Results 1 to 23 of 23
Thread: OC QX6700 Asus Maximus Formula SE
    Dec 2007
    Stockholm Sweden
    Starting this thread to collect information about bios settings for the
    QX6700 and the asus maximus formula SE.
    Water cooled or not.
    Looking to collect settings for OC above 3.6Mhz
    Prefere Bios template taken
    (from Asus Maximus Formula *Part 2* *Help / Overclocking / Guide*
    http://www.xtremesystems.org/forums/...d.php?t=168119)
    Extreme Tweaker
    Ai Overclock Tuner : Manual
    OC From CPU Level Up : AUTO
    CPU Ratio Control : Manual
    - Ratio CMOS Setting :
    FSB Frequency :
    FSB Strap to North Bridge :
    PCI-E Frequency:
    DRAM Frequency: DDR2-
    DRAM Command Rate :
    DRAM Timing Control: Manual
    CAS# Latency :
    RAS# to CAS# Delay :
    RAS# Precharge :
    RAS# ActivateTime :
    RAS# to RAS# Delay :
    Row Refresh Cycle Time :
    Write Recovery Time :
    Read to Precharge Time :
    Read to Write Delay (S/D) :
    Write to Read Delay (S) :
    Write to Read Delay (D) :
    Read to Read Delay (S) :
    Read to Read Delay (D) :
    Write to Write Delay (S) :
    Write to Write Delay (D) :
    DRAM Static Read Control:
    Ai Clock Twister :
    Transaction Booster :
    CPU Voltage :
    CPU PLL Voltage :
    North Bridge Voltage :
    DRAM Voltage :
    FSB Termination Voltage :
    South Bridge Voltage :
    Loadline Calibration :
    CPU GTL Reference :
    North Bridge GTL Reference :
    DDR2 Channel A REF Voltage :
    DDR2 Channel B REF Voltage :
    DDR2 Controller REF Voltage :
    SB 1.5V Voltage :
    NB LED Selection : NB Volt
    SB LED Selection : SB Volt
    CPU LED Selection : CPU VOlt
    Voltiminder LED :
    Advanced CPU Configuration
    C1E Suppport : Disabled
    CPU TM Function : Disabled
    Vanderpool Technology : Disabled
    Execute Disable Bit : Disabled
    Max CPUID Value Limit : Disabled
    USB Configuration
    USB Functions: Enabled
    Legacy USB Support : Disabled
    [Asus P8Z77 WS Z77] [i7 3770K] [Apogee HD waterblock]
    [16GB G.Skill DDR3 PC3-19200 2400MHz TridentX Series CL10 (10-12-12-31) Dual Channel kit]
    [Zotac GTX 680][Watercool Heatkiller GPU-X3 GTX680 Hole]
    [2x ThermoChill PA120.3][2x Laing DDC-1T-PLUS - XSPC Dual 5.25"Bay Reservoir ][Stacker 832][PSU:ThermalTake 1200W][2x 24" Screens BenQ G2420]
    Current Rig ASUS P8Z77 WS - ATX / Z77 Intel Core i7-3770K CM Stacker + 2nd WC Casehttp://img49.imageshack.us/my.php?image=pict0157dh0.jpg
    Project Blue Orbit - Phase 2
    http://www.xtremesystems.org/forums/...d.php?t=243865
    Build With MIPS freezers NB,SB,Mosfets
    Dec 2007
    Stockholm Sweden
    Extreme Tweaker 3,680 mhz
    Ai Overclock Tuner : Manual manual
    OC From CPU Level Up : AUTO auto
    CPU Ratio Control : Manual 8
    FSB Frequency : 460
    FSB Strap to North Bridge : 400
    PCI-E Frequency: 100
    DRAM Frequency: DDR2- 920
    DRAM Command Rate : 2
    DRAM Timing Control: Manual manual
    CAS# Latency : 5
    RAS# to CAS# Delay : 5
    RAS# Precharge : 5
    RAS# ActivateTime : 15
    RAS# to RAS# Delay : auto
    Row Refresh Cycle Time : auto
    Write Recovery Time : auto
    Read to Precharge Time : auto
    Read to Write Delay (S/D) : auto
    Write to Read Delay (S) : auto
    Write to Read Delay (D) : auto
    Read to Read Delay (S) : auto
    Read to Read Delay (D) : auto
    Write to Write Delay (S) : auto
    Write to Write Delay (D) : auto
    DRAM Static Read Control: auto
