02-24-2008, 03:15 PM
#1
9600GT voltmod thread
Have this lovely card here - runs very cool under accelero s1 - 29°/37° idle/load @ 770/1890/1070. This card just craves for a volt mod. Anyone up to figuring one out?
Thx!
02-24-2008, 03:27 PM
#2
Xtreme 3D Team Member
Strip it naked and take lots of high res. pics, do you own a multi-meter?
__________________
QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
DFI LP LT X-38 T2R
2X HD4850's water cooled , volt modded
Thermaltake 1KW Psu
4x Seagate 250GB in RAID 0
8GB crucial ballistix ram
02-24-2008, 03:28 PM
#3
I do! Though my camera is dead atm.
But I'll try to figure smth out.
02-25-2008, 10:24 AM
#4
Xtreme Mentor
Post up pics of the back of the card when you can and im sure someone here can help
Wouldnt be surprised if Shamino already has mods mapped out
__________________
Proudly using
Crucial Ballistix
Xigmatek air
watercooling by XSPC
Originally Posted by T_M
Originally Posted by soundood
you sigged that?
why?
02-25-2008, 01:16 PM
#5
Hi guys!
I managed to lend a crappy camera from my friend and take some photos.
Here is the back of the card with some voltage measuring points which i have found out to be the vgpu and vmem measuring points:
Here is another pic of vgpu circuit and voltage ic:
Here is a pic of vmem circuit and voltage ic:
one more:
Tell me if more pics are needed and as well i can supply a higher resolution pics.
Right now i'm gonna try to mod the card's bios for more volts.
EDIT: bios vmod seems not to be working (setting 1.3V for extra and 3d modes yielded nothing).
EDIT2: fixed broken pic links
02-25-2008, 03:02 PM
#6
Xtreme Mentor
no pics showing up for me (FireFox)
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
02-25-2008, 03:05 PM
#7
dang, must find some worthy pic hosting service then. Brb.
EDIT: hosted on imageshack. can you see them now?
02-25-2008, 03:30 PM
#8
Xtreme Mentor
all good now  Will edit this post with info once Iv had a look at em
Cheers
______
The IC in pic 2 is the Core controller- please can you post up the info on it- I cant make it out in the pic.
Im not sure if you have got pics that cover the controller for the RAM voltage. It will be under the core controller, close to the other edge of the card i reckon
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
02-25-2008, 03:43 PM
#9
Gpu controller:
adp3208a
J #0751
I336086.1
KOREA
I couldnt find any data sheet for it though..
About ram ic: which one of these do you think it is?
I think in vr-zone 96gt review they mentioned something about this 51117 chip..
02-25-2008, 03:50 PM
#10
Xtreme Mentor
Well the chip on the right is a power FET, datasheet: http://pdf1.alldatasheet.com/datashe...RF7328PBF.html
The other one.... I cant make out whats on it, sorry!
CPU IC: Please can you measure the resistance from the marked pin to GND? (3rd from right on the bottom side of the IC)
Please can you also probe the components immediately around that pin and see what points its connected to (that would be easier to attach a trimmmer to)
pic:
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
02-25-2008, 03:56 PM
#11
here are the pics from vr-zone
02-25-2008, 04:06 PM
#12
Xtreme Mentor
excellent- please can you confirm that the 2 points iv marked in the picture are connected directly? (or...if they arent, which of those marger solder points does it go to)
DISCLAIMER TIME:
When this voltmod is posted, it will be untested. I will not be held responsible for any dead hardware that results from a mod gone wrong. No-one forces you to try these mods. Any mods attempted will be at the owners risk.
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
02-25-2008, 04:18 PM
#13
here is a closer pic of the gpu ic
unfortunately i can't measure the resistance between pin14 and gnd prolly because of my crappy MM - it just won't show me any value (just constant 1) up to 2000k ohm.
As you can see from this pic - the 2 red dots you marked are not connected directly on my card. vr-zone obviously has somewhat different (non-reference) pcb?
02-25-2008, 04:21 PM
#14
Xtreme Mentor
 Not good. Either im wrong, or you need to hit your DMM.
