Results 1 to 16 of 16
Thread: HOWTO: Minimizing Vcores and Operating Temps-must read!
    Feb 2007
    Well, guys I wrote up this procedure I used to minimize my vcores on my new x3360/P35-based system, and I thought I'd share it with folks. It's a systematic method anyone can use to arrive at a minimized set of vcores for a given multiplier and FSB value. The examples I present in this post are using my X3360/P35-based system. The data aren’t made-up or fictitious for the examples; they are the real data I used to arrive at the stable system.
    Also, anyone can use this method - even if not overclocking their system - to lower their respective CPU and MB temps. I should say that I also incorporated this into my C2D/C2Q Overclocking Guide as well, but I felt it could also be useful to folks as a stand-alone post/guide.
    The goal of stress testing is two fold:
    1) To arrive at a stress test stable system (>24 hours with no prime95 errors).
    2) To minimize your vcores and thus minimize heat product both on your CPU but also on your NB/SB and other MB components.
    Prime95 will run and every now and then it will check the values it’s calculating using your processor to its internal standards since its torture testing using known values. Assuming you enable error checking, you’ll be notified if your values differ indicating an instability. This is why it is IMPERATIVE that you enable error checking within Prime95; again, if you don’t enable it, you WILL NOT be notified of errors!
    Do so simply by going to the “Advanced” menu and enabling “Round off Checking.” If the system isn’t stable, it will report an error and stop stressing the core that gave the error.
    Now that you picked your operating condition (i.e. 9x333 or 8.5x400, etc.) let’s stabilize the system through stressing it with prime95. Just so you get an idea what to look for, Coretemp as well as Prime95 (double-check that you enabled round off error checking) and run the Torture Test>Large FFTs. You’ll wanna keep an eye on your system temps to make sure they don’t exceed the redline so the chip doesn’t get throttled (assuming you have thermal management enabled in your BIOS). All your cores should get stressed equally (look in the task manager to verify):
    For your reference, here’s what an error from within prime95 looks like:
    When/if you get an error (and you will), you’ll need to either back off on the operating conditions (FSB or multiplier) or add some voltage to your vcores. Therein lies the challenge. Since you have four different vcores to select from, how do you know which one or which ones to adjust?
    It’s now time to minimize your vcore settings. Reboot and go into the BIOS’ section where you can control your CPU and MB voltages. Remember, different motherboard will call these variables different terms. The pic below is right out of my BIOS so you can see what DFI calls them, and what they mean:
    CPU VID Control – The processor vcore, I’m not sure why DFI calls it “CPU VID Control” but whatever. From here on out, I’m going to call it Vcc since technically, the term VID is an entirely different concept (see this document, page 14 for more if you have an interest).
    DRAM – The memory vcore.
    SBCore – Southbridge vcore (might be called ICH in your board).
    NBCore – Northbridge vcore (might be called MCH in your board).
    VTT – Reference voltage (might be called FSB Termination voltage in your board). It’s used to terminate data lines between the MCH and CPU.
    Some motherboards give the option for GLT reference controls. If you enable this you’re adding three additional variables to the mix and making your life more complicated. Unless you’re an extreme overclocker wanting to squeeze every single MHz out of your system, my advice is not to enable the GLT options. I’d also caution you not to enable this option since there is tons of misinformation out there about these undocumented features.
    If you must, here a few links that might help you understand how it works and give you some starting points, but I won’t be using them in this guide:
    Adjusting [Advanced] Gunning Transceiver Logic (A/GTL+) Voltage Levels for Increased Front Side Bus (FSB) Signaling Margins and Overclocking.
    DFI UT P35-T2R: Tweakers Rejoice!
    Good thread (kinda long) but good info.
    There are several approaches you can use to arrive at a stable, minimized set of vcores. I recommend that you start with lower vcore values and work your way up. Lower values will fail much faster than higher values thus making the process a bit quicker for you.
    To start with, select a set of vcores that are kinda low and see if you can POST. How do you know where to start? Use trial and error at this point unless you know someone else’s settings to use as starting points. When in doubt, I’d recommend that you start near the bottom of the scale. Here are some rough guidelines for setting your VTT:
    1.2-1.3V - for a FSB of ~400 MHz.
    1.4-1.5V – for a FSB of ~420-440 MHz (exceed 1.4V at your own risk with a 45nm chip)!
    1.6V – for a FSB of ~440-475 MHz - use at your own risk with a 45nm chip!
    You should be aware that newer 45nm fab chips are MUCH less tolerant toward high VTT than their 65nm predecessors. Anantech published their experience frying a QX9650 with high VTT’s as an example.
