THESE parts ALL inside a ThermaltakeArmor ok?
i'm finally building a water cooled system and i just wanted to run the parts on here for other opinions first. all these parts are going to be going in a thermaltake armor:
pump- liang ddc2 with petra top
rad- PA120.2
res- EK-RES150
cpu- fuzion
gpu- MCW60
NB- MCW30
tubes- 7/16"
fans- 2x yate loons
i really want to only spend about $300-350, but $400 is the MAX i want to spend for parts and this brings me exactly to $400 (+/- few dollars). if i had to lower the performance just a little, which part should i sacrifice for a cheaper one? i know i would save 60 bucks if i got an MCR220 instead... but the thing is i'm only doing this once and never plan on upgrading this WC, so i want to do it right the first time. i don't want to cheap out on parts, but don't want to empty my wallet either.
a few more qustions:
1) although i won't be doing SLI or crossfire, there's 3 blocks in the loop. do all 3 match in terms of restrictions? i don't want just one of them to be the restriction bottleneck
2) how am i suppose to mount the thermochill radiator? do i need to drill holes or do any other mods or does it fit right in?
3) two 120mm fans will take up 6 bay slots. but having this radiator in will actually take up 7 slots since the area where the tubes enters and exit take up space also right?
4) will 7/16" tubing fit all these parts?
5) i will be using all stock case fans and an additional two yate loons. two will push while two will pull air for the radiator, with the stock fans close to the mesh and the yate loons closer to the inside of the case on the rad. would it really matter that much to have air inside the case going through the rad and out of the case or air from the outside going through the rad into the case?
6) any other tips/suggestions/advice is greatly appreciated!
- You may not post replies
- You may not edit your posts
Forum Rules
