #24
mhooper1125
Im new around here but I purchased the Nagamaki from Mark over at Killernotebooks so far I have personally managed this:
Hopefully Fugger will be of assitance to get that number a little higher =)
I know another client of his got 16,500+ with the x9100 Duel Core.
mhooper1125 is offline   Reply With Quote
Old 11-05-2008, 06:06 PM   #25
Anemone
Perpetually learning
subscribing because...
Due to the way life turns I still want to game but have to be more mobile, with emphasis on "more" not "totally" so a DTR is in the offing in the next 6mo or so. Curious to see how the Quad is performing and how high it can clock. Running a room AC through the thing is exaaccctly what I was thinking for speed when home based.
Think 40nm GPU's in the springtime and a quadcore and possibly the Q45 chipset, 160gb SSD and 500gb/7200 and you will have a good idea of what I'm thinkin.
TY Fugger for a nice job that just read my mind!
Anemone is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