    Vcc – Initially, set within 200-400 mV of where the auto setting used (remember that you need a little more in the BIOS compared to what CPU-Z told you). Remember to consult Intel’s processor finder to know where the upper-end of safety is for your processor (I believe the figures there correspond to the values CPU-Z is displaying, not what you set in the BIOS.).
    DRAM – What ever the RAM manufacture recommends is a good starting point. Unless you’re really overdriving them, they shouldn’t need more.
    SBCore – I’ve always used the lowest setting, but I typically don’t push my systems that hard (20-25 %). You’re on your own here.
    NBCore – Start off low, 1.33 or 1.37 and see if you need more. Also, a little bit can go a long way. My system is unstable @ 1.330V here but stable @ 1.370V which is a difference of only 40 mV (0.04V).
    Here are the levels my Q6600 @ 9x333 uses to run stable:
    Code:
    Memory Voltage=2.100V
    CPU VCore=1.2625V
    FSB Termination=1.200V
    NB Vcore=1.25V
    SB Vcore=1.50V
    ICH Chipset=1.057V
    Here are the levels my X3360 @ 8.5x400 uses to run stable:
    Code:
    Vcc=1.12500V
    SB 1.05V=1.070V
    NB Core=1.370V
    SB Core/CPU PLL=1.550V
    CPU VTT=1.310V
    I show those only to give you an idea, not all hardware is the same, and really, those values are personal to my chip, RAM (and RAM settings), MB, etc.!
    Once you select a baseline set, that will complete a POST, you’ll want to start a more vigorous evaluation by changing the MB vcores one-at-a-time moving forward. If you change too many variables at once, you’ll never be able to arrive at the stable settings. Confused? Don’t be, just read on and after you see the examples, I think the process will seem clearer to you.
    The basic process is to try different Vcc values keeping the other vcores constant. Run p95 at a given Vcc and record what happens after an arbitrary time point (10 to 15 min is good to start with). If Vcc level is stable for 15 min of p95, reboot and lower it a little and repeat. The goal is to find the minimum level that gives errors, then increase it until it’s stable, then extend that time out to say 2-4 h. If it’s still stable, further extend it to 10-14 h. You can probably call it “stable” if you can run p95 for 24 h. If a setting fails after 4 h, increase it one notch or so and repeat until it’s stable out to 24 h. You can then come back knowing this Vcc and try to lower one of the other vcores repeating the process. Yes, it’s time consuming and yes, it’s tedious, and yes, that’s a load of rebooting, but it works.
    The key to this process is keeping a detailed record to help you achieve a stable system and troubleshoot which vcore to change – p95 errors are NOT always the fault of a low Vcc! Without these data, you’ll have a tough time. So what do you keep track of here?
    1) The MB vcores you’re using
    2) The Vcc values you’re testing
    3) Which core failed (prime95 tells you) and how long it took to fail
    4) Any observations or comments you want to record for yourself
    Here is an example minimizing vcores using my X3360/P35-based system. The data presented aren’t fabricated to help illustrate the method; rather, they are the real data I used to arrive at the stable system.
    Hardware specs for your reference:
    X3360 running @ 8.5x400, DFI LT P35-T2R (BIOS 3/17/2008), Ultra-120 Extreme, Corsair TWIN2X4096-8500C5DF 2x2 GB @5-5-5-15 running @ 960 MHz (5:6), 620HX power supply.
    Before we dig into the examples, know that to really really do this right, you’d need to do several runs at the various levels; doing it just once as I am is the quick ‘n dirty approach and can cause you to draw an incorrect conclusion or two as you will see.
    On to it: in my first try, I set up my MB vcores and began testing Vcc starting low (I chose 1.12500V somewhat arbitrarily).
    Keeping the motherboard vcores constant, I varied the Vcc starting out low and working up high. You may or may not get a stable system on your first set of iterations (probably not actually). If you do, you’ll probably want to repeat keeping your stable Vcc but optimizing (minimizing) for one of the other vcores such as NB or VTT, etc.
    Code:
    Overclocking log, Iteration Set 1
    Comments: Initial try
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    VTT	1.200V
    Vcc/Prime95 success or failure
    1.12500V	Failed on core 3 ~ 5 min
    1.13750V	Failed on core 0 ~ 28 min
    1.15000V	Failed on core 2 ~1 h 18 min
    1.16250V	Failed on core 1 ~ 4 h 4 min
    Looking at the data, we see there that multiple cores have failed as I increased the Vcc. That’s suggestive of one of the other voltages lacking and thus needing to be increased. There are two likely causes for my instability: NBCore and VTT. In my next Iteration set (below), I chose to raise the NBCore several notches keeping the rest of the MB vcores constant.
