Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 124
Thread: new HD x264 video encoding benchmark
    Feb 2007
    Techarp is hosting a new HD x264 benchmark. Have a look and run it on your system to help populate the data table.
    Basically, you run the test encode of an HD sample (1280x720) and it will report back frames-per-second values for your machine @ it's clock/overclock level. You can run it at your stock settings and at your overclock settings to see how your machine compares to others in the database.
    My goal is to have a representative set of data for many different chips and chipsets. Please just report your results here in this thread. I will keep the data at that url to keep things simple.
    Thanks all and enjoy!
    The following image will be updated automatically as new data comes in. It doesn't display any results, but it does show the number of data points collected so far and how they break down by CPU type:
    Nov 2005
    Plano, TX
    Opteron 165 @ 3.0GHz, 9x333. Memory is 2x512 at 231MHz, 2.5-4-3-7 1T.
    OS: WinXP SP2
    Code:
    ---------- RUN1PASS1.LOG
    encoded 1442 frames, 31.51 fps, 3905.08 kb/s
    ---------- RUN2PASS1.LOG
    encoded 1442 frames, 31.67 fps, 3905.08 kb/s
    ---------- RUN3PASS1.LOG
    encoded 1442 frames, 31.57 fps, 3905.08 kb/s
    ---------- RUN4PASS1.LOG
    encoded 1442 frames, 31.54 fps, 3905.08 kb/s
    ---------- RUN1PASS2.LOG
    encoded 1442 frames, 7.33 fps, 3942.92 kb/s
    ---------- RUN2PASS2.LOG
    encoded 1442 frames, 7.34 fps, 3942.92 kb/s
    ---------- RUN3PASS2.LOG
    ---------- RUN4PASS2.LOG
    Core i7 920 @ 4.4GHz, EVGA Classified E760, 3x1GB OCZ Platinum DDR3-1600 @ 1680 7-8-7-24, SLI eVGA 8800GT @ 756/1890/2200, Heatkiller 3.0 CU waterblock, WD Caviar Black 1TB, Hitachi E7K500 500gb, Seasonic S12 SS-650HT psu
    Feb 2007
    Kentucky
    Your link isn't broken, but the one to the download page is...
    Asus Maximus Formula (Rampage Conversion Bios 0403)
    Q6600 G0 stepping@4.05 Ghz
    8GB G. Skill 1066 @ 1081 Mhz
    EVGA 280 GTX
    Auzentech Prelude
    2X 74 GB WD Raptors in Raid 0 Windows 7 Ultimate 64
    2X 1 TB WD Caviar Blacks in Raid 0 Vista Ultimate x64
    Thermaltake Toughpower 1200W
    DTek Fuzion V2 in a custom CPU only water loop
    Coolermaster Stacker 830
    Hanns-G 28" widescreen
    Klipsh Pro-Media 2.1
    G15 Keyboard and G9 Laser Mouse
    Feb 2007
    @spdycpu - cool man, thanks for the data
    @speedfreak86 - thanks for letting me know, it's fine now give it a shot
    Feb 2007
    Kentucky
    B3 Q6600@3.6Ghz, 9X400, X38 chipset, Memory is 4X2GB DDR2@1066Mhz 5-5-5-15 2T
    Windows XP Pro x64
    encoded 1442 frames, 72.73 fps, 3905.42 kb/s
    encoded 1442 frames, 73.13 fps, 3905.42 kb/s
    encoded 1442 frames, 72.72 fps, 3905.42 kb/s
    encoded 1442 frames, 72.90 fps, 3905.42 kb/s
    encoded 1442 frames, 19.92 fps, 3952.85 kb/s
    encoded 1442 frames, 19.96 fps, 3952.85 kb/s
    encoded 1442 frames, 19.94 fps, 3952.85 kb/s
    encoded 1442 frames, 19.93 fps, 3952.85 kb/s
    EVGA 280 GTX
    Auzentech Prelude
    Feb 2007
    Cool man, thanks!
    Jun 2005
    Bulgaria, Varna
    C2D E8400 @ 9*445 (4005MHz); X38; 4x1GB DDR2 @ 1069MHz (5-5-5-12);
    Windows Vista-64 SP1;
    encoded 1442 frames, 45.85 fps, 3905.08 kb/s
    encoded 1442 frames, 45.94 fps, 3905.08 kb/s
    encoded 1442 frames, 11.88 fps, 3942.92 kb/s
    encoded 1442 frames, 11.90 fps, 3942.92 kb/s
    encoded 1442 frames, 11.86 fps, 3942.92 kb/s
    encoded 1442 frames, 11.89 fps, 3942.92 kb/s
    Feb 2007
    Thanks man, first wolfie data point!
