Every other log has a name so I guess pimp will do
Anyways.. Pics of old setup:
I want to do a significantly better job this time around. I want this case done perfect the first time around.
Hardware used:
eVGA 780i
E8400
4GB Patriot Viper
2 Galaxy 8800GTs
800W Odin GT
Silverstone Commander ESA fan/light controller.
Loop 1:
DTEK Fuzion V1
ViperJohn 780i NB Block
MCP355 w/ EK X-140 top
MCR320
Loop 2:
2 x MCW60
MCP350 w/ Petra's top
Swiftech Micro-Res
MCR220
Here is the Black Pearl stock. Although I am sure most of you know what it looks like.
case stripped and RadGrillz templates on.
Radiator holes cut. Still need to clean up the edges a bit.
And yes the doorstep is my workshop Well off to work. Tomorrow I'll be cleaning the edges up and cutting the remainder of the wire management/tubing holes.
