Results 1 to 14 of 14
Thread: E8400 Temps on P5K-Premium
    Mar 2006
    I'm seeing some strange #'s on coretemp on my board (P5K Premium BIOS 0504)
    I have this machine overclocked to 4G 9x444 with voltage in the BIOS @ 1.3375
    At idle the voltage is 1.312 and temps reported by Coretemp are about 55
    Under Load the voltage is 1.288 and temps reported by Coretemp are about 77!
    PC Probe is reporting 60 under load
    I've been stress testing assuming these temps cant be accurate, but now i'm starting to get worried. The machine is stable at these temps and volts though.
    When I was running the machine at stock settings the temps werent much better, probably about 10 degrees difference
    Anyone have the same experiences, could it be the BIOS and the new wolfdales or just some wolfdales?
    BATCH: Q746A514, friend has a Q746* as well with a P5K-E with the same problems
    Apr 2007
    Sweden
    None have figured this out yet, maybe some bad IHS, or the bios? OR the programs out there are not fineadjusted to handle these new cpu's..
    no one actually knows yet, check around and keep a look out, sometime we will get whats up
    Intel i7 920@ ???| Inno3D 8800GT OC Edition | 3x1 Corsair 1600 DHX | DFI UT-X58 | TT ToughPower 850W
    Watercooling: D-Tek FuZion V2, DDC Ultra Plexi top, PA120.3, MCW60, Ek's Res.
    Jun 2003
    It is a problem with the cpu per the core temp person. Read the link at the end if want more info.
    "There can not be any bugs in retreiving the temps because if there was something wrong, it wouldn't have worked at all, on any CPU (as the code is identical for all Yonah, Conroe and Penryn).
    Anyway there seems to be a major issue with DTS and 45nm..."
    http://www.alcpu.com/forums/viewtopic.php?t=372
    Nov 2007
    i have the same build as yours, 8400 and p5k premium, but i am using the 0404 bios.
    with watercooling, apogee gtx block, i have 38c-39c idle when running at 4320mhz at 1.368v. and 58c-59c load.
    Nov 2007
    I had the same problem with my MARS. I guess its due to the BIOS?
    Intel Inside
    Xtreme Cruncher
    Sep 2005
    Bay Area, CA
    Quote Originally Posted by aoch88 View Post
    Nope, its the chips itself.
    Mar 2006
    Quote Originally Posted by Bail_w View Post
    Bail do you mean the 8400 Chip or the Chipset (P35)?
    Xtreme Cruncher
    Sep 2005
    Bay Area, CA
    It could be the IHS and Core contact was not prefect or it could be something elese related to the CPU.
    Feb 2006
    Richmond, VA
    Quote Originally Posted by haoster View Post
    I didn't think the 0404 bios would run an E8400... if it does... that's great news. Can you confirm its 0404 and not 0504?
    Nov 2004
    Norway
    Would appreciate a confirmation on this as well
    (Like what i'm reading about this cpu - don't like what i've read about the 0504 bios..)
    ASUS P5K Premium 2.00G/A02 - Bios 1101
    Q9650 @ 4.0@1.30 - 24/7
    Corsair 4 x 2048 8500 C5
    ASUS HD 6950 2 GB.
    Cooling: PA 120.3 w/ shroud. (CPU / GPU / NB)
    Mist 800W
    Lian Li PC-A7010
    Jan 2008
    I agree it's a problem with the CPUs not the mobo, but I don't think it matters. Intel raised TjMax by 30 degrees compared to 65nm chips for a reason and surely measuring how far away from that you are via CoreTemp is a reliable indication of whether you're running too hot.
    I've run chips much hotter than this, the heatsinks generally got too hot to touch and they still ran fine. My old P4's blackened the copper heatsinks because they got so hot, ran at 85 degrees 24/7 and never had a problem. This E8200 can't even warm my IFX-14 up...
    With actual 1.44 vCore under load I'm TjMax - 35 (70 / 105) on air, around the same as my 65nm which was TjMax - 32 (47 / 75)? Fine I tell ye!!
    At the end of the day: cold heatsink + TjMax-30 = np
    Nov 2007
    Quote Originally Posted by Kilyin View Post
    the 0404 bios for p5k-premium runs e8400 very well. i have been running it with 0404 for a week now. not a single problem.
    actually i think the best bios for 8400 is still the 0404. since 0504 has a lot of memory bandwidth fall back
    for the high temp problem, i dont have it at the first day i installed my 8400, everything seemed normal. 4320mhz @ 1.368v underload at 59c. idle at 39c-40c. and both core pretty much have the same temp at the same time.
    but now, after i changed my waterblock from gtx to gt. the temp went up. with lower clock and the same volts(cpu degraded i think), 4230mhz @1.368v. underload at 69c (10c difference). idle at 43c. i have mounted the waterblock for about 5 times, and everything else remained the same. so now i dont know if the waterblock really could cause so much temp difference, or its something else.
    and i have tried both the 0404 and 0504. both show the same temp.
    May 2005
    I reseated the heatsink 3 times with no change in temps. Mine reports 50 idle 70 load, but the heatsink doesn't get warmer than room temp.
    E8400, Asus P5Q-D, GTX280, X-fi music, 4X1GB D9's, Scythe Ninja, corsair 620
    I am Xtreme
    Jul 2005
    Quote Originally Posted by zizo View Post
    Hmm that would imply a sensor/program problem and not necessarily a heat problem.
    The main thread is here
    [SIGPIC][/SIGPIC]