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    Q9550 C1, 8.5 x 475, 2 gigs OCZ DDR3 at 1900mhz, cas 8-7-6-20-1T.
    Vista with SP1.
    encoded 1442 frames, 87.95 fps, 3905.42 kb/s
    encoded 1442 frames, 88.03 fps, 3905.42 kb/s
    encoded 1442 frames, 87.87 fps, 3905.42 kb/s
    encoded 1442 frames, 24.17 fps, 3952.85 kb/s
    encoded 1442 frames, 24.20 fps, 3952.85 kb/s
    encoded 1442 frames, 24.19 fps, 3952.85 kb/s
    encoded 1442 frames, 24.29 fps, 3952.85 kb/s
    I like this benchmark, its pretty cool.
    uses all cores, not too short, not too long, good amount of information from the results. very handy benchmark.
    Xtreme Cruncher
    Jan 2008
    Canada
    Q6600 G0, 8 x 450=3600, 4gb Ballistix DDR2 1:1 900mhz, 4-4-4-12 Performance LvL 1, Vista with SP1.
    Code:
    encoded 1442 frames, 72.22 fps, 3905.42 kb/s
    encoded 1442 frames, 72.05 fps, 3905.78 kb/s
    encoded 1442 frames, 72.05 fps, 3905.42 kb/s
    encoded 1442 frames, 71.27 fps, 3905.42 kb/s
    encoded 1442 frames, 20.13 fps, 3952.75 kb/s
    encoded 1442 frames, 20.19 fps, 3952.82 kb/s
    encoded 1442 frames, 20.14 fps, 3952.75 kb/s
    encoded 1442 frames, 20.20 fps, 3952.75 kb/s
    i don't see how that other kents beat me @9x400 with 800mhz ram
    edit: looks like it's a difference of OS XP vs. Vista maybe
    anyway, nice benchmark as was the non hd one, great work on the tables to graysky
    Nov 2005
    Mansfield TX
    Q6600 B3 378X9 2GB ram 3-3-3-10 winxp. This is my 24/7 config.
    encoded 1442 frames, 67.26 fps, 3904.67 kb/s
    encoded 1442 frames, 67.91 fps, 3904.67 kb/s
    encoded 1442 frames, 68.01 fps, 3904.67 kb/s
    encoded 1442 frames, 19.04 fps, 3952.97 kb/s
    encoded 1442 frames, 19.03 fps, 3952.97 kb/s
    encoded 1442 frames, 18.89 fps, 3952.97 kb/s
    encoded 1442 frames, 19.02 fps, 3952.97 kb/s
    Praetor
    » Intel i7 2600K 3103B306 » Asus Maximus IV Extreme-Z » Asus GTX 470's TRi-SLI » Corsair Dominator GT CMT4GX3M2A2000C8 » Corsair Force F180 SSD » Corsair AX1200 PSU » Corsair 800D
    » Cooling : Swiftec Apogee XT » Swiftec MCP350-DDC1 w/XSPC Dual DDC Bay Reservoir » Swiftech MCR320-QP w/Scythe SlipStreams 110CFM
    The Yamato
    » Intel i7 920 3849B028 or i7 980X » Asus Rampage III Extreme Black Edition » Asus HD6970's QuadFireX or Asus GTX 570's 4way SLI » 6GB Corsair Dominator GT TR3X6G1866C7GTF » Corsair Force F180 SSD » Corsair AX1200 PSU » Microcool Banchetto 101
    » Cooling : Dragon F1 Extreme Edition(LN2) » Custom SS by RunMc »
    Feb 2007
    Thanks for the results, guys!
    A few questions:
    @Kunaak - What chipset is your MB (X38 I'm guessing) and is your O/S 32 or 64-bit?
    @Gen - Same questions as Kunaak, what chipset and O/S architecture
    @Nemesis - Same questions and one other: what chipset, O/S architecture, and what speed is the memory running (756 I'm guessing)?
    Nov 2005
    Mansfield TX
    chipset is p965, os is winxp 32 bit, memory 757mhz. There's a link in my sig to a screen shot with all exact numbers.
