Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: Super Talent Project X 2GB DDR3 2000 9-9-9-28
Hybrid View
    Phenom™
    Sep 2002
    Super Talent recently offered me a chance to play with the newest addition to their Project X lineup of DDR3 and I thought you guys may be interested in the results from this sub-$300 set of memory. Let's first start off with the official specs on the kit:
    http://www.supertalent.com/datasheet...UX2GP_spec.pdf
    *A few notes regarding testing:
    - I used my 790 board since it was what Super Talent had done their testing with. This presented a few of HUGE problems:
    1. OS boot corruption occurred EVERY time I tried to boot with the memory set higher than 2050. That's why you'll notice the highest memory speed benchable was 1025. It didn't matter what CL, or voltage, or what FSB. As soon as I set >2050 memory from BIOS, my file system corrupts. I had to re-install windows 6 times before I figured this out.
    2. CL6 testing resulted in another type of corruption in windows. Anything beyond ~1600 CL6 caused the OS to lock me out of accessing my HDD. Every time I tried to save anything to my HDD or even browse it, my computer would BSOD. I ended up having to run my picture program from a flash drive in order to save the screenshots.
    3. The lack of a Clockgen for the 790i made it a chore to do memory testing with the board. Therefore, I would have loved to have more give more results, but after a week and a half of constant booting and re-booting, I thought I'd just post what I have at the moment. If you want, I have some other results, let me know
    -Testing was done with minimal voltage adjustments for sake of saving time. The 32m's were not tweaked for times whatsoever (short of LSC on) so nobody say anything about the horrible SuperPi times .
    -The kit is rated @ 1.7-1.9Vdimm so, naturally, I'll show results STARTING @ 1.9V .
    Test Setup:
    CPU: Intel (Yes, I know...but AMD has nothing running on DDR3 - at least publicly- yet ) E8400
    Motherboard: Asus Striker II Extreme, BIOS 0507
    Memory: Super Talent Project X W2000UX2GP
    Video: EVGA 8800 Ultra
    Cooling: Thermalright Ultra-120 Extreme
    PSU: Corsair HX1000
    Secondary memory settings were as follows (for ALL runs):
    P1 = Enable
    P2 = Enable
    tRRD = 5
    tRC = 4
    tWR = Auto
    tWTR = Auto
    tFAW = Auto
    tRD = Auto
    tRTP = Auto
    tRFC = 72
    tREF = Auto
    Default
    1.9V
    CL7
    CL8
    CL9
    2.0V
    CL6
    CL7
    CL8
    2.1V
    CL7
    Just for fun @ 1.9V
    I'll try to get some benching done with x48 later.....I want to get as far away from my S2E as possible for awhile
    Xtreme Legend
    Mar 2005
    Australia
    try using 7-6-6-x timings with JNL ICs
    i'm surprised those ones were able to bench that high with 7-6-5-x timings
    i get instant corruptions if i try to boot at 1GHz 7-6-5-x hahahah
    Team.AU
    Got tube?
    GIGABYTE Australia
    Phenom™
    Sep 2002
    Quote Originally Posted by dinos22 View Post
    Hmmm....I tried 777 timings when testing @ 2.0V and it didn't seem to help at all. Although it may have been due to my OS being corrupt already
    Just for the record, this kit was a FULL RETAIL KIT....no handpicking or the like
    xtreme energy
    Oct 2004
    Europe, Latvia
    Side note about 790i, does this corruption occur if using PCI/PCIe raid card?
    8-7-6 1000Mhz is norm that we are looking for
    Phenom™
    Sep 2002
    Quote Originally Posted by kiwi View Post
    Good question....I've got a Promise SuperTrak EX8650 I can test with
    One-Eyed Killing Machine
    Sep 2006
    Inside a pot
    Yes.
    S7e9h3n use BIOS v0701 or v0702, the CL6 issue is been worked a tad with those, and some other bugs as well.
    Coding 24/7... Limited forums/PMs time.
    -Justice isn't blind, Justice is ashamed.
    Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by s7e9h3n View Post
    it turns out that some of these are still older Micron based kits hence why 7-6-6- didn't do squat
    impressive RAM nonetheless mate
    Team.AU
    Got tube?
    GIGABYTE Australia
    uncore challenged...
    Feb 2006
    ontari-ho (canada)
    looks like a good start.
