After years of languishing in the cesspit of outdatedness (2.0 Ghz P4 with 1Gb RDRAM, nvidia 7900 AGP, etc.) I got permission from my wife last November to build a high-end gaming machine. Well, the last part isn't really true but that's how it all turned out (: So at the end of 2007 I started cruising the tubes to research the best build for my situation.
I never explicitly planned on going water cooling, but then I never planned on working with a computer that sounded like a vacuum cleaner either. My initial build was complete by Jan. 20th:
Case: Mountain Mods U2-UFO with a thermochill front panel with accessories
Case Cooling: 9 Yate Loon 120mm silent case fans Some LED, some black.
Mother Board: eVGA 780i
Processor/cooling: Intel Q6600 with a Tuniq Tower 120
RAM: 8Gb G.Skill DDR2 1000
VGA: x2 eVGA 8800GTS G92 in SLi
Display: Dell 2707WFP (27" LCD)
Media: Asus 20x DVD/CD-RW
Storage: x4 WD 750AYYS w/ Vista Ultimate x64
Power: PC Power &Cooling 750W PSU with a 900W CyberPower UPS
I managed to stay close to budget, and was very happy with the performance of my new build. There was no comparison with my old machine. My CPU temps were doing well in the mid to upper 30's idle (over clocked to 3.6Ghz), my VGA was around 50 idle (with fan speed at 60%, stock clocks), after fixing some issues with the stock cooling on the eVGA MB, I got my chipset temps down from 108C to 64C idle. It was nice. But I had an itch.![]()
The only downside was that with the new (larger) case I couldn't enclose it in my "computer drawer" and keep it out of earshot. That meant the obnoxiously loud stock nVidia north bridge fan was going full bore, an arms reach away. The VGA fans weren't helping either. Also, not having a fan controller for the case fans meant that they were unnecessarily running at full speed, adding to the din. This computer was pretty loud, and not really by design.
After consulting with my financier we () decided a quieter approach was needed. Water cooling was needed. Urgently. Being able to hear the computer in the nursery helped in that regard ;D. So, some new equipment was ordered:
- Evercool Twinkling VGA Cooler for the South Bridge/MCP chipset
- 15' of Tygon 3/4" OD 1/2" ID tubing (this whole set-up is 1/2" ID, 3/4 OD)
- A bunch of sleeving and heatshrink to beautify the cabling
- ZALMAN MFC1 Plus 6 Channel Multi Fan Controller
- A RadioShack butane soldering iron with some silver solder (this came in handy!)
- A few LED's and some UV case lighting.
- A bunch of reusable swiftech hose clamps and zip-ties
- I raided about 4 ACE hardware stores and a custom bolt shop and wholesaler (J& E Supply) to get enough black 6-32 bolts of various lengths and cap types (: I liked the bolt shop. It was across the street from five seedy strip clubs.
- Koolance swiveling angle nozzles
- Koolance QDC shut-off nozzles (male & female) with a nylon T junction. These are for draining the system.
- Koolance liquid (distilled water + propylene glycol + anti corrosion + dye)
- XSPC Black Dual Bay Reservoir 5.25" with Bubble Window (it's HAL 9000)
- D-tek Fuzion CPU block with nozzle kit washer installed
- ViperJohn's custom north bridge water block with mosfet heatsinks (ViperJohn is THE MAN, as in YTMND, not "The Man")
- x2 Danger Den IONE 8800 G92 blocks with acrylic tops and optional SLi nozzles
- Thermochill PA120.3 Radiator with 1/2" ID barbs and with the performance shroud (properly flushed before install!)
- and a Laing D5 Vario/Swiftech MCP655 Inline 12V DC Pump
It's a long list for sure, but I think that about covers it. Next up is the rebuild.
