Asus P5K Premium SATA problems
I just got a Asus P5K premium Black Pearl edition, but I cant get it to work together with my raptor x hard drive. I know that the hard drive is fine, because it works with every other motherboard I have. When I start up the computer I get this message: " Detect drives, no any drives found". After this (before entering the bios) I get "No IDE Master H.D.D. Detected!"
When I try to boot from HD I get "error loading operative system". I first tried booting from a cd installing the OS on the harddrive, but I got the same messages every time. Then I tried installing the OS on the raptor x drive using another computer, and then boot from it on the P5K, but that didnt work either. I have flashed to the latest bios, I have tried every setting in the bios under the "Sata configuration" - section, but it wont boot no mather what I do it seems.
I can find the raptor drive in the list of sata devices in the bios, and I can boot from a IDE harddrive. When I use a IDE drive to boot from, I can find the raptor disc from the start menu in windows, and it works perfectly.
Have anybody had any similar problems? What do I have to do to fix it?
- You may not post replies
- You may not edit your posts
Forum Rules