    For discussion’s sake, let’s say the same core failed repeatedly. This scenario is [i]likely]/i] caused by a low Vcc (although it doesn’t have to be). For you quad core users, cores 0/1 and cores 2/3 should be treated the same, so if you get some core 0 and core 1 failures, treat them like a single core failure as you consider this analysis.
    So, I increased the NBCore a few notches and tried a few higher Vcc settings just to see if it was enough:
    Code:
    Overclocking log, Iteration Set 2
    Comments: Added some NBCore
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.41V
    VTT	1.200V
    1.16250V	Failed on core 2 ~2 min
    1.17500V 	Failed on core 1 ~3 min
    Again, I got two quick failures across the entire chip. Ideally, you might want to collect more data points, but I took a hunch that 1.45V should be plenty for 8.5x400, and next added some VTT keeping the newer, higher NBCore constant – remember to only change one of them per iteration set!
    Code:
    Overclocking log, Iteration Set 3
    Comments: Added some VTT and kept the higher NBCore
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.41V
    VTT	1.310V
    1.17500V	STABLE 15 min
    1.16250V	STABLE 15 min
    1.15000V	STABLE 15 min
    Now, with the higher VTT, I didn’t get a single failure for at least 15 min at the three Vcc values I ran. I concluded that the VTT gave me the stability. To test this hypothesis, I kept the higher VTT, but lowered the NBCore back to 1.37 and repeated in the 4th iteration:
    Code:
    Overclocking log, Iteration Set 4
    Comments: Kept the VTT, lowered the NBCore
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    VTT	1.310V
    1.15000V	STABLE 2 h
    1.13750V	STABLE 30 min
    1.12500V	STABLE 1 h
    1.07500V	crashed p95 (n=2)
    1.09375V	crashed p95 (n=1)
    1.10625V	BSoD after 1+h
    1.11875V	STABLE 11 h
    1.11250V	Failed on core 0 ~ 1 h 8 min
    Now I got some stable runs. After evaluating the data, I was able to nail down both my NB and VTT in only 3 iteration sets, arriving at what I thought was the stable Vcc in the 4th (I was later wrong).
    It’s a little easier to visualize if you sort the Vcc from low to high. If you keep your log in a spreadsheet, you can easily sort them, here are the same data sorted by Vcc:
    Code:
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    VTT	1.310V
    1.07500V	crashed p95-program exited (n=2)
    1.09375V	crashed p95-program exited (n=1)
    1.10625V	BSoD after 1 h
    1.12500V	STABLE 1 h
    1.15000V	STABLE 2 h
    It would seem as though 1.11875V was the winner. I could have stopped right here and repeated extending the time out to 24+ h with these settings, but I elected to further optimize and targeted the VTT since I thought I could do better having jumped from 1.20 to 1.31 and skipping 5 sub levels in the process. This time through, I held the Vcc constant and varied, VTT:
    Code:
    Overclocking log, Iteration Set 5
    Comments: 1.11875V seemed stable, minimizing VTT
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    Vcc	1.11875V
    VTT/Prime95 success or failure
    1.250V	Failed on core 0 ~ 2 h
    1.260V	Failed on core 2 ~ 1 h 20 min
    1.280V	Failed on core 0 ~ 18 h 22 min
    1.310V	Failed on core 1 ~ 1 h 20 min
    This one is a little puzzling since the 3rd run (VTT=1.280V) lasted for over 18 h, yet the 4th run with a higher VTT died in under 1-1/2 h. My thinking was that VTT wasn’t the problem, and that I had been mislead on the Vcc. I was also getting a little anxious for this to be finished and I broke my own cardinal rule for the next iteration set by upping two variables at once: Vcc to 1.12500V and VTT to 1.310V.
    Code:
    Overclocking log, Iteration Set 6
    Comments: 1.11875V seemed flaky, so upped the Vcc and kept the higher VTT.
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    VTT	1.310V
    1.125000V	Stable 21 h 34 min
    Okay! So maybe it was the Vcc after all since it ran for over 21-1/2 h before I stopped it. You could argue that there’s no difference between 18-1/2 h and 21-1/2 h and you would have a valid argument. This underscores the need to collect multiple data point per level as I mentioned in the beginning of this section (I told you it was quick ‘n dirty)!
    Finally, I set out to essentially repeat my Iteration Set 5 minimizing the VTT with the slightly higher Vcc.
