Results 1 to 25 of 1415
Thread: **Unified** DFI LanParty UT 790FX-M2R-M2RS / Phenom /Data Base Thread**
Threaded View
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    Bios's - Drivers - Manuals - Specifications.
    Official Bios Releases:
    Date Code: 2008/1/30
    R7LD130_u.zip
    Major Reasons of Change:
    1、Improved DRAM compatibility for OC function.
    2、Add DDR2-1066 MCT timing Select.
    Remark :This new update BIOS(2008/01/30) comes with some new features such as “DDR Timing Mode”, therefore the existing CMOS Reloaded setting stored on your motherboard cannot apply to this new update BIOS. Users will need to manually set your overclock setting to this update BIOS and save those setting in CMOS Reloaded to work with this new update BIOS.
    2008/1/30 BIOS updates ATI RAID ROM to version 3.1540.21., since the RAID ROM is changed in this 12/11 Beta BIOS, please download the new RAID Driver790FX_RAID_F6.ZIP , and use this new version instead of the previous version on Driver CD.
    Date Code: 2008/03/07
    R7LD307.zip
    Update ATI RAID ROM to 3.0.1540.30
    Date Code 2008/04/16
    R7LD416.zip
    1.Increase CPU voltage control step by step.
    2.Add CPU Voltage Item help string.
    3. Fixed “CPU Clock Ratio” item issue for PHENOM CPU.
    4. Fixed smoe CPU temperature show error.
    Beta Bios Releases:
    The BIOS in this section are Beta and still under evaluation. Please be advised that warranty will be voided for any damages caused by these BIOS on your system and DFI is not liable for such damages.
    The Beta's are here for reference and maybe added to or removed based on what is currently on DFI's Global Web Site.
    Date Code: 2008/04/15
    R7LD415.zip
    1. Fixed “CPU Clock Ratio” item issue for PHENOM CPU.
    2. Fixed some CPU temperature show error.
    3. Added cpu OV warning message.
    Date Code: 2008/04/16
    R7LD416.zip
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
