Results 1 to 25 of 59
Thread: Maximus Extreme + Zalman GT1000 tri-loop setup - picture heavy
Threaded View
    Feb 2008
    Well, here's my take on watercooling the maximus extreme. First of all, I did get decent temps using a Reserator XT with the stock fusion block chipset cooler. However, I decided after all to go all the way and replace this with custom blocks and radiators. So I'll start with a review of the components:
    Zalman "Z-Machine" GT1000
    4-5mm thick aluminum walls, tool-free HDD cage, supports up to 6 HHDs and 7 expansion slots
    Laing DDC Ultra
    4,7m head, 600L/h, 110 ml plexiglass reservoir
    EK-Supreme CPU block
    EK-NB S-Max
    EK-SB Max-Ex (SB/crosslinX block)
    EK-Mosfet ASUS 3a
    EK-FC3870 X2 (GFX cooler)
    Zalman Reserator XT
    120mm Papst 4412 F/2M
    2400 rpm, 140 m3/h, 38dBA
    Three types of tubing:
    1) ClearFlex60 19/13mm (1/2") for CPU loop
    2) Tygon R3603 11/8mm (5/16") for chipset/GFX loops
    3) ClearFlex60 12,7/9,5mm (3/8") for bringing CPU loop out of case to the radiator - see next post
    For other hardware - check signature.
    Rig #1: Maximus Extreme X38 BIOS 0904 | Intel Q6600 rev. G0 @ FSB450*9=4050MHz Vcore=1.575 V_NB=1.61 V_FSB=1.54 | 2x 1GB Corsair Dominator DDR3-14400 1800MHz @ 7-7-7-20-1T V_DIMM=2.06 | 4x WD Raptor 36GB 10000RPM in RAID0 | 1x Samsung SpinPoint T166 250GB 7200RPM | 2x Radeon HD 3870X2 CrossfireX | Thermaltake Toughpower 1200W | Case: Zalman GT1000 | CPU cooling: EK-Supreme + Laing DDC Ultra + PA 120.3 | Chipset cooling: EK blocks + Zalman Reserator XT | GFX cooling: EK-FC3870 X2 + Laing DDC Ultra + PA120.2 | Vista Ultimate 32bit SP1 | 3DMark06: 20116 | Build log
    Rig #2: Asus Striker II Formula 780i BIOS 0902 | Intel E6600 rev. B2 @ FSB400*9=3600MHz Vcore=1.40 V_NB=1.32 | 2x 1GB Corsair Dominator DDR2-8500 1066MHz @ 4-4-4-15 V_DIMM=2.20 | 1x Western Digital Raptor X 150GB 10000RPM | 3x XFX 8800GTX in 3-SLI OC to 650/1000 | Thermaltake Toughpower 1200W | Case: Thermaltake Armor | CPU cooling: Swiftech Apogee GTX + Swiftech MCP655 + PA120.2 | GPU cooling: Zalman ZM-GWB8800 GTX/Ultra + Zalman Reserator 1 Plus | Vista Home Premium 32bit SP1 | 3DMark06: 15223 | Build log
    Rig #3 (HTPC): Asus P5K Premium/Wifi-AP P35 | Intel E6550 @ stock | 2x 1GB Corsair DDR2-6400 800MHz | 1x Samsung SpinPoint T166 250GB 7200RPM | XFX 8600GTS | Corsair HX620W | Vista Home Premium 32bit | Case: Silverstone SST-LC20B | CPU cooling: Zalman CNPS9500 LED | Vista Home Premium 32bit
