First off, I want to give a big thanks to you all, particularly in the liquid cooling section. These forums are unlike anything that exists, on the internet or elsewhere. The people here are very helpful, encouraging, and knowledgeable!![]()
Show Me The Pics!!
Now, onto things...
I've been working on this for a long time, and am nearing the end.
I've always had a soft spot for Lian- Li. Clean lines, functional design, and always solidly constructed. In this build, my goal is to make a water cooled 'sleeper', that is appear totally unmodified to the casual observer.
It all started like this:
Though the measurements are in no way accurate, and i'm definitely not using that board, it helped me lay things out. The pump did not stay where it is, either.
Once I got the motherboard and rad, I was able to do some dremeling and dry fitting.
It was at that point I realized that i misread the width of the case (didn't account for the thickness of the mobo tray)and found that the shroud wasn't clearing the memory slots or the outlet for the waterblock or the bottom left mounting screw. That said, dremel to the rescue!
(Later on, I'd find out that i was mistaken about the wb outlet, but only after some damage had been done.)
Then more parts started to come in, and it's starting to look more PC like.
The Spread:
And some more dry fitting:
I got a large order from Newegg last week, the rest of the hardware- PSU, drives, etc. Yesterday, I picked up my shroud from the metal shop. I'm expecting (another) package from Petra's tomorrow. Hopefully it will be the last of the pieces I need for this. When this last package comes, it's on (literally).
Either way, I'm going to be working on it tomorrow, and will post more pics then or maybe friday.
i7 920@2.8
X3220@3.0
X3220@2.4
E8400@4.05
E6600@2.4
I almost forgot to thank these guys! They truly rock, Quoc answered all of my questions quickly.
Saaya yupp, I agree