    Code:
    Overclocking log, Iteration Set 7
    Comments: 1.12500V seemed stable, minimizing VTT
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    Vcc	1.12500V
    1.250V	Failed on core 0 ~ 1 h 3 min
    1.280V	Failed on core 1 ~ 1 h 0 min
    1.310V	Stable 34 h 41 min
    Apparently VTT needs to be 1.310V on this system. In any case, those examples should serve to illustrate the method you need to use to attack the task.
    To summarize, using a stepwise approach and documenting your runs, you should be able to arrive at a stable system (assuming your hardware can operate at the level you choice). It probably goes without saying that you will need to repeat this process if change your operating conditions (multiplier and FSB).
    Oct 2007
    Nice initiative, but I have to disagree on the base of validating stability.
    You're the only one stating to use Prime95 Large FFT as an overclock stability test for BOTH CPU and MB settings
    Prime95 in small FFT mode is the way to go for CPU testing (eventually OCCT 2.x in CPU mode as it uses now same Prime95 small FFT algorithm with just one more larger block size 64kb max instead of 32kb I think)
    For testing your stability, including RAM and motherboard settings Prime95 in large FFT or Blend is a mess. Even anandtech, now uses OCCT in RAM mode as it is the only real stress application that can reproduce some in-game or F@H errors related to high FSB/RAM especially on quadcore CPUs
    Finally, on high FSB overclocks, with loadline calibration enabled especially, you can have random rare hang-ups during boot procedure while being stable on all benchmarks. This is because system power load is usually maximized few seconds during the boot procedure of system with initialization of all hardware.
    In my point of view, your method can be said to be ok (even, as you noted it, for extreme overclocks the settings you detail are too limited) except for the tools to validate the stability. At least, Prime95 + OCCT in RAM mode must be used in a first time, than, in a second time, a validation using suites of real applications like PCMark and eventually 3DMark in some loops must be completed for final stability
    Q6600 G0 L740B126 Lapped, 2x1Gb Kingston HyperX DDR2-1200
    Gigabyte 8800 GTS 512Mb OC 756-1890-1000
    TT Toughpower 750 W (W0116) new 8xPCI-E Rev.
    Western Digital Caviar SE16 WD6400 AAKS rocks
    WC: Swiftech H2O-Apex Ultra 220 GT + PA120.3 5v
    OCZ XTC RAM Cooler, HR-05 IFX + 80mm FAN (NB), 2x HR-09U type 2 (mosfets), Modded Zalman ZM NB-47J (SB), Arctic-Cooling MX-2
    Vista 32 bits
    - ASUS P5K Premium bios 0612: (3.84GHz 8x480) @1.432v
    - P5B Deluxe: 3.60GHz (9x400) @1.33v *** Old Setup (P5B deluxe)
    OCCT 2.x Final Download
    Xtreme Legend
    Mar 2005
    Australia
    Gentlement
    THIS IS OVERCLOCKING 101
    i used to have a lot of notepads like this
    now i rely on bios save profiles and small tweaks like you said until i get the right mix of voltages/settings
    i also use this same method for my 24/7 machine
    hats off to you man.....i could never put this into words but i've been using this kinda method for a long time myself
    Team.AU
    Got tube?
    GIGABYTE Australia
    Oct 2007
    Japan
    My system can pass 24 hours small FFT and blend test but will automatically restart after few hours using large FFT. Anyone knows which voltage should I raise?
    Core i7 920
    Scythe Mugen 2
    Silicon Power DDR3-1333 2GBx3
    Gigabyte EX58-UD4
    Palit GTX 260 Sonic 896MB
    Samsung Spinpoint F1 640GBx2 Matrix RAID
    Samsung Spinpoint F2 1TB
    Creative Audigy 2 ZS
    Winfast TV2000 XP Expert
    Antec Earthwatts 650W
    Coolermaster CM 690
    LG W2442PA
    Win 7 RC x64
    Xtreme Guru
    Jul 2004
    very informative . Nice post!
    Feb 2007
    Thanks again to all for the kind words!
    Quote Originally Posted by wyemarn View Post
    @wyemarn - you gotta give us some idea what we're dealing with here... what brand memory, MB, and CPU? What settings are you using (CPU and mem timings, overall mem speed, vcores, etc.) and mb vocres.
    Mar 2005
    Pennsylvania
    Warm boots are almost always a RAM issue. You could try VDIM but that's not the only thing that will help stabilize memory. If you don't know where else to go then try VDIMM but be careful. Memory is easy to cook with volts.