    Ai Clock Twister : auto
    Transaction Booster : auto
    CPU Voltage : 1,50625V
    CPU PLL Voltage : auto
    North Bridge Voltage : 1,65V (1,71V in everest)
    DRAM Voltage : 2,18V (2,32V in everest)
    FSB Termination Voltage : 1,52v
    South Bridge Voltage : 1,075v
    Loadline Calibration : enable
    CPU GTL Reference : auto
    North Bridge GTL Reference : auto
    DDR2 Channel A REF Voltage : auto
    DDR2 Channel B REF Voltage : ddr ref
    DDR2 Controller REF Voltage : auto
    SB 1.5V Voltage : auto
    NB LED Selection : NB Volt NB Volt
    SB LED Selection : SB Volt SB Volt
    CPU LED Selection : CPU VOlt Cpu Volt
    Voltiminder LED : enable
    USB Configuration
    Administrator
    Nov 2007
    Stockton, CA
    This is the template that I used. It was awhile ago and I cannot seem to remember what I did to get to 3.8ghz. I know it started getting pretty hot so I decided not to push it until I get a better cooling setup.
    This is for a 3.6 Ghz OC with a QX6700
    This is with the stock BIOS or 0401. I will update that in a bit after I finish
    backing up everything. Not real sure which is a good working BIOS atm and
    reading through these threads, 902,903 seem to give others problems and
    hard to flash backwards. I think I have seen a few posts with 602 or 802
    that seem to work fine.
    I used the basic setup from the first post and worked from there. Using a
    8x450 would not post for me, even up to CPU 1.5v. At that point I changed
    to 9x400 and it went smooth. Ended up dropping to CPU 1.468v and that has
    been stable all day.
    So in the end I just wanted to give this BIOS a shot to see what it could do.
    In Everest it shows the CPU temp, then the temps for all 4 cores which seem
    to be higher temp's. Which are the correct temps ?
    I will most likely not Prime this as I will update the BIOS and will do it then.
    And Thanks a bunch for this updated thread !
    Ai Overclock Tuner [Manual]
    OC From CPU Level Up [Auto]
    CPU Ratio Control [Manual]
    Ratio CMOS Setting: [9]
    FSB Frequency [400]
    FSB Strap to North Bridge [400MHz]
    PCIE Frequency [100]
    DRAM Settings
    DRAM Frequency [Auto]
    DRAM Command Rate [2T]
    DRAM Timing Control [manual]
    CAS# Latency [5]
    RAS# to CAS Delay [5]
    RAS# Precharge [5]
    RAS# Active Time [12]
    RAS# To Ras# Delay [3]
    Row Refresh Cycle Time [42]
    Write Recovery Time [6]
    Read To Precharge Time [3]
    Read To Write Delay(S/D) [8]
    Write To Read Delay(S) [3]
    Write To Read Delay(D) [5]
    Read To Read Delay(S) [4]
    Read To Read Delay(D) [6]
    Write To Write Delay(S) [4]
    Write To Write Delay(D) [6]
    DRAM Static Read Control [Disabled]
    Ai Clock Twister [Light]
    Transaction Booster [Enabled]
    Boost Level [0]
    Voltage Settings
    CPU Voltage [1.468v]
    CPU PLL Voltage [Auto]
    North Bridge Voltage [1.49v]
    DRAM Voltage [2.1v]
    FSB Termination Voltage [1.4v]
    South Bridge Voltage [Auto]
    Loadline Calibration [Enabled]
    CPU GTL Reference [0.63x]
    North Bridge GTL Reference [0.67x]
    DDR2 Channel A REF Voltage [Auto]
    DDR2 Channel B REF Voltage [Auto]
    DDR2 Controller REF Voltage [DDR2_REF]
    SB 1.5V Voltage [Auto]
    CPU Spread Spectrum [Disabled]
    PCIE Spread Spectrum [Disabled]
    Dec 2007
    Stockholm Sweden
    Quote Originally Posted by Buckeye View Post
    Thank you for the post!
