Results 1 to 19 of 19
Thread: Corsair Nautilus 500 Mod (Easy)
    Jul 2007
    Florida
    Talking Corsair Nautilus 500 Mod (Easy)
    Just finished modding a Nautilus 500 and wanted to share since I saw some commenting on them and modding them. This is a simple mod and took at total of 5 hrs. I could have finished quicker but - I was just relaxing and enjoying the day.
    Parts list for the Mod:
    Xchanger 120 http://www.performance-pcs.com/catal...ducts_id=23556
    3/8" fittings http://www.performance-pcs.com/catal...ducts_id=21263
    Scythe Ultra Kaze 3000 http://www.performance-pcs.com/catal...ducts_id=22540
    Chrome 120mm grill http://www.performance-pcs.com/catal...roducts_id=249
    Mini Shroud 120mm http://www.performance-pcs.com/catal...oducts_id=3511
    Permatex Black Silicone http://www.autoaccessconnect.com/peblsiadse.html
    Black Rubber Feet (2") from Lowes (Couldn't find link but here is similar)
    http://www.starglass.com/products.html
    http://www.starglass.com/images/Rubb...r%20Bridge.jpg
    I started by removing the rubber feet under the stock Nautilus. There you will a total of 4 screws that holds the upper housing to the lower housing.
    Then unplugged the fan power cable.
    I then fought like crazy to remove those Nutty Hose Clamps - Dont know what to call them other than a Pain in the Arse.
    The Aluminum Rad is held in place by some kind of epoxy. *(Thank Goodness the preform plastic was smooth or this would be a paint to remove.) Simply pry with a screw driver and the walls of the Nautilus are so smooth to allow the epoxy to break free.
    This is what you will have when done.
    Next I took my Beautifully Packaged Xchanger 120 out and traced a generic outline of the rad on the bottom of the housing.
    I dremeled about an 1/8" away from my trace line and filed up to it, to ensure a tight fit. (A lot of time goes into this - for looks, even though no one will see the bottom but you.)
    Not done filing but you at least get the picture - not going to kill you or bore you with multiple filing shots.
    Next I dry fit the 90* elbows and Rad into the Nautilus. I pretty much pushed it all the way to rest on the plywood. I did this so that I could dry fit the top with a Ultra Kaze 120x38 (3000 = 133cfm) fan and check for clearance.
    Well after that, I could clearly see that there was NO WAY that the fan and Rad were even remotely close to fitting. So I ordered a simple 120mm shroud and traced it out on the top of the Nautilus. *** Note that the shroud has a 1/8" lip and dremel again about an 1/8" from the line and file to the needed size.
    Next I went ahead and installed the Fan in a PULL CONFIG and replaced the close knit mesh guard that was stock with a normal wire grill. (The air will be pulled from the bottom and exhausting at the top of the unit.)
    I dry fitted the top again, and note that the Rad is still just sitting on the plywood. Once it was fit into position, I slid the Rad up until it was bottoming out against the top of the housing. I then tacked it on with some hot melt glue - in four corners. I flipped it over and made sure it was level. (Rad was same height all the way around)
    Once I had it where it was going, I then painted 2 "L" angle brackets and then attached them to the Rad and Housing. This secures the Rad in place.
    I then installed another wire grill on the bottom since the Rad is extended about 1/4" past the housing.
    I then used Black Silicone Permatex to seal the Xchanger so that there were no air voids. Where it crosses through the housing. This will prevent any air not coming through the rad. (You dont want the cool air to go around it, but through it.)
    ****DOH just realized I dont have a clean pic of it siliconed and am too lazy to take another pic....
    I then installed some simple 2" black rubber feet I picked up from Lowes. They took the shape of the square feet nicely.
    OK - Now it is done and if anyone knows where I can get an Feser Xchanger Sticker from, please let me know. I want to attach it right before the logo for Nautilus 500.
    Leak testing Now for about 9 hours. No issues what so ever! I noticed when I took it apart that the Green LED was point straight down - so I remounted it pointing directly into the res and now it is BRIGHT as HECK!
    I really dont know what I will use this on yet.... my sons really want me to cool their xbox 360 with it, but my honey's computer could use it for a cpu only loop as well. Oh well - I just enjoy modding and dont know what I will do with it.
    Please post some feed back if you enjoyed the read or hated it - this is my first tutorial of sorts!
    L8R,
    RoB
    Apr 2007
    arizona
    wow impressive
    How much better does it cool then with the stock rad
    FREEDOM ISN'T FREE
    Cruncher Support:
    Utnorris
    DarthBeavis
    DEFRANCO NATION
    _____________
    E6750@ 3.0ghz- evga 750i FTW- 320gb- Swiftech MCR220 compact- 8800gts 512mb KO- 620hx - 4gb Crucial 1066- CM 690- 6 yate loons
    E6600- Asus striker Extreme-2 x 750gb- Igloo 5710- 8800gt- antec 850w Quatro- 4gb DDR2 800- Antec 1200- 24/7 cruncher
    **Wishes for a dual- quad core cruncher **
    Mar 2006
    Los Angeles CA
    Probly a lot...