    My Micron D9JNL's don't like high volts at all. I usually LOWER the voltage to get them stable when changing settings. But thats D9s and DDR3. You've got DDR2... and I didn't notice what kind.
    And yes... nice post. I also agree however with the vote for OCCT.. I can run Prime forever but OCCT will crack my nut almost immediately if it's a little off. Damn those Russian programmers!!
    Daily Desktop Custom Built - Modified Data General Server Case
    Asus M4A79T Deluxe | 955BE C2 Rev | 4GB OCZ DDR 2000 @ 1600 6 5 6 1T | 4850x2 + 4850 w/MCW60 | CPU on H20 w/ Enzo Sapphire l Custom Built Pump and Res Combo 1/2 Gallon! | 4 Swiftech 320mm Rads with 6 All Aluminum Delta Fans with their own PSU - Finger Loppers - for real!
    Literally, CPU&GPUs are almost always at ambient therefore heat ain't limiting sh|t.
    Mar 2007
    Cool guide.
    Just a note - Isn't any VTT over 1.15v out of range from the intel spec for 45nm? I find that if I adjust GTL settings properly I never need more than 1.13vtt to be several hours stable at 4.25ghz+ with only 1.325 vcore.
    Sep 2005
    Quote Originally Posted by graysky View Post
    That's definitely not right, as example I am running 8x 450 with FSB Termination voltage on 1.2V (The lowest setting available in bios)
    Now, you consider passing 21h of prime small FFT's as stable and its totally wrong. I can pass 20 hours of small FFT's but fail within minutes on BLEND
    CPU: Intel Q6600 G0 @ 3.6 Ghz 1.272V
    HEATSINK: Thermalright Ultra-120 eXtreme push/pull 120mm @ Lapped
    MB: Asus Maximus Formula
    Memory: OCZ DDR2-1066 4GB Kit ReaperHPC @ 1081
    GFX: EVGA 8800 GTS (G92) 770/1900/1150
    SFX: Creative X-Fi ExtremeMusic
    SPEAKERS: Creative GigaWorks G500 5.1
    HDD: 2x Segate 320GB 7200/16MB SATA2 RAID 0
    HDD2: 1x WDC 160GB 7200/8MB ATA
    POWER: Toughpower 750 Watt
    OPTICAL: LG DVD-RW x16
    PC CASE: Thermaltake Armor+ / ALU / 5x 140mm intake / 1x 140-120mm exhaust
    3Dmark06 17178
    Feb 2006
    Potosi, Missouri
    The term CPU VID Control is used as the result is a direct manipulation of the VID Select pins. Similar to the manipulation of BSEL when using the onboard jumper block in conjunction with the Clock VCO Divider setting.
    Not sure why GTLREF would be termed undocumented. It's a basic principle used in all types of signaling circuits. It was in use long before Intel decided to implement it. If the goal is a stable overclock using the least amount of voltage proper tuning of GTLREF voltages is a necessity.
    Aug 2007
    Belgium
    Thanks for this topic, really helpfull without any comment and even more with it
    DiKKeneK fan !!
    I am Xtreme
    Feb 2003
    Netherlands
    Very nice write up.
    FSB termination voltage and NB voltage are the ones that needed altering on my setup to get it fully stable, i also messed with GTL voltage and it seemed to help.
    I'm running a P35 chipset with a Wolfdale CPU, i think different chipsets might need other voltages to be altered though.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Feb 2007
    Quote Originally Posted by sesion View Post
    Dunno what to tell ya... have a look at the source.
    Mar 2007
    I think that article was written with 65nm quads in mind. The new 45nm chips are sensitive to high vtt.
    Feb 2007
    @mrcape - yeah I made reference to that in the 1st post.
    Oct 2007
    Quote Originally Posted by chris.y2k.r1 View Post
    OCCT has nothing Russian, but the name maybe. It is a french programmer
    I fully agree. Look at my signature with my stable 3.8GHz 8x475 on a Q6600 (65nm). My vFSB is 1.20 only. Many people could get low vFSB too on high FSB and Q6600. Some people need lots of vFSB, but it could be quality of signal in MB, mis-configuration of the Ref volt, high memory frequency with tight TRFC and subtimings, too low vNB...
    The VTT is needed to terminate the data between CPU and MCH if I'm not wrong, so many factors can lead to fluctuations.
    I prefer tweaking NB, RAM, GTL Ref than using a 1.6v on the vFSB side. That's reall too much and can kill even a 65nm chip (33% out of intel specs)
    Vista 32 bits
