Results 1 to 10 of 10
Thread: New to W/C... Swiftech Compact 120???
    Feb 2007
    Norman, Oklahoma
    hey guys =P... i have been looking at water cooling for a while now and i have been afraid of messing something up and ruining my computer (like a spill or something >.< ) lol... the main thing i want to know is what you guys think of this kit Swiftech compact 120 ... it sells for around 100 dollars and i was looking at it as a way for a noob like me to get introduced to water cooling... will i see any real big difference in temperatures between it and my current cooling with an asus arctic square (lapped processor and AS5) and good airflow with 2 thermaltake 120mm's at 94 CFM... my idle temps sit around 28-30 at 3.45-3.5 ghz with a 6400+ BE. what kind of temperatures should i expect and also would it be adequate for a phenom 9850 BE? thanks guys!
    [MOB] AM3 Asus M4A79T Deluxe
    [GPU] ATI HD 5870 1gb 925 mhz
    [RAM] OCZ Reaper 4gb 1600 mhz
    [CPU] AMD Phenom II 965 4.0 ghz
    "What doesn't kill you, only postpones the inevitable..."
    Water Cooled Apevia X-Plorer | Custom Window | Lapped Phenom II 955 | Lapped Phenom 9850
    Mar 2006
    Los Angeles CA
    You probably won't see any performance increase switching to that kit in regards to idle temps.
    Water cooling only starts to outshine high end air coolers when it comes to overclocked cpu's under load.
    Theres also the silence factor to be considered.
    -aspire
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
    Feb 2007
    Norman, Oklahoma
    well thats more what im interested in, i plan on getting a 9850 and clocking it up to around 3.0ghz and i want a w/c system that can handle that.
    Mar 2006
    Los Angeles CA
    Consider the 240mm version of that kit instead then. That might be better suited to the quad core.
    Feb 2007
    Norman, Oklahoma
    well, the thing is... that 120 will fit PERFECTLY in my case (i have a midtower apevia case) i am very limited on how far i can go with water cooling because of my case size and i really dont want to replace it (weve grown quite attatched =P)
    Mar 2006
    Los Angeles CA
    My first case was an aspire x-infinity and aspire later changed their name is apevia. Hence my s.n.
    Anywho, for the time being your probably better off sticking with air cooling.
    Nov 2007
    COLORADO
    agreed. just get a nice TRUE or IFX and you'll see some nice temps even with a semi low flow fan.
    Xtreme Cruncher
    Feb 2008
    C:\WINDOWS\system32\
    You could get the 240 version and mount the radiator externally if space was an issue. Otherwise, I'd just stick to air until you get a bigger case.
    Banned
    Aug 2007
    C:\Philippines\TPC
    so can the 240 version be at par or better than the TRUE on OC load?
    Oct 2006
    Sweden
    If you're gonna start with WC, do it right from the beginning. I don't want to be harsch on you, but honestly, that kit is probably just crap and you would probably be better of with a TRUE, there really is no shortcuts. If you would wanna get some decent temps to that cpu, I recommend you to consider a PA120.2, a DDC 3.2 or a D5 vario, a fusion block with quad nozzle and maybe a res or you can simply go with a T-line.
