Page 1 of 41 123411 ... LastLast
Results 1 to 25 of 1135
Thread: Asus P5E3 Premium Wi-fi-AP
Hybrid View
    Xtreme X.I.P.
    Aug 2004
    Chile
    I got this board on friday but i had to travel today i installed windows and started playing with it.
    Any one else has this board? AFAIK is the only X48 from Asus with support for DDR3 2000Hz, with 3 Power Phases for the memory
    2 Phase chipset regulation + Clockgen
    3 Phase Memory Regulation
    Old School jumper Overclock (Gets you more Volts)
    Blue SB
    DDR3 2000MHz 1.8v really easy
    If anyone can help me get a SetFSB with support for this clockgen would be great
    Will update more soon
    Xtreme X.I.P.
    Nov 2002
    Shipai
    wow, very nice!
    strange, so far 2 people told me their premium boards didnt perform very well at all... is this a board asus sent you or did you buy it?
    Do you know if its handpicked?
    What Vmch are you using for 2ghz?
    What voltages do the Jumpers enable?
    Oct 2007
    I am glad someone has now setup a thread specifically for this board. I was going to do it, but you saved me the trouble thankyou to Metro. Good luck with your board.
    System:
    Asus P8P67 Deluxe 2600K 4.8Ghz 5970 4GB Corsiar GT 2000 Areca 1880i & Corsair F40 and 2 Intel 80 Watercooled DDC 120.3
    Xtreme X.I.P.
    Aug 2004
    Chile
    Quote Originally Posted by saaya View Post
    wow, very nice!
    Asus sent it to me, for a CHW review i'm doing the CellShock review first to get a feeling of the board, dont think is cherry picked they only told me if the memory is right the board can do 2100MHz, i think i will get further
    This are the Boot settings, all from BIOS
    And the result:
    Quote Originally Posted by DeViTTo View Post
    Yeah the board seem really sweet, all of this results are with a 24/7 config, antivirus, wi-fi conection, etc...
    May 2004
    Subscribed...
    Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
    Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
    Asus MA378-T with AMD Athlon 64 X2 7850
    ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
    BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
    Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
    Xtreme Legend
    Mar 2005
    Australia
    nice board
    and nice RAM clocking there
    bump the volts and let's see some 1100+ action
    that TRFC is really hurting the superpi times lol
    Team.AU
    Got tube?
    GIGABYTE Australia
    Xtreme X.I.P.
    Aug 2004
    Chile
    Quote Originally Posted by dinos22 View Post
    nice board
    yeah according to Sayaa the SPD is not set for this timings, so the bios is setting whatever it wants tomorrow i'll test more hopefully 1100+ if my cpu can go that high fsb wise.
    I'll also try to tighten the timings
    Regards
    Nov 2004
    guys, i'm using this board as well .. well i wonder what's the safe value for cpu pll? coz i've read somewhere that over 1.6v will make ur cpu degrade very fast, or it might even kill the proc.. issit true?
    last time i was with gigabyte p35t dq6 so there's no this option..
    Intel Core i7 870,
    MSI P55 GD65,
    4x 2048mb DDR3 1600 Corsair Dominator,
    Sapphire 5870,
    Corsair HX850W,
    2x 640GB WD sata II,
    1x 1TB WD Sata III,
    Xtreme X.I.P.
    Nov 2002
    Shipai
    with the right mem AND the right cpu
    for 2200 you need 550fsb, i dont think there are any quads that can do this stable
    irenic, im running 1.9v pll voltage for 3 months without any issues.
    Nov 2004
    thx saaya.. there're lots of things i need to learn regarding this board.. so i subscribed to this thread!
    Intel Core i7 870,
    MSI P55 GD65,
    Sapphire 5870,
    Corsair HX850W,
    1x 1TB WD Sata III,
    Dec 2006
    Falkenberg, Sweden
    That´s some a VERY good kit of DDR3 there Metro.cl Will follow this theread closly! Also got a board not to long ago, but I have not hade time to play with it much yet
    memset reads wrong, it´s 2000mhz...
    http://s30.photobucket.com/albums/c3...t=8-7-6-20.gif
    EDIT: Have you noticed any diffrens between black and orange mem slots in terms of OC?
    AMD
    955BE, 720BE & Athlon II 250
    Gigabyte 790FXT-UD5P F5 Bios
    Crucial Value 2*1Gb D9 JNM
    XFX 4770
    Seventeam 650w
    Mar 2008
    Finally a thread dedicated to this mobo. Will post results.
