Noob Worklog: A Work in Progress
Hello all, firstly I would like to thank all of you who contributed to my previous thread. Your input has saved me a lot of time and money.
I would also like to thank MaxxxRacer who has the best damn liquid cooling guide on the net IMHO. I was able to chip away at my original list until it was perfect.
This log will be a work in progress and I'll post many photos and comment on my experiences etc. Hopefully if all is done right it will help other newbies out there.
Components Purchased (mostly from PTS):-
Laing D5 Vario/Swiftech MCP655 12V DC Pump $87.99
D-tek FuZion CPU Waterblock $59.95
D-Tek FuZion Accelerator Nozzle Kit $6.99
D-Tek Fuzion Pro-Mount Hardware $11.95
Swiftech MCW60 GPU Waterblock x2 $89.20
Enzotech VGA Memory Heatsink Multipack (BMR-C1) x2 $25
Swiftech MCR320-QP Radiator $54.99
Swiftech MCB-120 "Radbox" R2 $17.99
120mm Yate Loon D12SM-12 Fan (70.5 CFM, 33 dBA) x3 $17.85
1-1/4" Stainless Steel Swiftech MCR-QP Fan Screws (Pack of 4) x3 $3.45
Masterkleer 7/16" ID (5/8" OD) Tubing x20Ft. $9.8
Danger Den Acetal FillPort $11.95
1/2" OD T-Fitting (for 1/2" and 7/16" ID Tubing) $1.99
D-Tek High-Flow Fitting (G 1/4" Thread, 1/2" OD) x6 $13.8
Stainless Steel Worm-Drive Hose Clamp (Wide Band w/Liner) x14 $17.5
5/8" ID (1 1/8" OD) Rubber Grommet x2 $1.50
Arctic Cooling MX-2 Thermal Compound $5.99
Petra'sTech "Gel-Stuff" Vibration Absorption Block $3.99 (for Pump)
120mm Sound Vibration Dampener x3 $5.37 (for Fans)
Feser One Non Conductive Cooling Fluid - 1000 ml - UV Red $19.95
$467.20 (It's a good investment IMHO)
Loop Order:-
Pump outlet --> CPU inlet
CPU outlet --> GPU1 inlet
GPU1 outlet --> GPU2 inlet
GPU2 outlet --> Radiator inlet
Radiator outlet --> Pump inlet
AMD Phenom II X4 940 Black Edition @ 3605.17MHz (206.01*17.5)
Gigabyte GA-MA790X-UD4 Motherboard (BIOS F6)
2048MB x2 G.SKILL (F2-8800CL5D-4GBPI) DDR2-1100 @ 5-5-5-15
Sapphire Radeon HD 5850
Sound Blaster X-Fi Fatality FPS
WD Caviar Black 500GB (WD5001AALS) SATA 3.0 HDD x2
OCZ GameXStream OCZ700GXSSLI 700W PSU
Cooler Master Cosmos S Chassis
Windows 7 Professional x64
Driver Versions: Catalyst 9.12, X-Fi 2.18.0013
CPU-Z | 3DMark Vantage | Behold teh DRAGON
- You may not post replies
- You may not edit your posts
Forum Rules