    Praetor
    The Yamato
    Xtreme Cruncher
    Jan 2008
    Canada
    Quote Originally Posted by graysky View Post
    P5K-e, Vista x64
    Xtreme Monster
    May 2006
    United Kingdom
    E6600: 3.0 MB: P5N32-SLI Ram: 4.4.4.12 890 Mhz OS: XP
    Code:
    encoded 1442 frames, 32.38 fps, 3905.08 kb/s
    encoded 1442 frames, 32.67 fps, 3905.08 kb/s
    encoded 1442 frames, 32.55 fps, 3905.08 kb/s
    encoded 1442 frames, 32.53 fps, 3905.08 kb/s
    encoded 1442 frames, 8.25 fps, 3942.92 kb/s
    encoded 1442 frames, 8.26 fps, 3942.92 kb/s
    Metroid.
    Aug 2003
    Rome
    encoded 1442 frames, 69.86 fps, 3904.67 kb/s
    encoded 1442 frames, 70.07 fps, 3904.67 kb/s
    encoded 1442 frames, 70.02 fps, 3904.67 kb/s
    encoded 1442 frames, 69.76 fps, 3904.67 kb/s
    encoded 1442 frames, 19.55 fps, 3952.97 kb/s
    encoded 1442 frames, 19.60 fps, 3952.97 kb/s
    encoded 1442 frames, 19.49 fps, 3952.97 kb/s
    encoded 1442 frames, 19.59 fps, 3952.97 kb/s
    EVGA Classified 759 ~ i7 975 EE ES ~ Noctua NH-U12P + 2 x UltraKaze 3000
    Mushkin 998696 BBSE ~ Sapphire BBA 4890 ~ Cosmos S ~ Enermax Revolution 1250
    Feb 2007
    Cool man, thanks. Added.
  18. #18
    Feb 2007
    Quote Originally Posted by Metroid View Post
    Metroid.
    Is it 9x333 = 3.0 GHz? Also, XP 32 or 64?
  19. #19
    Xtreme Monster
    May 2006
    United Kingdom
    Yes 9x333 XP: 32 bits, forgot these bits
    Metroid.
  20. #20
    Nov 2002
    Juneau Alaska
    A few questions:
    vista 32.
    maximus extreme.
  21. #21
    Nov 2005
    Mansfield TX
    Here's a run @ 3.6 Ghz Q6600 B3 400x9 2:3 divider DDR2-1200 P965 winXP 32bit.
    encoded 1442 frames, 74.67 fps, 3904.67 kb/s
    encoded 1442 frames, 74.91 fps, 3904.67 kb/s
    encoded 1442 frames, 74.79 fps, 3904.67 kb/s
    encoded 1442 frames, 74.37 fps, 3904.67 kb/s
    encoded 1442 frames, 20.40 fps, 3952.97 kb/s
    encoded 1442 frames, 20.42 fps, 3952.97 kb/s
    encoded 1442 frames, 20.39 fps, 3952.97 kb/s
    encoded 1442 frames, 20.36 fps, 3952.97 kb/s
    Praetor
    The Yamato
  22. #22
    Feb 2007
    @Kunaak - cool thanks!
    @nemesis - got it, thanks!
  23. #23
    Xtreme Mentor
    May 2007
    Q6600 G0, normal air, 18MHz more than every day 3825MHz settings:
    [OC 3843MHz, 427x9, DDR2-1066 5-5-5-5 (PL7), P35, XP Pro SP3 32-bit]
    [1.504 idle/1.482 load vCore, 2.08 vMEM, stock vNB, vPLL and vFSB]
    [Stock 2400MHz, 266x9, DDR2-1066, 5-5-5-5 (PL4), P35, XP Pro SP3 32-bit]
    [1.200 idle/1.184 load vCore, 2.08 vMEM, stock vNB, vPLL and vFSB]
    Nice bench, loads the cores perfectly and length is good too
  24. #24
    Nov 2005
    Mansfield TX
    rams @ 5-5-5-15
    Praetor
    The Yamato
  25. #25
    Feb 2007
    Quote Originally Posted by The Nemesis View Post
    rams @ 5-5-5-15
    Which of your two runs use the 5-5-5-15 timings? Both? For some reason I had them down as 3-3-3-10. The 5-5-5-15 makes way more sense
