Hey,
Alright, Ill start off by saying, that Ive done 3 re-mounts, with different AS5 / MX-2 Applications, and all 3 have yielded me the same results. Almost the same anyways.
Im running a DTek Fuzion with the 4.5mm Nozzle (Earlier I was running the Quad Nozzle, as I was using my Quad).. Temp's have improved by 4C, just because of that.
Ambients : 24-25C
My Load temp's are ~63/63C ... Prime takes it upto 65/65.
Last night, when the Ambients were 21C, Temp's were 61/61C Prime Loaded.
Only thing I can think of is that either coretemp is wrong, or the VID coretemp shows is correct.
I tried testing 333x9 @ the lowest vCore I could (1.200 BIOS Set, 1.110v Loaded Prime), It was stable for 1 hour, then I shut it, since I wanted to OC :P). Temp's during that run, were like 55/55C Prime Load.
Im running rock solid stable, Prime completed 9 hours this morning @ 4.3Ghz @ 1.39vCore Load.
Oh, Contact is perfect as well...
What could be the problem?