    **edited because my Crucial kit turned out not to be JNL**
    i don't quote in my signature, but best WR ever...
    Quote Originally Posted by Jor3lBR View Post
    It holds the current WR for the least vcore required to run 4500Mhz stable (1.32vcore)
    i can't even make that shyt up ^^^
    Jun 2007
    Long Beach, CA
    Did you get a chance to test these on a x38 or x48 mobo? Wondering if they could do even better?
    CPU: Intel Core i7-4770K 4.8GHz
    MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
    MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31 1T
    GPU: 2 x eVGA GTX 780 SC
    SOUND KRK Rokit 5 Limited Edition White Studio Monitors
    SSD: 4 x Samsung 128GB Pro's Raid 0
    PSU: SeaSonic Platinum 1000W
    COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm 6 x Swiftech Helix 140mm Fans
    CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
    MONITOR: ASUS VG278HE Black 27" 149Hz
    O.S: Windows 7 Pro x64
    Mar 2005
    Pennsylvania
    Quote Originally Posted by Lu(ky View Post
    I just got the 2x1GB SST DDR3 1800 7 7 7 kit in yesterday. I will try and post up some SP 32M testing results of those on my ME.
    Daily Desktop Custom Built - Modified Data General Server Case
    Asus M4A79T Deluxe | 955BE C2 Rev | 4GB OCZ DDR 2000 @ 1600 6 5 6 1T | 4850x2 + 4850 w/MCW60 | CPU on H20 w/ Enzo Sapphire l Custom Built Pump and Res Combo 1/2 Gallon! | 4 Swiftech 320mm Rads with 6 All Aluminum Delta Fans with their own PSU - Finger Loppers - for real!
    Literally, CPU&GPUs are almost always at ambient therefore heat ain't limiting sh|t.
    Jun 2008
    Hi s7e9h3n,
    After reading your post and see that superb results, I decided to go
    directly to the nearest shop and buy the mobo Striker Extreme II and 2x1GB Super Talent Project X W2000UX2GP. So I did.
    But now I am struggling even to set the memory at default values of:
    2000MHz at 9-9-9-28, 1.9 V, slots 1&3.
    Even if I set SLI % CPUOC and CPU AUTO the mobo does not post and beeps for ever. I have tried a lot with different variants of unlinked, sync, lower multiplier, CPU Crazy, etc., but without success.
    I have also tried your settings (P1,P2 = Enable / tRRD = 5 / tRC = 4 / tRFC = 72), but again nothing.
    The best that I could achieve it was to overvoltage the mobo as suggested from Anandtech (maximum recommended for sustained operation):
    CPUvtt = 1.36V
    Vnb = 1.6V
    Vsb = 1.6V
    and then to post successfully, but I get blue screen after entering VISTA32.
    Did you achieve these results by tweaking mobo voltages? or not?
    Could you advise me what i have to do, to reach at least the default specs
    from this memory?
    CPU: E8500
    SEII with BIOS 704
    Supertalent W2000UX2GP
    2 GAINWARD 8800GTS (G92)
    Watercooling system
    Mar 2005
    Pennsylvania
    My Maximus Extreme needs alot more than 1.6 VNB to hit 500 FSB (I assuming you are using 500 FSB - I'm pretty sure there's not other way to achieve 2000 MHZ). Anyay, with very good custom water cooling and a strong CPU fan directly on the NB, I run 1.71~1.75 VNB @ 41c. Anything lower doesn't cut it and even with that much NB juice my X38 has a rough time with 500FSB. Anyone have any insight on that for us X38 peeps?
    Quote Originally Posted by pkour View Post
    Hi s7e9h3n,
    CPUvtt = 1.36V
    Vnb = 1.6V
    Vsb = 1.6V
    from this memory?
    CPU: E8500
    SEII with BIOS 704
    Watercooling system
    Jan 2006
    New Hampshire (USA)
    I've had the PC3-14400 version of this RAM for a few weeks now (got it back when the price was $300+) and I'm quite impressed with it! Does anyone know what IC's both my PC3-14400 kit and the newer PC3-16000 kits are using? I know you mentioned JNL dinos22 but I wasn't sure if you meant this kit was using them or not? Given how my kit compares to all the other GTR kits I've used I'm assuming my kit is GTR? Unfortunately I've not been able to verify this because removing this heatspreader is a bit more difficult than say removing Crucials or GSkills heatspreader? Whatever IC's this new kit is using the results are pretty decent, thanks for posting your work S7e9h3n. Oh yeah I'll second what BenchZowner mentioned, try flashing your S2E to a newer BIOS as both performance and some minor bugs have been sorted a bit!