If anyone else has this card and a DMM, please can they chime in?
We'll worry about the core for now- if nVs last few cards are anything to go by, the GDDR doesnt scale well with volts anyway
Just checked on VR-Zone- if the GDDR controller is a mystery to Yan, I dont feel so guilty!
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
02-25-2008, 04:24 PM
#15
Yeah i dont think 9600gt is limited by mem bandwidth anyway.
Though im confused about the different layout of traces on my card and the one in vr-zone review. Not really sure which one is the reference design now. I would bet on my (Club3D) card though.
As of the resistance between pin14 and gnd - it is prolly higher than 2mohm thats why my DMM cant measure it.
02-25-2008, 04:27 PM
#16
Xtreme Mentor
 that res is way too high to be right. ok, my semi-wild stab at the FB pin might be wrong. DAMNIT.
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
02-25-2008, 04:34 PM
#17
Well it could be also be my DMM - you can't ask much from 10$ hardware.
Anyways if you come up with something - i'll prolly still be here lying somewhere with my 0.5L brandy.
02-25-2008, 04:42 PM
#18
Xtreme Mentor
I think the FB pin will be along the bottom edge of the chip, but process of elimination is hardly a stylish way of hunting it down...
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
02-25-2008, 05:00 PM
#19
by googling the number I came up with a possible match. http://64.233.167.104/search?q=cache:WkX6faGQ1XUJ:www.21icsearch.com/searchpdf/download.asp%3Fid%3D137161+ADP320+data+sheet&hl=en &ct=clnk&cd=1&gl=us#8
It is a 07 not an 08 but the others from the series appear to have the same layout, maybe this is just too new to be on the list.
FB is the 6th pin from the dot on the left side as you look at the chip.
completely guessing here let K404 see it and see what he thinks.
__________________
DFI LP LT X-38 T2R
Thermaltake 1KW Psu
02-25-2008, 05:35 PM
#20
i took another closeup shot of that side of ic:
pin6 marked
though once again i couldnt measure the resistance between pin6 and gnd..
02-25-2008, 06:21 PM
#21
The 2 pics look exactly the same to me except one is upside down.
__________________
ES Q9550 E0 @ 4.0GHz (471x8.5) 1.256v
TR-Ultra-120-X, 115CFM 120mm fan
Maximus II Formula @ 1884MHz FSB
Ballistix DDR2-800 (4x1GB) 1132MHz 5-5-5-5-15 4-55-8-14-11-3-8-5-4-2T
eVGA GTX 280 @ 702c/1404s/1260m (1.175v)
Auzentech XPlosion DTS-Interactive Vantage 'X'-6,727
300GB Velociraptor, PC P&C 750W
(3)120mm, (2)90mm, (1)250mm case fans in TT Armor
27.5" LCD/Z-5500-office, 95" 720P projector/7.1ch-living room
Logitech Driving Force Pro-Microsim Racing Pod
02-25-2008, 11:21 PM
#22
Xtreme Guru
vGPU mod is pin #6 of ADP3208 to ground.
vMEM mod is pin #5 of "51117" to ground.
Someone please measure resistance from the marked pads to GND:
__________________
You were not supposed to see this.
02-26-2008, 12:05 AM
#23
Attachment 72993
4.52 kOhm
8.5kOhm
Today i can measure resistance nicely with my DMM - i wonder if that has anything to do with French brandy i was using..
EDIT:
- Naye, i understood what i was doing different - last night i tried to measure that spot while the card was running - todays measures are when pc is turned off.
Actually - when do i have to measure - when pc is running or off?!
Omg i feel so owned.
02-26-2008, 12:14 AM
#24
Xtreme Guru
100kΩ for vGPU between the marked point and ground.
200kΩ for vMEM between the marked point and ground.
Any volunteering guinea pigs?
__________________
02-26-2008, 12:19 AM
#25
Im willing to do it. I'll check if i have the needed VR resistor on hand.
EDIT: Unfortunately it seems that i do not have the needed pots at my disposal (highest value i have is 47k). I will check back and confirm the mod tonight when i return from my work.
p.s. Largon - your input is largely appreciated.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
