Yesterday my with my buddies tosunermc and AbsoluteZero had some fun on that mabo, it s too bad although i figured out ovp mod, after i did it save-existing bios was not possible
, then stuck at 1.85v so only 6g validation and some fsb try. it was able to do 1m at 5864 but didnt try to optimze it since too low speed with this cpu
, well, here the ss.
btw, coldbug for nb was around -70c
http://valid.x86-secret.com/show_oc.php?id=384379
SETTINGS
M/B : BIOSTAR TP I45 (BIOS:P45BA620.BST)
CPU : Core2 Duo E8500(ES)
CPU cooling : Zalman / Temp:56C-80c
Chipset Cooling : old socket A nb heatsink + amd 939 stock fan
Mem : Corsair+kingstone PC2-8500 C5 512mb
VGA : 9600gt PCI-E
VGA Cooling : Stock
HDD : Seagate 320gb ide
OS : Windows XP
[BIOS SETUP] O.N.E
Over-Clocking Navigator [Manual OverClock]
Intel(R) SpeedStep(tm) : Disabled
Ratio CMOS Setting : ×8
CPU Frequency Setting : 665(boot)
Over Clock Retry Count : 3
FSB(Bsel) To NorthBridge Latch : 1333
DRAM Frequency : DDR2-1330
DDR2 Enhance Mode : Disabled
DRAM Timing Configuration
DDR2 RCOMP Configuration : AUTO or 1 ,cant remember
Static tREAD Value : Auto
Configure DRAM Timing by SPD : Disabled (5-5-5-15)
Clock Gen Configuration
PCIE Frequency Setting : 100
CPU Clock Skew Control : 200ps
(G)MCH Clock Skew Control :100ps
CPU Clock Driving Control : Auto
Voltage Configuration
CPU Voltage : +0.7000v
DDR Voltage : +0.900v
Chipset Voltage : +0.700v
FSB Voltage : 500
CPU Core1 GTL Ref Voltage : 0.63*VTT
CPU Core2 GTL Ref Voltage : 0.67*VTT
MCH GTL Ref Voltage : Auto
CPU PLL Voltage : 1.6v
(i again used NB's writing as template
btw, can some mods change title of the thread to "705.5*8 with Biostar I45..This time on LN2
