XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Liquid Cooling > Liquid Cooling Worklogs
Reply
Old 02-11-2008, 11:45 PM   #1
virtualrain
Talking Project: RainMaker (PC-343B w/ Horizontal Mobo and Triple Loops)
Sadly, I've been working on this project for almost a year, and I've realized, it will likely never be completely finished... there's always something else to be done.
Anyway, after a sufficiently long period of procrastination, I've finally got around to annotating some of the pics I took during the build for those of you who might be interested in seeing something a bit different with a Lian-Li PC-343B Cube Case.
The key unique mod I've made here is in converting the motherboard tray to a horizontal configuration.
Although the rest has largely been done before, there are a few other unique elements such as the pump mounting and overall number of water cooled components that may be of interest.
Many ideas were borrowed from others on this forum and elsewhere, so I give due credit to all concerned and thank you sincerely for the inspiration behind many of the design considerations in this project.
My key design goals when starting this project were:
  • Build a chassis complete with cooling that would last several generations of electronics
  • Build something that would stretch my capabilities as a hobby PC modder
  • Build a completed system that was as good if not better than something a custom mod shop would build or a high-end system builder in terms of aesthetics, servicability, and modularity.
  • Build a cooling system that would pass the XtremeSystems test of no-compromise performance
  • Build a system that was challenging and agressive and could stand up to the scrutiny of my peers
Ultimately, your feedback will determine if I was successful in my goals.
March UPDATE: Post #3 now contains pics of the finished build (including SLI and PhysX with the laser cut top/rear panels).
April UPDATE: RainMaker has been featured on Million-Dollar-PC.com!
RAINMAKER FOR SALE! Link
Let's get to it...
Teaser of the Semi-Final Outcome
Essential Tools of the Trade
Chassis Frame
Motherboard Tray
Horizontal Motherboard
Cable Management
Powder Coating
Nickel Plating
Radiator Mounts
Radiator Pump Assemblies
virtualrain is offline   Reply With Quote
Old 02-11-2008, 11:46 PM   #2
virtualrain
More Build Pics...
SilentMaxx Watercooled PSU's
Lower Radiator Installation
Motherboard Cable Tray
Monitoring and Control
Water Cooling Prep
Old 02-11-2008, 11:47 PM   #3
virtualrain
More Build Pics...
Initial Build (before SLI and PhysX)
Initial Build with Lighting
Adding SLI & PHysX
Laser Cut Top Panel
Laser Cut Rear Panel and Louver
Desktop Screen Shots
Note that these images are very large. I run a dual monitor setup with a Dell 30" 2560x1600 primary display and a Dell 2007 1600x1200 in portrait mode for a secondary display.
Data collected by Speedfan, Rivatuner, and the Aquaero's is displayed in the Samurize configs on the right hand side of the secondary display.
The Full Desktop...
The Secondary Display...
Wallpaper compliments of AHiL
Old 02-11-2008, 11:52 PM   #4
NoobCake
just looking at ur sig, you have a pa120.2 on the GTX's and a PA120.3, shouldn't it be the other way?
i would seriously chuck the pa120.3 on the GTX's.. and a pa120.2 should handle a q6600 quite easily
NoobCake is offline   Reply With Quote
Old 02-11-2008, 11:57 PM   #5
Nicoleef
Nicoleef's Avatar
Send a message via MSN to Nicoleef
Patriote on his XETM Project has 2 GTX's on a PA120.2 and as i saw his temps are ok with 626Mhz\2000Mhz OC.
Link: http://www.xtremesystems.org/forums/...d.php?t=160457
__________________
*/Specs:.
....LOADING
Nicoleef is offline   Reply With Quote
Old 02-12-2008, 05:07 AM   #6
shazza
Xtreme Fan
shazza's Avatar
Another great 343B build! You guys are so talented. Thanks for sharing this one. It is unique.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is online now   Reply With Quote
Old 02-12-2008, 05:44 AM   #7
Talonman
Xtreme Mentor
Talonman's Avatar
Legendary build going on here, with excellent documentation!
Thanks for the post virtualrain. You rig has a very unique look to it.
Keep up the good work.
__________________
Asus Maximus SE X38 / Lapped Q6600 G0 @ 3.8GHz (L726B397 stock VID=1.224) / 7 Ultimate x64 /EVGA GTX 295 C=650 S=1512 M=1188 (Graphics)/ EVGA GTX 280 C=756 S=1512 M=1296 (PhysX)/ G.SKILL 8GB (4 x 2GB) SDRAM DDR2 1000 (PC2 8000) / Gateway FPD2485W (1920 x 1200 res) / Toughpower 1,000-Watt modular PSU / SilverStone TJ-09 BW / (2) 150 GB Raptor's RAID-0 / (1) Western Digital Caviar 750 GB / LG GGC-H20L (CD, DVD, HD-DVD, and BlueRay Drive) / WaterKegIII Xtreme / D-TEK FuZion CPU, EVGA Hydro Copper 16 GPU, and EK NB S-MAX Acetal Waterblocks / Enzotech Forged Copper CNB-S1L (South Bridge heat sink)
Talonman is offline   Reply With Quote
Old 02-12-2008, 05:58 AM   #8
Colossous
Colossous's Avatar
Send a message via MSN to Colossous
Virtualrain raises the bar ! Amazing build and great project log dude ! I have a new one coming too and yours is inspiring for sure !
__________________
Hark children of the Resolution !!
