Translated from an asian site"
Mini P180 Antec Antec Mini P180 is the quieter, features and design technology condensed micro ATX case. 200mm 120mm Small, three-layer sound insulation panels, DYUARUCHANBA design, cabling good, functional HDD cage, 200 mm and 120 mm fans for fans, air filters, such as SHIRIKONGURIPPU the various features. Or even better expandability up to five HDD, optical drives with up to three units.
Mini P180 Mini P180 is a case in isolation or down to the design DYUARUCHENBA adopted. To prevent heat conduction in the system, exhaust heat separation zone.Air flow from the effective realization of the system noise and reduce fever.Case at the top of the CPU / motherboard / VGA / HDD, is the power to set up at the bottom of the case.
Case in side panels, plastic and aluminum(plastic + + aluminum aluminum) three layers of sound insulation panels adopted. In the case of noise-blocking tight, resonant sound and prevents MORE. The front door is open 270 degrees DABURUHINJI expression adopted. HDD。 Front port is connected to a new HDD interfaces, eSATA adopted. Fast and easy-to-port from the front.
LMAO at google translator
source; http://www.links.co.jp/html/press2/news_minip180.html