    Intel i5 2550k @ 4.5
    Asus P8Z68-V Pro/Gen 3
    MSI 7950 Twin Frozr III 1050/1450
    Crucial Elite (4x4GB) 16GB 1866
    Crucial M4 512GB
    Seagate 7200.12 1TB HD
    CNPS11X Extreme Cooler
    Seasonic Platinum 860W
    Lian-Li PC-B25FWB/ Lian-Li PT-FN04 Fan Controller
    Plextor PX-L890SA
    Samsung S27A950D 120Hz
    Windows 8 RTM 64-bit
    Apr 2008
    Question
    I have that board along with an Intel Q9450 w/ 4GB of OCZ3P1800. My issue is this, I can neither boot all 4GBs without having it freeze on me, nor can I slightly OC it [not even to 1600FSB]. I have imaged two different Raptor X drives with Vista 64 and XP 64; switched the RAM into other slots and everything, but the freezing keeps happening. What do you guys think is the issue here? I'm blaming the board, because on top of all that it does not even boot into nor show me the Express Gate feature. I called in an RMA already, but since I'm getting the same board again I would like to get some feddback as what I could be doing wrong. Thanks for your time.
    Apr 2008
    Hi Guys,
    anybody else having problems (or not) with the P5E3 Premium Wifi (Bios 0204) and the ASUS EN9800GX2 Graphics card? I am getting no video signal at all from this card...(standard PCIE cheap graphics is fine!).
    I have noticed there are BIOS updates 0401 for the P5E3 Premium (no Wifi) which allege improved VGA compatibility but that is for a "different" board - nothing for the P5E3 Premium Wifi beyond 0204 (anyone running 0401 on a Wifi edition Mobo or know if it is compatible?).
    I am at the point of RMAing the graphics card.
    Any suggestions appreciated.
    Regards and Thanks!
    May 2004
    Quote Originally Posted by Fatron View Post
    Hi Guys,
    Regards and Thanks!
    I believe 0401 is for both. I flashed mine without any problem. In fact, I haven't seen the the non-Wifi anywhere, does it even exist?
    Nov 2005
    Porto, Portugal
    Hi Guys,
    Regards and Thanks!
    You have to connect to the DVI I/O nš1. On my Asus GX2 it's the one next to the HDMI I/O, if i connect to the DVI I/O nš2 there's no video signal when i startup the system.
    Windows 7 Ultimate 64bit, SP1 Power By:
    Asus Rampage IV Formula
    Intel SBE 3930K
    Gskill RipJaws Z 14900 (1866 DDR3) 16GB 10-11-10-24
    EVGA 570 GTX SLI
    SSD Samsung P830 240GB
    Corsair AX850
    Apr 2008
    Thanks JohnMike - unfortunately already tried both to no avail! Either an MB incompatibility or a GFX card issue I fear! I am RMAing the GFX card now and will see what transpires!
    If anyone else has P5E3 Premium and ASUS EN9800GX2 - I'd appreciate their experiences....Thanks!
  18. #18
    silver wall jumper X
    Apr 2005
    Las Vegas
    Hi Guys,
    Regards and Thanks!
    Did you try both VGA ports?
    I am having trouble with 9800GX2 performance - only been doing 01 nature but I am taking a huge FPS hit compared to a 790I board. Seems like the PCI-E bandwidth is somehow limited since rasing PCI-E frequencies gives a big boost in FPS.
    ANyone has similar problems?
  19. #19
    Nov 2004
    maybe gx2 also faced the same problem like 3870x2..
    i'm using x2 and i need to disable the expressgate in the bios..
    Intel Core i7 870,
    MSI P55 GD65,
    Sapphire 5870,
    Corsair HX850W,
    1x 1TB WD Sata III,
  20. #20
    Sep 2005
    Stoke on Trent, England
    I have this motherboard but never got round to using it, and now its in for sale thread
    Board: DFI LanParty UT X58-T3eH8 (2009-02-17)
    CPU: Intel Core i7-920 Batch:3835A799
    RAM: Corsair TR3X6G1866C9DF 3x2GB Dominator 9-9-9-24 1866 1.65V Triple Channel
    GPU: ATI Radeon HD 4870 X2
    Sound: onboard
    HDD: 3x30GB OCZ Vertex RAID0 , 2X300GB VelociRaptor RAID0
    DVD: Samsung SATA DVD/RW
    PSU: Thermaltake 1200W
    OS: Vista x64 SP1
  21. #21
    Apr 2008
    Angry
    Thanks both - already tried expressgate disabled to no avail!
    Flashed 0401 and no change - still no video signal!
    Looks like an RMA!
  22. #22
    Nov 2004
    too bad .. well the same case happened to my friend.. new board and no display.. just the board is el cheapo biostar p35..
    Intel Core i7 870,
    MSI P55 GD65,
    Sapphire 5870,
    Corsair HX850W,
    1x 1TB WD Sata III,
  23. #23
    Xtreme X.I.P.
    Aug 2004
    Chile
    I had 30 mins last night to play (been really busy at work) and i'm FSB limited, my CPU sucks FSB wise, i'll flash to the newer BIOS and try again maybe y can get to 540-550FSB.
  24. #24
    Mar 2008
    TX
    I have this motherboard, but i have a problem. Everytime i save settings like voltage or timmings and exit from the BIOS for restart, it just turns off and then after like 2 seconds it turns on again, is this normal?
  25. #25
    Xtreme X.I.P.
    Aug 2004
    Chile
    Quote Originally Posted by gbsx View Post
    Which BIOS? i only get that if the memory divider changes (normal for Asus from what i know).