Colossous is offline   Reply With Quote
Old 02-12-2008, 06:21 AM   #9
Xilikon
Banned
Very great build here... Gave me a few ideas for my own mod
Imitation is the sincerest form of flattery
Xilikon is offline   Reply With Quote
Old 02-12-2008, 06:31 AM   #10
disruptfam
I am Xtreme
disruptfam's Avatar
Send a message via MSN to disruptfam
WOW VIRTUAL RAIN !!
i've been waiting for this for a long time hehehe
Looks like all your Hard work has paid off Looking forward to more updates
This going to be LEGENDARY
__________________
Originally Posted by skinnee View Post
No, I think he had a date tonight...
He and his EK Supreme are out for a night on the town!
disruptfam is offline   Reply With Quote
Old 02-12-2008, 06:49 AM   #11
Talonman
Xtreme Mentor
Talonman's Avatar
I think he has successfully grabbed our full attention!
__________________
Old 02-12-2008, 06:52 AM   #12
disruptfam
I am Xtreme
disruptfam's Avatar
Builds Like This Make My Day!
I can tell this is going to blow me away!
__________________
Old 02-12-2008, 07:12 AM   #13
Canadmos
Canadmos's Avatar
Holy crap.
Canadmos is offline   Reply With Quote
Old 02-12-2008, 09:12 AM   #14
IanY
I am Xtreme
You may want to order the Alphacool reservoir sponges because you may have a hell of a time bleeding those reservoirs in that configuration.
Beautiful job.
IanY is offline   Reply With Quote
Old 02-12-2008, 09:32 AM   #15
MrToad
I am Xtreme
MrToad's Avatar
After seeing the pics of your work I feel like ordering a skip and putting everything I've done so far in it, then take gardening as a hobby.
It looks amazing man. Great job.
MrToad is offline   Reply With Quote
Old 02-12-2008, 10:43 AM   #16
Waterlogged
I am Xtreme
Waterlogged's Avatar
DAMN VR! That's just the sweetest 343 I've ever seen. Primo A++ work there.
__________________
Waterlogged is offline   Reply With Quote
Old 02-12-2008, 10:48 AM   #17
RockfordFosgate
RockfordFosgate's Avatar
This is the most beautiful and creatiful 343b log Keep going men
__________________
Intel Core i7 920 D0 | Gigabyte EX58-UD4P | 3x1Gb OCZ 1600mhz | Gigabyte 8800GT Turboforce 820/2010 | 1TB Seagate | Samsung P2350 23'' | Silverstone Decathlon DA750W | Lian-Li PC777B | Logitech Z-5500 | Creative X-Fi|N97
Watercooling & Case mod soon...
Hardwarena Overclock Team
RockfordFosgate is offline   Reply With Quote
Old 02-12-2008, 11:15 AM   #18
FallenCow
FallenCow's Avatar
wow... this is the best build log i've had the pleasure of reading! Keep up the stellar quality... can't wait for the next update.
FallenCow is offline   Reply With Quote
Old 02-12-2008, 11:25 AM   #19
sobih25
sobih25's Avatar
really unbelievable
sobih25 is offline   Reply With Quote
Old 02-12-2008, 11:37 AM   #20
Fujimitsu
Fujimitsu's Avatar
Wow beautiful so far.
That case looks promising... I'm considering starting a cube case build (either this or MM) and this is greatly helpful.
Keep up the posting! :P:
__________________
XBOX Gamertag:Fujimitsu - I'm lonely, be my friend!
Fujimitsu is offline   Reply With Quote
Old 02-12-2008, 11:54 AM   #21
madmaxx
madmaxx's Avatar
WOW! just WOW!
the mod is SWEET! the log is SWEET! the pix SWEET!
everything is just wicked man
thnx for posting this
__________________
madmaxx is offline   Reply With Quote
Old 02-12-2008, 12:19 PM   #22
Scubar
I am Xtreme
Scubar's Avatar
This is going to be freakin awesome, i cant wait.
Scubar is offline   Reply With Quote
Old 02-12-2008, 12:28 PM   #23
trouble2000
Send a message via MSN to trouble2000
Excellent!
trouble2000 is offline   Reply With Quote
Old 02-12-2008, 12:36 PM   #24
biglipzit
I am Xtreme
biglipzit's Avatar
Send a message via AIM to biglipzit Send a message via MSN to biglipzit Send a message via Yahoo to biglipzit Send a message via Skype™ to biglipzit
The nickel plating everywhere is amazing!
__________________
Thermaltake Xaser VI Case
Gigabyte MA790FXT-UD5P
AMD Phenom II 955BE
Dual Sapphire 3870X2's
4 gigs of Kingston HyperX DDR3 333mhz
Coolermaster V10
Coolermaster UCP-1100W PSU
Originally Posted by {GOD}Raptor22
I find it exceedingly humorous how you sit here and continue to play keyboard warrior even though you know you are wrong.
biglipzit is offline   Reply With Quote
Old 02-12-2008, 01:52 PM   #25
k0nsl
k0nsl's Avatar
Send a message via MSN to k0nsl
Very ambitious work. I am following this thread with immense interest.
__________________
Intel Core2 Quad Q6600 @ 3.6GHz (xxx) | Asus Maximus Extreme | Dual PSU (1100W) | 2048MB Corsair DDRII | Asus HD 3850 512MB | Seagate Barracuda 7200.10 320GB X 2 in Raid 0 | Watercooled (CPU, GPU) | CM Stacker | Samsung Syncmaster 19" 970P
When you were born, you were crying and everyone around you was smiling. Live your life so that when you die, you're smiling and everyone around you is crying.
k0nsl is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
