XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Liquid Cooling > Liquid Cooling Worklogs
Reply
Old 09-28-2007, 02:07 PM   #1
Patriote
Patriote's Avatar
Project "XETM" - Worklog (56k Warning)
Hey guys!
EDITED: I will be using this thread to log the work of my up-coming project called "XETM". It'll consist on 2 8800GTXs, a QX6800ES G0, 4GB of RAM, Vista X64, Dual watercooling (1 CPU-NB-SB loop and 1 loop for the 2 GTXs) loop in a U2-UFO case etc...
________________________________________________
The goodies that i have ordered :
Xoxide.com order : (Arrived)
1 - Razer Tarantula Tempest Blue Gaming KeyBoard (Sent back for RMA...)
1 - ULTRA X3 1000w Modular Power Supply
1 - Steelpad QCK Heavy - Cloth Mouse Pad
1 - Xoxide Wire Sleeving Kit (Black) $8.99
1 - Enzotech Forged Copper Northbridge Heatsink - Low-Profile
Petra's Tech Shop order : (Arrived, Thanks Quoc And Alex!)
2 - EK-FC8800GTX Full Cover Waterblock for nVidia 8800 GTX
10 - Stainless Steel Worm-Drive Hose Clamp
17ft - 1/2" ID (3/4" OD) Tygon R-3603 Lab-Grade Tubing
1 - Arctic Cooling MX-2 Thermal Compound
2 - 120mm Scythe SFF21F S-FLEXT Case Fan (63.7 CFM/28 dBA)
3 - EK-FC8800 Replacement Voltage Regulator TIM Pads (I just hate to spread compound everywhere...)
1 - EK Multi-Option Reservoir Rev.2 Bottom
NCIX.com order : (Arrived, I love NCIX.com)
1 - Western Digital Raptor X 150GB 10000RPM NCQ SATA Hard Drive Windowed Top
1 - Corsair Dominator Airflow Memory Fan
1 - Mountain Mods Acrylic Case Feet Smokey Black (4 pack)
1 - Swiftech MCP355
1 - Petra's Top for that MCP355
1 - Sunbeam Tuniq Tower 120 (Not really for this project but more to test out all my stuff before i hook it under H2O)
1 - Highspeed PC Large Top Deck Tech Station FAST-ACCESS E-ATX Computer Case Black (Still not for the project)
2 - BFG GeForce 8800GTX OC2 626MHZ 768MB 2.0GHZ GDDR3
1 - G.SKILL F2-6400PHU2-2GBHZ PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-12 240PIN Dual Channel Memory Kit (+ the one i have ATM = 4GB for Vista X64)
Costco.ca order : (Arrived!)
1 - Dell UltraSharp 2407WFP-HC 24-in. LCD Display
Upcoming NCIX.com order : (Arrived!)
1 - Thermochill PA120.2 (Back-ordered so got refunded and ordered it @ Jab-Tech)
2 - Whatever barbs that will fit the Thermochill PA120.2 ...
2 - Gaskets for that PA120.2
+ Some UV Cathodes
+ Add to this a nice EVGA 680I A1 mobo from Turtletrax! Thanks man
EDIT: Second NCIX.com order :
(Arrived!)
1 - Thermochill Pa 120.2 Dual 120MM Fan Water Cooling Radiator *No Barbs* Back ordered so i am asking for refund and i placed an order elsewhere (Jab-Tech )
1 - Thermochill NG120.2 Neoprene Gasket for PA120.2 Radiator
1 - Klipsch Promedia 2.1 THX Computer Speaker System 160W RMS
1 - Danger Den 1/2IN Polyethylene Barb Fittings 3/8 NPT (Pair)
1 - Logisys CLK12GN2 12 inches Dual UV Cold Cathode Kit
Second EDIT :
Jab-Tech order :
(Arrived, Jab-Tech is awesome.)
Thermochill PA120.2
EDIT: I ordered some D-Tek nozzles, 17ft of Tygon R-3603 7/16" ID 5/8" OD Tubing, a second MCW30 for the SB, 2 Gel Pad for my pumps and Crysis! All from different stores (NCIX.com - Jab-Tech mainly.)
