Results 1 to 19 of 19
Thread: Undervolting 9850BE.
    Apr 2005
    Well...i no longer ocing the 9850BE...so now im running at stock with a MSi K9A2 platinum with bios 1.4.
    I was wondering can i undervolt the 9850BE from the current vcore to a lower one which still maintaining at stock speed???
    i7 4770 | 24GB | Z87 Mpower | 1070FE | 512GB/1TB/2TB | WiNDy FC500 | 2713hm | 2.0 | 650w
    Sep 2007
    Quote Originally Posted by ragnarok95 View Post
    Try? Please do, and report back. I don't know anything about the K9A2 BIOS, but it might support undervolting, or you'll have to use a program like RMClock, or CrystalCPUID.
    Xtreme Mentor
    Mar 2006
    You should .... in fact, how far you go will be an indication of how tightly AMD might be binning the processor.
    I suspect 0.1-0.3 volts, try, the worst that can happen is it locks up. You cannot damage the CPU but supply too little voltage.
    Jack
    One hundred years from now It won't matter
    What kind of car I drove What kind of house I lived in
    How much money I had in the bank Nor what my cloths looked like.... But The world may be a little better Because, I was important In the life of a child.
    -- from "Within My Power" by Forest Witcraft
    Apr 2005
    Ok, tried. Stock is 1.288v, now using AOD, i set it to 1.2v. CPU-Z report at ~1.208 - 1.216v. Temp drop by 3 degrees as in coretemp.
    Using K9A2 platinum and bios v1.4, the bios doesnt allow me to go below 1.3v....does it mean that it needed 1.3v to boot up? Or other bios version able me to go below 1.3v in bios??? I have yet to test bios v1.5 however.
    Im using AOD to adjust and auto load when its in window.
    Jul 2008
    K9A2 will not let you under volt (on bios 1.2-1.4 tested) wouldn't under volt on my 9850BE nor my 9550
    Apr 2005
    Ok, i undervolt further now to 1.2v using AOD. CPU-Z reports ~ 1.180 - 1.196v. Thats a drop of 0.1+v with a reduce in temp.
    I like!
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    I run mine at 2.8ghz @1.2375v since the day I bought it
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    Xtreme Mentor
    Mar 2006
    I like!
    Power (active power, i.e. loading) goes as the square of the voltage, if you reduce 10%, you are actually getting a .9^2 factor in power or a 20% reduction in power.
    Apr 2005
    Ok, playing with current vcore of 1.2v, able to play CnC3 no hang/restart/freeze up. Listening to music/movie ok too.
    Mean i can still go lower....
    Doing 1.18v now. CPU-Z reporting ~ 1.17v now.
    Apr 2005
    Thanks everyone here for the input!
    Now i lower it to 1.165v....
    Man i really like this cpu even more now!
    Apr 2005
    Doing a 1.15v now...
    Apr 2005
    Ok, think i will stop here. Vcore at 1.125v.
    Anyway, in AOD, under CPU VID, i set to 1.125v, CPU VDDC is showing 1.288v but its highlight in RED. IS it ok????
    Sep 2007
    The program probably has limits, and you're at the bounds of those limits, so it's telling you there's a problem. But since you did this intentionally, don't worry. So, 1.125v? Have you stressed the processor? If you can get 1.125v stable, that's impressive. I wonder what kind of power consumption the processor is drawing.
    Apr 2005
    Well...i ran a couple of games, play some music, watching movie, doing office work, a few tabs of IE running, doing what i normally do and i yet to get a freeze up.
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    I was playing around with this same concept on my SB750 board yesterday. I was trying to see the lowest possible working voltage for the chip, so I disabled three cores and clocked down to 1600MHz. I was able to run at 0.800V. Full load pulled just 18W off of the 12V rail. Idle was about 13W. Now that's entertainment. Anything less than 0.800V caused a crash, so I'd say you can probably consider that an absolute minimum. I'm hoping that gives you a perspective on usable range now, and that might help you tweak your target voltage. I think 1.1xx is pretty good, personally.
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
    Jul 2008
    Quote Originally Posted by Particle View Post
    Pardon the hijack, but could you describe step-by-step how you disable cores?
    Aug 2004
    undervolting is good fun
    the older cores seem to have been much more tightly binned:
    laptop 3400+ clawhammer stock 1.5V (89w DTR cpu)
    2200mhz min volts = 1.45
    2000mhz min volts = 1.175
    thats some huge volts drop for 200mhz freq
    desktop x2 6400be 3200mhz @ 1.275v down from 1.4 stock
    LCB9E 0641 APMW @3100 1.65V Decapped ~50c orthos load, TDX+House Rad (passive!)+Eheim 1250, Abit AX8, 2*1gig Crucial PC4000 @ 221 3-3-3-8-1T
    X4 940BE @ 3640 @1.475, Gigabyte GA-MA790X-UD3P, 4x G.Skill F2-8500CL5D-2GBPK @ 1110mhz 5-5-5-15 @1.8v, 3870XT
  18. #18
    Jul 2008
    Quote Originally Posted by Herbie21 View Post
    At least with Asus M3A32-MVP Deluxe you can do it via BIOS. Simple option for it.
  19. #19
    Jul 2005
    I'm running a Phenom 9500 at 1.15, haven't pushed to see if it will go lower.