    Dec 2007
    Stockholm Sweden
    Extreme Tweaker 3,600 mhz
    CPU Ratio Control : 8
    FSB Frequency : 450
    DRAM Frequency: DDR2- 900
    CAS# Latency : 4
    RAS# to CAS# Delay : 4
    RAS# Precharge : 4
    RAS# ActivateTime : 12
    CPU Voltage : 1,48125V
    North Bridge Voltage : 1,57V (1,63V in everest)
    FSB Termination Voltage : 1,54v
    Above tested with Prime95:Ok
    Dec 2007
    Stockholm Sweden
    Prime95 1 hour test
    Prime95 1 hour test
    This test was performed with the following settings
    QX6700, 3.6Ghz
    Ambient 18.1c NB 28c
    By neo_rtr at 2008-03-05
    Dec 2007
    Stockholm Sweden
    By neo_rtr at 2008-03-08
    Dec 2007
    Stockholm Sweden
    Corsair Dominator 4096MB PC2-8500 1066MHz (5-5-5-15) (2x2048MB) (TWIN2X4096-8500C5DF)
    By neo_rtr at 2008-08-04
    I changed the memory to Corsair Dominator 4096MB PC2-8500 1066MHz (5-5-5-15) (2x2048MB) (TWIN2X4096-8500C5DF)
    I can run them at 8x444 nothing above that. PS OS is now vista 64bit as well
    Dec 2007
    Stockholm Sweden
    Hmm iam doing 10x380
    dont pay attention to the memory timinings will take a look at them.
    the good thing is that i was able to do 3,8Ghz something that was not possible before, will stíll need to finetune
    By neo_rtr at 2008-08-07
    Apr 2008
    nice results
    Dec 2007
    Stockholm Sweden
    Cm2x2048-8500c5d
    By neo_rtr at 2008-08-08
    sample
    EDIT: The PLL is set to 1.56V this comes up as 1.712V reportd by BIOS
    I have try it 3 times (SET in Bios 1.66v, 160V & 1.56V) and appears that my system is stable in Prime p95v256 (so far)
    Just to say that this is with Bios 12.07
    Dec 2007
    Stockholm Sweden
    iam getting hard time to get it stable at 10x380. any ideas any one
    iwould like to see if any of you guys has a suggestion at to the volts this CPU needs.
    PS Bios 12.07.
    thank you
    Dec 2007
    Stockholm Sweden
    Some better memory timings
    8x 455 with 5 5 5 12 . 3 45 6 3 ,
    By neo_rtr at 2008-08-14
    Dec 2007
    Stockholm Sweden
    I have some new results
    FSB Frequency : 450
    By neo_rtr, shot with DiMAGE X1 at 2009-02-11
    By neo_rtr at 2009-02-11
    Dec 2007
    Stockholm Sweden
    Doing it the wrong way
    Perfect example that going up is not always the direction one should choose.
    But for some time now been trying to get it to work.
    My goal was 3.8ghz. At some point i did a cross flash as i call it to the RAMPAGE bios. 8202
    It proven to be one of the best things ever. No i have not reach my goal but now days what ever i put on it it will boot.
    Any way. been surfing alot to get some more info. This QX6700 is not so commons and by now almost no one using it.
    In search of the sunrise has to redo bios settings and from what you can see from previous posts they where high.
    So far i have managed to take them down a bit.
    One thing i can tell you for sure is that 8x450 fsb needs that 1.50V FSB Termination Voltage. (have tryied almost anything and i found countless ways NOT to do it that way).
    So 1.50V FSB and 1.53V NorthBridge works for me.
    By neo_rtr, shot with DiMAGE X1 at 2009-02-13
    By neo_rtr at 2009-02-13
    Also notice that the CPU Voltage is now down to 1.46875V / 1.54V CPU PLL
    Iam quite sure that there is room from improvment.
    One thing i did notice is that taking the CPU voltage 1 click down, I had to take the PLL 1 click down as well. If not, Prime failed on around the 7 or 8th loop.
    Also when prime fails going up one click in voltage Do Not always work.
    Will not argue that , just an observation. Be flexible! and take your time. It does take time this OC business.