__________________________________________________ _______
The stuff i already have and plan on using on this build :
1 - Thermochill PA120.3 w/ the Aqua Extreme barbs
1 - MCP355 w/ Petra's top
1 - D-Tek FuZion WB
1 - MCW30 (For NB)
1 - Ek Multioption Res 150 (This one will be for the GPU loop)
1 - Performance PCs Cyclone Res (It hooks on a 120mm fan)
1 - U2-UFO Original top Black Powder Coated case
2 - Modded Zalman 6-channels Fan controllers
9 - Modded Fan grills
1 - LG Dual Layer DVD Burner
1 - X-FI Xtrememusic
1 - QX6800ES G0
1 - G.SKILL F2-6400PHU2-2GBHZ RAM kit
1 - WD SATA2 500GB HDD
1 - WD Caviar 250GB 16MB
1 - Vista Ultimate X64 ENG
+ about 10 kind of different additives...
+ about 3M of coolsleeves of different colors
+ a lot of Sound proof material (Maybe)
+ a lot of black sleeving
+ a sh*t load of different 120mm fans!
The planning!
Heres a few sketch-ups on how the 2 loops are going to be routed (Still, it might change) : EDIT: It has changed and now the looping will be different.
CPU loop : (Res - MCP355 - PA120.3 - FuZion - MCW30 - Back to Res)
GPU loop : (Res - MCP355 - PA120.2 - GPU1 - GPU2 - Back to Res)
Behind the mobo tray :
This is how my current rig looks like (Well looked like before i kill my 8800GTX...)
I will update this thread with more pics as more orders arrives. Then, the work will began! And more pics will be added for each steps so everyone can enjoy them.
Comments and suggestions are welcome!
__________________
• - EVGA 680I A1 (vdroop mod)
• - Intel QX6800ES G0 @ 3.95Ghz
• - SLI BFG 8800GTX OC2 @ 626Mhz \ 2000Mhz
• - 4GB G.SKILL F2-6400PHU2-HZ @ 1005Mhz
• - Ultra X3 1000 Watt Modular PSU
• - X-FI XtremeMusic \ Klipsch Promedia 2.1 THX 160W RMS
• - WD RaptorX 150GB \ WD Raptor 150GB \ Hitachi 1TB
• - Custom Modded CoolerMaster 810
• - Dell UltraSharp 2407WFP-HC 24''
Watercooling Loop #1 : D-Tek FuZion (Quad Core Nozzle) - 2x MCW30 (NB\SB) - T-Line + Fil-port - MCP355 w/ Petra's Top - Thermochill PA120.3 (3x Scythe SFF21F S-FLEX™) - Masterkleer 7/16" ID 5/8" OD
Watercooling Loop #2 : 2x Ek-FC 8800GTX WBs - Swiftech MCRES - MCP355 w/ Petra's Top - Thermochill PA120.2 (2x Scythe SFF21F S-FLEX™) - Masterkleer 7/16" ID 5/8" OD
X.E.T.M Completed
January - SLI Rig Of The Month
Patriote is offline   Reply With Quote
Old 09-28-2007, 02:08 PM   #2
Patriote
Patriote's Avatar
Update: Let the early Christmas begin!
Xoxide.com order has arrived!
Man, that keyboard looks awesome! But OMFG! That Mousepad is huge! Thick and large!!1 It'll never fit on my current desk... Wow!
EDIT: Check the size of that mousepad!
My mouse looks lost on that thing!
The size of my old mousepad on that thing just looks ridiculous!
I am getting a new desk pretty soon so i should keep in mind that ill have to hook such mousepad on it
Check out that awesome keyboard!
More pics! The Ultra X3 PSU
The most gorgeous PSU i have ever seen in my life! The sleeving* on the cables is just amazing. The cables bends so easy, it'll be a real pleasure to route them in my case. Also the way the cables connect to the PSU is just amazing!
Update: As i said earlier, i have some pics of my new Desk! I re-arranged my room too!
My watercooling shelf!
Looks good eh! 149.99$ for that desk!
PS: For the Video lovers, i have recorded a small 2 mins video of my room. It's on Youtube : http://www.youtube.com/watch?v=EcOHZEVLSNU Enjoy
__________________________________________________ ______________________
Update: Look what the Canada Post guy gave me today!
