Hi guys
i would like to start this topic to get all these mods confirmed first of all but ppl here that are more experienced. i've worked with simon (oohms) on these but because he didn't have the board on his and pics only these mods may not be correct. Vince found a droop mod but i could not get it working with a pencil mod
i need to solder a 50K VR and check it (that's basically the only mod i'll need as bios has all the options i need)
actually maybe the DDR3 VTT mod may be useful if we can get it confirmed
WARNING: UNCONFIRMED MODS. IN TESTING STAGE AT THE MOMENT
I'll ask Simon to chime in what feedback he requires as i am not trusting my multimeter for resistance readings
DDR3 VTT MOD(unconfirmed/untested)
VCORE READOUT(haven't checked yet >> someone pls check and let us know)
VDIMM MOD(unconfirmed/untested)
VNB MOD >>> tested using 20K VR (be careful here though and make sure your VR is loosened up all the way as 20K already boosts vNB by 0.05v at stock VR resistance)
VCORE & VDROOP MODS
>> VCORE MOD confirmed working >>> USE 100K VR to be sure....even 200K if required.....you could use as low as 50K but start high first as not all boards are the same
>> VCORE droop MOD confirmed working >>> USE 50K VR .... also may be able to use a smaller VR as one user is reporting around 2-3K reading after dialing down 50K VR to control droop properly
as you can see none of them have resistance readings (besides vdroop) yet so i need ppl to do the readouts on their boards and report
if anyone does test these please report your findings or if you have alternative points let's get them up here and test out make sure they work 100%
dinos22