    Asus Maximus III Formula (2001)
    Intel i7 860 (L924B516)
    Noctua D14
    Corsairs CMG4GX3M2A2000C2 (2 x 2GB) RAM
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    Creative X-Fi Titanium PCI-e
    LG GGC-H20L Blu-Ray
    Toughpower 850w Modular
    GSkill Phoenix Pro SSD 120GB
    HEAT
    Xtreme X.I.P.
    Aug 2004
    Chile
    nice price tag on the Kit
    If you ar going to try X48 use P5E3 Premium
    Mar 2005
    Pennsylvania
    I'm willing to bet my left nugget that the only difference in 4 products listed in the 1st post is the SPD/XMP code. I have the 1800 CAS 7 sticks and I'm sure that would (obviously) run at 1600 7 6 6 or 2000 9 9 9. I'll confirm tonight. With that said, it's probably best to buy the 1600. If you look at the specs as per manufacturer's website, it further supports this theory based on 'spec' voltages.
    DDR1600 7 6 6 1.9V
    DDR1800 7 7 7 2.0V
    DDR2000 9 9 9 1.9V
    That's exactly what I would expect to see if I was testing the same kit at different speeds. I'll find out tonight if my 1800 will do 2000 at 9 9 9 1.9V. I'm sure it will.
    Does anyone have any idea what would be other good latencies to try at 2000MHZ? Would 9 8 7 be decent... 9 7 7 ?? What are good combos to shoot for? I'd be willing to go as high as 2.1V, besides I doubt any more juice than that would help. These high freq Microns don't care for high volts. It just doesn't help above 2.1 in my experience.
    Phenom™
    Sep 2002
    Here's the only run that I tried on a P5E3 Premium when I first got the kit. I'll see if I can find some time to do some testing on the board:
    @ 1.9V:
    Jul 2007
    s7e9h3n what's the highest CAS6 you we're able to achieve?
    OT:s7e9h3n you work for AMD right?Due to your Phenom under your nickname
  18. #18
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by DMH View Post
    nah dude
    he is a fanboi though
    Team.AU
    Got tube?
    GIGABYTE Australia
  19. #19
    Xtreme X.I.P.
    Nov 2002
    Shipai
    nah dude
    says the king of fanbois
  20. #20
    Assistant Administrator systemviper's Avatar
    Nov 2007
    Newtown, CT
    So are you recommending them?
    HWbot - Team: XtremeSystems
    XS cruncher - Team: XtremeSystems
    OCN Feedback
    HEAT
    *** Being kind is sometimes better then being right.
  21. #21
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    The ProjectX sticks are priced fairly aggressively in the UK Over £120 cheaper than the equivalent Corsair kit
    This is crap of me- but the thing that puts me off this RAM is the **** **** name. ProjectX... WTF!
    you sigged that?
    why?
    ______
  22. #22
    Jun 2007
    Long Beach, CA
    Can someone confirm these arre the same memory stick? N E W E G G
  23. #23
    Jan 2006
    New Hampshire (USA)
    Yes Lu(ky, those are the same modules being discussed here, pretty decent price right!
    chris.y2k.r1 - Depending on how much voltage you feel comfortable running your sticks at you could try 8-7-6 or 7-7-7 if your willing to bump the voltage a bit? It might be best to try some timings a bit looser first and then work your way down, keep us posted on your progress.
    Noctua D14
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    LG GGC-H20L Blu-Ray
    HEAT
  24. #24
    Xtreme X.I.P.
    Nov 2002
    Shipai
    the only thing i'm a fanboi of is my son and daughter
    and their names are corsair and nvidia? heheheh jk man
    are you coming over to tai pei anytime soon btw?
    did you get a new 790 board from nvidia or evga?
    too bad you couldnt come to computex...
    sorry steve, enough OT
    ill check if i can find a set of this stt stuff and try it on our boards
  25. #25
    Xtreme Legend
    Mar 2005
    Australia
    Quote Originally Posted by saaya View Post
    i could not come because i'm too busy with work
    i got a replacement board >>benching this weekend with some new nvidia cards
    Team.AU
    Got tube?
    GIGABYTE Australia