Gorgeous blocks, more Tubing (I have around 40ft of tubing total. 20ft of Masterkleer (cr@p) tubing and 17ft or Tygon 1/2" ID 3/4" OD. I originally bought the Masterkleer months ago but i felt it was awful and not pleasant to work with, so i trashed it on my desk and used Tygon Tubing instead. I now use it as a safe Tubing... ), Rev.2 bottom EK res for my Ek 150 Res, Some Ek barbs, some Worm drives and finally, 2 Scythes fans for my up-coming PA120.2.
__________________
X.E.T.M Completed
Old 09-28-2007, 02:09 PM   #3
Patriote
Patriote's Avatar
BIG UPDATE!
My biggest NCIX.com order has arrived!
Poor desk can't handle the weight lol!
What i received in that order :
1 - Swiftech MCP355
Comments are welcome Ima going to build the Tech station (which i will be using as a bench table) pretty much tonight and ill post more pics!
Just finished building that nice little new Bench table... I had to drive and drop a comp to one of my customer... Anyway, Pics!
Working on it...
PS: I just got an e-mail back from Xoxide.com's customer support and it seems that i need to pay for shipping back the keyboard to them Imagine guys, that makes the damn keyboard worth around 140$ USD... The next one better be freaking 100% working!
8800GTXs pics
Let the early Christmas continue! More stuff arrived today!
Look at that gorgeous 24" monitor! My only concern is that either my desk or floor isn't straight which makes one side of the monitor to lean. Hooked something under the leg and all is good. Maybe it is a default with the supporting arm of the monitor too. Oh well, i can live with that
Here i prepared the pump for usage Also sleeved it.
Mounted the Tuniq with the back-plate and some neopropene to prevent shorts.
Only thing remaining to arrive is my PA120.2 from Jab-Tech should be here Monday or Tuesday.
PS: Tonight im working on hooking everything onto the Bench table and running on air just for testing. Then, tomorrow, i'll work on disassembling my U2-UFO and preparing it for the watercooling loops
UPDATE!
I just finished cleaning my room and assembling the rig on my bench table. I haven't hooked all 4GB and my X-FI Xtrememusic sound card yet. I will do when i know that everything is working great. Now comes the time to press the power button and i am nervous. Will everything boot up fine? I doubt it. There is always something going wrong on first boot for me...
RaptorX 150GB shot
Small Update!
Look what i received today
A nice Thermochill PA120.2 with some gaskets and Polypropene barbs since it's IMPOSSIBLE to find metallic barbs for that rad...
I think it can't be more clear than that... I didn't knew Thermochill had included that message with there Rads. I guess Hot water it'll be then!
My new EVGA 680I A1 is scheduled to be here on October 18-19th.. Until that time, ill clean my PA120.2, prepare my case, start the watercooling etc... Will updates as work gets slowly done!
Update!
Well, while im patiently waiting for the new mobo to arrive, i decided to start working on the case and watercooling stuff. So firstly, what i did was to take that defective EVGA 680I A1 and put it back into it's box and get ready to ship it back for RMA. I took my P5B Deluxe and hooked all my stuff on it and installed Vista Ultimate X64.
Then i started cleaning the case since the P5B Deluxe + mobo tray were out the case. I removed the watercooling loop, cleaned the case (Dust, sticky parts due to tape etc..).
As you guys can see, pretty much all wires\cables are already sleeved I had to sleeve the 2 fans for the back PA120.2 tho.
Once the case cleaning was done, i ran HOT water for a good 5mins through my new PA120.2.
Good idea eh!
Once all clean, i hooked the gaskets, the fans and in the case it went
After all that, i went to bed for 3 long hours (...) before going to work @ 6AM today.
Now im back and i'll work on disassembling my loop, clean the parts and hook the PA120.3 back into the case and ready for watercooling Once the new board gets home ill make sure that it's fully working, i might do the vdroop pencil mod and then it'll go under watercooling! Updates will follow...
__________________
X.E.T.M Completed
Old 09-28-2007, 02:09 PM   #4
Patriote
Patriote's Avatar
Update! October 21-07 Check page #6! (Direct Link : http://www.xtremesystems.org/forums/...postcount=148)
Updates will now be posted as replies since the first page was getting way too long to load...
