My New Build Lian-Li v1200
My old case
This build is replacing my 6 month old Antec 900 w/ the Thermaltake Big Water Cooling System... I'm not a photographer so my pictures will be limited..
As you can see my window broke
I guess something heavy was placed on it while it was being shipped..
This shows you how lazy I am... When I printed out the template it scaled down, and I used those measurements for my initial markings... Instead of replacing the tape I re-measured, and marked over my old lines... Worked for me... Wow took 6 dremel disk to cut that hole - Took about 2 hours to cut & smooth all of the edges...
As you can see I installed a Koolance heat exchanger on the top of my case… I like the way it looks and I would have had a few issues if both the fans / rads were on the inside of the case (I’m going to replace the radiator later)… I also installed an additional radiator beside the hard drive tray… OOoo and it takes a very long time to polish aluminum – It took about 4 hrs to hand polish it... That dull finish looked terrible IMO… Well that’s about it for now… I’m waiting for all of my other parts to arrive… (Extra barbs, fans/controller, thermal paste, EK CPU back plate, ECT…) Damn I spent $1200 on this upgrade which included my Case, DDR3 Ram kit, pump, res, and so on…
I guess I’ll spend a few days trying to decide where to place my tubing…
Windows 7 64 Bit
BenQ FP241W Black 24" LCD
Mountain Mod Case w/ Base
Asus Rampage III Black Edition
i9-990x @ 4.58GHz - 1.36v Temps (Idle 23C - Load 48C)
12GB Corsiar Dominator GT (PC3 15000) @ 9-9-9-24 1T - 1.65v
Sapphire 5870 x3 "OC" w/ EK Water Block Temps (25C-49C)
EK-Supreme / 4 Alphacool Laing DDC-Pump Ultras + Extras
Power Supply / 2x Silver Stone DX1000
Western Digital 1.0TB x 3
Crosair SSD 128GB x 2
World Community Grid!
- You may not post replies
- You may not edit your posts
Forum Rules