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    great mod.
    However im hurting at the price you paid on that radiator. :X
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Jun 2007
    Quote Originally Posted by NaeKuh View Post
    great mod.
    Aye, has there been any testing to prove that the PA just got beat anyways?
    Nov 2007
    COLORADO
    no proof yet.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    wow I like! wish I could do that to my Nautilus 500 hehe (lack the skills heh)
    congrats man!
    Aug 2007
    San Diego, CA
    very good work!! it turn out very nice! props!
    Quote Originally Posted by Kunaak View Post
    High end videocards are like hot girls.
    your never gonna pick the fat girl with the nice personality over the smoking hot 10.
    E8400
    DFI X38
    ATI 4870 X2
    8 Gb GSkill
    2x 36 Gb Raptor RAID 0
    750 Gb WD
    CPU, NB Water Cooled
    Xtreme Cruncher
    Feb 2008
    C:\WINDOWS\system32\
    Nice mod! I'm hurting that you spent $115 on a 1x120mm radiator, however.
    Jul 2007
    Florida
    wow impressive
    I honestly have no idea - I haven't connected it to anything yet.
    I will be adding a LCD for Water Temp soon though.
    great mod.
    Thanks and yes I too am choking on the price! I have to say though that I'm a sucker for the Feser Marketing!
    Thanks for the kind words everyone - and @ eva2000 it was super simple... no skills, trust me. Honestly!
    There was just no way that I was gonna mix metals in my loop, and oh for the price - I got the Nautilus 500 for $50 from a friend of mine who never installed it and went a Heater Core route. So... all in all I decided I could splurge a little on the Radiator side.
    One thing that I am impressed with, is the Pump (DDC - Laing) this little guy "JETS" the water through it. I almost drowned trying to fill it and bleed it..... the return to the Res is like a Pressure Washer, it litterally bled in a few minutes!
    Thanks again for the comments.
    RoB
    Banned
    Jun 2006
    in a Red Rage D....
    well since its a single 120 rad size, might as well get whats best and available at the moment. Cooling power and Quiet fans i hope...
    and it looks like money is not a problem for him...
    Chasing After Diety
    Jan 2007
    Quote Originally Posted by septim View Post
    lol he lives in the US.
    today's gas prices here, money is a problem to everyone.
    Banned
    Feb 2008
    Buffalo, NY
    nice work man!! good to see you take a pre packaged system and make it xtreme!
    Lets see some results/overclocks!
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    Wow very nice mod mate
    excellent work
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
    Banned
    Jun 2006
    in a Red Rage D....
    well i also see a 3000rpm fan in there, this should perform good due to the fannage...
    Xtreme Legend
    Mar 2005
    Australia
    nice mod dude
    i was a bit lazy with my one but it works
    Team.AU
    Got tube?
    GIGABYTE Australia
    Jul 2007
    Florida
    Thanks for all the comments guys! I really appreciate it. I still have it sitting...... I really dont know what to cool with it yet. It's just sitting, but I will think of something. I think I may open it back up and JB Weld a Temp Sensor in the Res and mount it flush on the top, or face of it.
    Anyway - thanks again!
    Oh... and the only reason I was able to pull it off was because of all of the great posts (Mods) in this forum for inspiration. I truly learn alot reading here.
    L8R
    OH and I swear the fan is not loud in this unit..... to me anyway. And it moves a ton of air.
  18. #18
    May 2007
    Sweden
    Our gas just went up to 14SEK/Liter = $2.34/qt in the US.
    Do I smell open revolt and uprising if that was to happen in the US??
    They say the definition of madness is doing the same thing and expecting a different result.
    Howlin' Pelle Almqvist
    Project Log Completed: all internal v1000
  19. #19
    Feb 2007
    Quote Originally Posted by LogAn'sRun View Post
    You would....because it'd mean that our tax on gas would be 10X what the tax is now...sort of like what you're paying for taxes on your gas. And that's the only reason you're paying so much for gas since everyone's paying the same for oil and refining costs are pretty much the same no matter where the oil is refined. So your high gas prices compared to other countries' prices is solely due to your gov't. taxing the crap out of it to encourage conservation and production of small, fuel efficient cars.
    Papa: Q6600 @ 3.6GHz @ 1.34V, Asus Maximus Formula, 4 x 2GB Mushkin Redline DDR2-1000, Asus HD4870, Antec Sig. 850, Lian-Li/RF case....WC'd via D-Tek FuZion w/quad nozzle, EK S-Max on NB, Laing DDC2 w/XSPC top, 2 x Feser 240's & one TC 120.1 rads.
    Momma: Xeon 3210 @ 2.8GHz, Gigabyte P965-DS3, 4 x 1GB Ballistix DDR2-800, Asus HD3870 TOP, Enhance ENP5150-GH, Lian-Li/RF case, HK Champagne 2.1, Xigmatek HDT cooler
