Hey all =)
NEW WORKLOG IS HERE!!!
This will be my first attempt at liquid cooling, I want to do as little modding required and have the best "look" I can =)
Ok, So my LC parts are currently on their way to me from Jab-Tech (Best support I have seen!)
This is what I will be using -
Heating
Intel CORE 2 Q6600 2.4Ghz
Asus P5KC - DDR2/DDR3 support
DDR2 2048MB Team Xtreem Dark
GeCube Radeon 4870 GDDR5 512mb
Samsung 750gb
Western Digital 160gb
Corsair HX620 watt modular
Silverstone TJ07
Cooling (On its way)
D-tek Fuzion V2 (Barbs: 3/8" Dtek Barbs)
Swiftech MCR320-QP-K Triple 120mm Radiator (Barbs: 3/8" Swiftech Metal High Flow)
Swiftech MCP 355 12v DC Pump
XSPC - Acrylic Reservoir for Laing DDC
PrimoFlex Pro LRT UV Blue Tubing - 3/8in. ID x 5/8in. OD x8
EK High-Flow Fitting - 3/8" OD x4
Plastic Tubing Clamps - Black x10
ARCTIC SILVER ARCTICLEAN 60ML KIT - THERMAL MATERIAL REMOVER
Arctic Cooling MX-2 Thermal Compound
YATE LOON 120mm Case Fan - D12SH-124B - UV Blue Frame with 4 Blue leds - High Speed
Scythe "KAZE MASTER" 5.25" Bay Fan Controller - Black
I hope to get my Quad core to ATLEAST 3.4ghz which really should be a piece of cake :p
I STARTED off by wondering where I can mount the HD cageThen an idea popped in my head!
(Sorry for some bad pictures, My camera doesn't want to work atm)
THINKING WHERE I CAN MOUNT THE CAGE
I TOOK OUT THE USB/AUDIO BAY. REPLACED IT WITH HD CAGE =)
NO MODDING/SCREWS REQUIRED!!!
FINAL LOOK
So that is pretty much all I can do until i get my LC items to play around with
More pics will be with you as soon as I receive my goodies![]()