Update! November 02-2007 Check page #7! (Direct Link : http://www.xtremesystems.org/forums/...postcount=161)
Small Update! November 05-2007 Check page #7! (Direct Link : http://www.xtremesystems.org/forums/...postcount=172)
Update! November 06-2007 Check page #8! (Direct Link : http://www.xtremesystems.org/forums/...postcount=188)
Update! November 08-2007 Check page #8! (Direct Link : http://www.xtremesystems.org/forums/...postcount=196)
Update! November 13-2007 Check page #9! (Direct Link : http://www.xtremesystems.org/forums/...postcount=211)
Small Update! November 14-2007 Check page #9! (Direct Link : http://www.xtremesystems.org/forums/...postcount=215)
Update! November 20-2007 Check page #9! (Direct Link : http://www.xtremesystems.org/forums/...postcount=221)
Update! November 24-2007 Check page #10! (Direct Link : http://www.xtremesystems.org/forums/...postcount=250)
Small Update! November 24-07 (Direct Link : http://www.xtremesystems.org/forums/...postcount=252)
DA BIG UPDATE! December 10-07 (Direct Link : http://www.xtremesystems.org/forums/...postcount=291)
__________________
X.E.T.M Completed
Old 09-28-2007, 02:30 PM   #5
louie101086
Send a message via AIM to louie101086
how good is that razer keyboard because i was wondering about getting that or a g15
__________________
MY RIG: BLUE DEVIL
CASE*BLACK SILVERSTONE TJ07-MODIFIED
MONITER*32-INCH SAMSUNG WIDESCREEN LCD TV
OS*MICROSOFT XP HOME EDITION SP3
MB*GIGABYTE P35-DQ6 F9B BIOS
CPU*INTEL E7200 3.6GHZ 1.3v
RAM*2GB G.SKILL PK PC8500**DEAD**
PSU*PC POWER&COOLING BLACK QUAD 750W
HD*SATA MAXTOR 150GB 8MB CACHE & SATA WD 250 GB 16MB CACHE
GPU*GIGABYTE HD4670 @ 811/1100
MY WATERCOOLING SETUP
CPU*SWIFTECH APOGEE GTZ
PUMP*SWIFTECH MCP 655
RAD*SWIFTECH MCR320 W/ 3 SCYTHE ULTRA KAZE MED. SPEED
RES*T-LINE
TUBING*DURELENE PVC
COOLANT*DISTILLED WATER & PT NUKE
WORKLOG-Blue Devil TJ07
WORKLOG-Project X
louie101086 is offline   Reply With Quote
Old 09-28-2007, 03:17 PM   #6
Patriote
Patriote's Avatar
It's freaking great! Only been using it since a few hours and so far, i am impressed. The Saitek Eclipse or the G15 are nothing compared to this keyboard i tell you!
__________________
X.E.T.M Completed
Old 09-28-2007, 05:30 PM   #7
Senater_Cache
Senater_Cache's Avatar
an ultra PSU?
Senater_Cache is offline   Reply With Quote
Old 09-28-2007, 05:47 PM   #8
dunn2953
They are no where near as bad as the used to be
__________________
CPU:X3210 G0@3.6 (8x450 1.48v)
MOBO: Asus P5K Premium, bios 402
RAM: 4x 1GB DDR2-1066 @ 1080 5-5-5-15 2.3v
CASE: antec 900
GPU: XFX GeForce 7900gt @600/1900
PSU: silverstone OP1000
Cooling: MCP655, Apogee GT, MCR320-QP-K
dunn2953 is offline   Reply With Quote
Old 09-28-2007, 05:56 PM   #9
Patriote
Patriote's Avatar
Indeed! 2 years ago, i had promised myself never to buy an Ultra PSU again! But hey, guess what? I did it again! And i think i did a safe choice right here. This PSU keeps getting good reviews all over. I tell you this, i haven't tried it yet, but it looks like one hell of a PSU!
__________________
X.E.T.M Completed
Old 09-28-2007, 06:12 PM   #10
disruptfam
I am Xtreme
disruptfam's Avatar
Send a message via MSN to disruptfam
looking good so far...
I love getting my pc stuff in the mail...Like you said Christmas comes early lol and alot more frequently
i got some ad900's headphone's and a prelude sound card yesterday..Christmas indeed...
__________________
Originally Posted by skinnee View Post
No, I think he had a date tonight...
He and his EK Supreme are out for a night on the town!
disruptfam is offline   Reply With Quote
Old 09-28-2007, 06:19 PM   #11
CedricFP
CedricFP's Avatar
Oh man, I'm really excited for this build.
