Page 1 of 117 12341151101 ... LastLast
Results 1 to 25 of 2905
Thread: **Official DFI LanParty UT X48-T2R(and LT) Discussion
    Aug 2006
    Note:northbridge cooler is shipped inside box.You must install.In the first picture,it is the silver item that says lanparty on it.
    LANPARTY LT X48-T2R http://www.dfi.com.tw/Product/xx_pro...YPE=MB&SITE=US
    LANPARTY UT X48-T2R http://www.dfi.com.tw/Product/xx_pro...YPE=MB&SITE=US
    CPU support list
    http://us.dfi.com.tw/Support/mb_cpu_...D=5915&SITE=US
    Recommended Memory for overclocking
    http://www.dfi.com.tw/Product/xx_pro...RODUCT_ID=5917
    Manual
    http://www.dfi.com.tw/Support/Downlo...YPE=MB&SITE=US
    BIOS
    http://www.dfi.com.tw/Support/Downlo...FLAG=A&SITE=US
    Drivers
    Understanding GTL reference vaules.
    http://www.edgeofstability.com/index.html
    Clunk's GTL ref.
    http://www.clunk.org.uk/forums/12436-post11.html
    Purchase USA.If outside usa.Shoot mike a email.
    http://www.motherboardpro.com/DFI-LP...ard-p-540.html
    Specification
    CPU
    # LGA 775 socket for: - Intel® CoreTM2 Quad and Intel® CoreTM2 Duo
    # Supports Intel Enhanced Memory 64 Technology (EMT64T)
    # Supports Enhanced Intel SpeedStep Technology (EIST)
    # Supports Intel Hyper-Threading Technology
    # Supports 1600/1333/1066/800MHz FSB
    Chipset
    # Intel® chipset - Northbridge: Intel® X48 Express chipset (with Intel® Fast Memory Access technology) - Southbridge: Intel® ICH9R
    Memory
    # Four 240-pin DDR2 DIMM sockets
    # Supports DDR2 667/800 MHz
    # Delivers up to 12.8Gb/s bandwidth
    # Supports dual channel (128-bit wide) memory interface
    # Supports up to 8GB system memory
    # Supports unbuffered x8 and x16 DIMMs
    Expansion Slots
    # 2 PCI Express (Gen 2) x16 slots (PCIE 1 and PCIE 3) - 2-way CrossFire at x16/x16 bandwidth - 2-way CrossFire + Physics at x16/x16/x4 bandwidth
    # 1 PCI Express x1 slot (PCIE 2)
    # 1 PCI Express x4 slot (PCIE 4)
    # 3 PCI slots
    BIOS
    # Award BIOS
    # 8Mbit flash memory
    # CMOS Reloaded
    Audio
    # Bernstein audio module - Realtek ALC885 8-channel High Definition Audio CODEC - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
    # DAC SNR/ADC SNR of 106dB/101dB
    # Full-rate lossless content protection technology
    LAN
    # Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
    # Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    IEEE 1394
    # VIA VT6307
    # Supports two 100/200/400 Mb/sec ports
    Storage
    # Intel ICH9R chip - Intel Matrix Storage technology - Supports up to 6 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1, RAID 0+1 and RAID 5
    # JMicron JMB363 PCI Express to SATA and PATA host controller - Supports up to 2 UltraDMA 100Mbps IDE devices - Supports 2 SATA devices - SATA speed up to 3Gb/s - RAID 0 and RAID 1
    Rear Panel I/O Ports
    # Mini-DIN-6 PS/2 mouse port and PS/2 keyboard port
    # 1 IEEE 1394 port
    # 6 USB 2.0/1.1 ports
    # 2 RJ45 LAN ports
    I/O Connectors
    # 3 connectors for 6 additional external USB 2.0 ports
    # 1 connector for an external COM port
    # 1 connector for an IEEE 1394 port
    # 1 connector for the Bernstein audio module
    # 1 front audio connector (on the Bernstein audio module)
    # 1 CD-in connector (on the Bernstein audio module)
    # 1 S/PDIF connector (on the Bernstein audio module)
    # 1 IrDA connector
    # 1 CIR connector
    # 8 Serial ATA connectors
    # 1 40-pin IDE connector and 1 floppy connector
    # 1 24-pin ATX power connector
    # 1 8-pin 12V power connector
    # 2 4-pin 5V/12V power connectors (FDD type)
    # 1 front panel connector
    # 6 fan connectors
    # 1 diagnostic LED
    # EZ touch switches (power switch and reset switch)
    Power Management
    # ACPI and OS Directed Power Management
    # ACPI STR (Suspend to RAM) function
    # Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse
    # Wake-On-LAN and Wake-On-Ring
    # RTC timer to power-on the system
    # AC power failure recovery
    Hardware Monitor
    # Monitors CPU/system/Northbridge temperature and overheat alarm
    # Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    # Monitors the speed of the cooling fans
    # CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
    PCB
    # 6 layers, ATX form factor
    # 24.5cm (9.64") x 30.5cm (12") All specifications above are subject to change without prior notice.
    Aug 2006
    Known aftermarket cooling solutions with no mods required to install.Please post if you have one.
    Cpu air:
    Northbridge air:
    Thermaltake extreme spirt II.
    Northbridge water:
    Swiftech MCW30
    Enzotech SNBW-SLI Aprrox 85% coverage.
    Southbridge air:
    Thermaltake extreme spirt II.Questionable with dual slot cooling graphics card.
    Southbridge water:
    Swiftech MCW30.Questionable with dual slot cooling graphics card.
    Other:
    Xtremely unstable
    Aug 2004
    Between Hell and Nowhere
    I really like the fact that dfi still uses socketed bios on their boards.
    dx58so
    w3520@4100
    4x1gb corsair ddr3-1333
    gtx 295
    TR ultra-x, 2 scythe ultrakaze push/pull
    xclio stablepower 1000
    vista ultimate
    [SIGPIC][/SIGPIC]
    would you crunch if you thought it would save her life?
    maybe it will!
    XS News
    Dec 2003
    North Carolina
    I get my tracking number tomorrow.
    RIP Dad. I will miss you always.
    Q6600,DFI X48 T2R,280 GTX,4gig ReaperX,XiFi Prelude,LL TYR PC X-2000,Westinghouse 37,Klipsch 5.1 Ultra
    May 2007
    Quote Originally Posted by loonym View Post
    It makes sense to use a socketed bios. Think of all the money that can be saved on RMA's. Somebody hoses a bios flash and all DFI has to do is pop in a new bios chip and send the motherboard back to the customer. Or better yet. Just ship out a new bios chip to the customer and let them do it themselves. All higher end motherboards should use socketed bios chips.
    i5 2500K @ 4.7ghz 1.32v(+.010 offset LLC set to 4) / ASRock P67 Extreme4 (B3) / 2x4gb Samsung Green MV-3V4G3D @ 1866mhz 1.35v / AMD HD 6850 1gb /2x150gb Velociraptor Raid 0 + 500gb WD Green / Corsair TX 750watt V2
    Jan 2003
    Canterbury, UK
    Ok, this is my biggest n00b question ever but here goes...
    Which is the better version with DFI (I've never used them), UT, LT or DK?
    | Asus nVidia 580 GTX @ 850MHz |
    | Windows 7 x64 Ultimate | Mac OS X 10.6.8 | Mac OS X 10.7.2 |
    | Intel Core i7 970 @ 4.2GHz | Gigabyte X58A-UD9 | 12GB Corsair 2000MHz 8-8-8-24 |
    | HTC HD2 | MIUI 1.10.21 | Android 2.3.7 | TyTung 12.4 Kernel |
    New Builds Coming Soon..
    Xtreme 3D Team Member
    Jun 2006
    small town in Indiana
    Quote Originally Posted by kup View Post
    basically the order you have them in. UT is the top dog with the best cooling arrangement, LT has normal-ish heatsinks but shares the same layout and most components, DK is the budget segment, cheaper components fewer pci-e slots etc.
    QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
    DFI LP LT X-38 T2R
    2X HD4850's water cooled , volt modded
    Thermaltake 1KW Psu
    4x Seagate 250GB in RAID 0
    8GB crucial ballistix ram
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    the LT probly has a better heatsink like last time, some1 needs to upload the bios so we x38 users can get it
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Jan 2003
    Canterbury, UK
    So putting cooling aside because most of us here will change it or mod it in some way, which board is the one designed for all out overclocking performance? I assume the UT being that it is the top dog?
    Jul 2007
    SF bay area, CA
    they are probly the same
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    Isn't the X48 Chipset just a Higher binned X38 Chipset?
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    Jan 2003
    Canterbury, UK
    Quote Originally Posted by Brother Esau View Post
    Indeed it is.
    Jul 2007
    SF bay area, CA
    i wounder how the wireless integration works i hope that its a card or a usb header and not something that would keep us from flashing up to it
    Admin
    Mar 2003
    North Texas
    The UT and LT are the same board with different cooling solutions. I'm not sure about the DK, I never had one.
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    Jan 2003
    Canterbury, UK
    The wireless is in the new IHCR10 SouthBridge.
    Jul 2007
    SF bay area, CA
    then why would it have an ich9r and wifi
    May 2007
    Quote Originally Posted by runmc View Post
    Correct. UT and LT perform basically the same. Dark version LanParty has somewhat different bios with some fewer options and thus is slightly outperformed by UT and LT version. And of course it's a lot cheaper.
  18. #18
    Jan 2003
    Canterbury, UK
    I meant that the new ICHR10 will have Wireless intergrated, not that the ICHR9 does.
    Where does it say this board will have wireless intergration?
  19. #19
    Jul 2007
    SF bay area, CA
    sorry i misread it
  20. #20
    Feb 2007
    Arizona, USA
    I wonder if someone can mod the X48 T2R bios to flash an X38 T2R with...
    Core i7 920 D0 B-batch (4.1) (Kinda Stable?) | DFI X58 T3eH8 (Fed up with its' issues, may get a new board soon) | Patriot 1600 (9-9-9-24) (for now) | XFX HD 4890 (971/1065) (for now) |
    80GB X25-m G2 | WD 640GB | PCP&C 750 | Dell 2408 LCD | NEC 1970GX LCD | Win7 Pro | CoolerMaster ATCS 840 {Modded to reverse-ATX, WC'ing internal}
    CPU Loop: MCP655 > HK 3.0 LT > ST 320 (3x Scythe G's) > ST Res >Pump
    GPU Loop: MCP655 > MCW-60 > PA160 (1x YL D12SH) > ST Res > BIP 220 (2x YL D12SH) >Pump
  21. #21
    Aug 2006
    Shipping date change from MotherboardPro.com. site.
    We expect to start fulfilling orders for this product on 3-17-2008.
  22. #22
    Oct 2006
    Auckland, New Zealand
    what advantage does the X48 chipset have over the X38?
    i7 920 | Asus Rampage II gene | 6GB ocz Blade | 4870x2
  23. #23
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by ColonelCain View Post
    why would u have to mod the bios, it uses winflash thats a clean version to flash so u can flash whatever u want to the rom
    uve been with asus to long
  24. #24
    May 2007
    Quote Originally Posted by nzbleach View Post
    Something like this:
    The basic differences between the chipset Intel x48 and x38 is the official support to 1600 MHz system bus, corresponding frequency dividers, and also the possibility to exploit a pair of modules DDR 3-1600 with XMP technology and 1.8 v .
    http://xtreview.com/addcomment-id-35...8-chispet.html
    Somewhat better memory overclocking and native support.
  25. #25
    Dave's Mentor!
    May 2007
    montreal
    Quote Originally Posted by zanzabar View Post
    yup i had flashed bios with the x38-dk bios
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