    Dec 2007
    Stockholm Sweden
    Lowest QX6700 3.6Ghz 8x450
    this is the lowest Prime 95 result i can get
    By neo_rtr, shot with DiMAGE X1 at 2009-02-14
    By neo_rtr at 2009-02-14
    Dec 2007
    Stockholm Sweden
  18. #18
    Dec 2007
    Stockholm Sweden
    FYI
    Quote Originally Posted by Roger_D25 View Post
    Thanks A-Gray and mikeyakame for helping out with my questions, its greatly appreciated! By the way A-Gray how does Prime failing in SmallFFT's or LargeFFT's help determine what the problem may be or determine what CPU/NB GTL settings you should use?
    Quote Originally Posted by mikeyakame View Post
    Small FFT uses L1/L2 cache for calculations so its more likely to be CPU GTL Ref.
    Large FFT uses DRAM so it crosses cross clocking boundaries of MCH/DRAM so it could be more likely DRAM Clock Skews or NB GTL Ref.
  19. #19
    Jun 2002
    I only care about 24/7 clocks with low / safe volts, so I don't have a max cpu clock screenshot.
    I am aircooled, and this is what I use for 24/7 with QX6700 and Maximus II Formula.
    All the voltages and temps are there on the pics.
    500FSB (3.5GHz) DDR2-1000 5-5-5-18-2T - 7h prime + 20 IBT loops (full loaded temps showed by everest)
    494FSB (3.46GHz) DDR2-1186 5-5-5-18-2T - 4h prime + 10 IBT loops (idle temps showed by everest)
    []'s
    Simps
  20. #20
    Dec 2007
    Stockholm Sweden
    Great News, Thanks for the Post. If you have anything around 3.8Ghz i love to know.
  21. #21
    Dec 2007
    Stockholm Sweden
    FSB to 345 or 380mhz, and multiplier to 11 or 10x fails BSOD v up 1.6v
    testing prime
    NB GTL x.67- CPU GTL x.63 - 1.50v ok custom
    NB GTL x.67- CPU GTL x.65 - 1.50v fails custom
    NB GTL x.67- CPU GTL x.63 - 1.52v fails custom small FFT
    NB GTL x.67- CPU GTL x.65 - 1.52v fails custom
    NB GTL x.67- CPU GTL x.65 - 1.55v ok custom
    NB GTL x.67- CPU GTL x.65 - 1.48v ok custom
    NB GTL x.67- CPU GTL x.63 - 1.46v ok custom
    NB GTL x.67- CPU GTL x.63 - 1.44v fails small FTT
    NB GTL x.63- CPU GTL x.65 - 1.46v fails small FTT
    NB GTL x.63- CPU GTL x.65 - 1.50v fails small FTT around 12th cycle
    NB GTL x.67- CPU GTL x.65 - 1.50v fails small FTT with +1Cpu & pll Vtls
    customīmode works much better ???
    Passed Small FFT
    NB GTL x.67- CPU GTL x.63 - 1.52v . CPU 1.46875v CPU PLL 1.56v NB 1.55v meaning i had to go +1 click on the vlts
    By neo_rtr at 2009-02-26
    By neo_rtr, shot with DiMAGE X1 at 2009-02-26
  22. #22
    Dec 2007
    Stockholm Sweden
    Quote Originally Posted by A-Grey View Post
    Try to run Prime95 Small FFT's to adjust your CPU Voltage and your FSB termination Voltage and Prime95 Large FFT's for your NB Voltage.
    When you've got that stable for 10-15 minutes you can run Linx to tweak your GTL's in combination with the FSB Termination Voltage and adjusting the CPU Voltage.
    When you can run 25 passes stable in Linx you can go to Prime95 again and run Blend Mode to see what needs to be done to keep it stable for a long time.
    When you still fail Large FFT's it is your NB or FSB Termination Voltage.
    For Ref..
  23. #23
    Dec 2007
    Stockholm Sweden
    qx6700 bios settings
    QX6700 Asus Rampage 0803 Bios Settings
    By neo_rtr, shot with DiMAGE X1 at 2009-05-15
    By neo_rtr at 2009-05-15
    By neo_rtr at 2009-05-15 Will have to work with the timings
    Lower Volt Prime95 stable Small and Large FTTs with total test time about 2hrs-