Good luck with everything! You got some great parts coming in.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
CedricFP is offline   Reply With Quote
Old 09-28-2007, 06:24 PM   #12
Patriote
Patriote's Avatar
Thanks guys I am so excited too! But nervous when i think of the load i put on my credit card
__________________
X.E.T.M Completed
Old 09-28-2007, 06:31 PM   #13
disruptfam
I am Xtreme
disruptfam's Avatar
__________________
well when you work hard for your $$$ why can't spoil we ourselves every now and then......
__________________
Old 09-28-2007, 07:06 PM   #14
AliG
Xtreme Mentor
AliG's Avatar
wow....This thing is going to be a beast for sure. I'm definitely subscribing this
__________________
Originally Posted by Piotrsama View Post
Thousands of Mac users are worried because they might be experiencing the same problem.
Black screen when they turn their Macs off......
(j/k )
AliG is offline   Reply With Quote
Old 09-28-2007, 07:35 PM   #15
TheSamurai
i told you it was a nice psu!!!
TheSamurai is offline   Reply With Quote
Old 09-28-2007, 07:41 PM   #16
Patriote
Patriote's Avatar
Heh thanks guys Yeah, definitely a nice PSU. Now let's hope it'll power-up all my stuff without a problem and that it'll stay nice for years!
Can't wait to get my order from NCIX.com Monday!
__________________
X.E.T.M Completed
Old 09-28-2007, 08:43 PM   #17
IanY
I am Xtreme
Congratulations
IanY is offline   Reply With Quote
Old 09-28-2007, 08:46 PM   #18
Polizei
Xtreme Cruncher
Polizei's Avatar
Send a message via AIM to Polizei
Because some of us have girlfriends, lol. Shes why I cant spoil myself.
__________________
Polizei is offline   Reply With Quote
Old 09-28-2007, 08:50 PM   #19
Patriote
Patriote's Avatar
Originally Posted by IanY View Post
Congratulations
Thanks!
Mine won't say a word because she respect what i like
__________________
X.E.T.M Completed
Old 09-28-2007, 08:57 PM   #20
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
Or just having all your money (and then some) reserved to pay off stuff... bleh
Gonna watch this one, sounds cool
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is offline   Reply With Quote
Old 09-29-2007, 12:32 AM   #21
disruptfam
I am Xtreme
disruptfam's Avatar
mate... my gf ain't a leach..not saying your's is..but
It's 50/50 relationship
not like 80/20 like my last gf lol
my gf atm actually bought me some of my computer stuff...
Hows that for a awesome mrs!!!!
__________________
Old 09-29-2007, 01:25 AM   #22
Grafton
Xtreme Cruncher
Grafton's Avatar
Send a message via AIM to Grafton
my wife plays cs:s with me top that. oh btw nice build in progress
__________________
CPU Q6600 @ 3.15Ghz D-tek CPU Block
GIGABYTE GA-EP45-UD3R 350Mhz FSB
RAM G.SKILL F2-8500CL5D-2GBHK DDR2 1066
GPU Nvidia 8800GT MCW-60 700Mhz Core 1.0 GHz Mem
PSU Cooler Master realPower 550W
Storage 3 500 GB WD Caviar SE16 in RAID 5
Misc. CM stacker STC-T01 w/ Cross-flow fan, 2 MCR-320 Rads, DCC 355 W/ Petras Top, 12 YateLoon D12SL-12, ~12ft Tygon 9/16 ID tubing
Crunching for [XS]
Grafton is offline   Reply With Quote
Old 09-29-2007, 02:51 AM   #23
disruptfam
I am Xtreme
disruptfam's Avatar
lol im beaten
my mrs only plays age of empires 3 and chess on vista lmao
i like neither.... haha
__________________
Old 09-29-2007, 04:00 AM   #24
septim
Banned
Send a message via Yahoo to septim
girlfriend or wives with the big 2x4 stick...
looking forward to this revision of yours Patriote...
christmas comes early...
septim is offline   Reply With Quote
Old 09-29-2007, 07:31 PM   #25
BNDMOD
BNDMOD's Avatar
Send a message via MSN to BNDMOD Send a message via Skype™ to BNDMOD
Suscribed!!!
__________________
iMac 24''
BNDMOD @
Cruz Alta (Cba.) Argentina
BNDMOD is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
