Fit 2X 320 Rads, 1X 220 Rad, 3xD5s in one Armor Case?
Sure you can...
Still working on adding more Petra's UV red to get the red I want, but here are a few "Bleeding" pics..
I've been wanting to run three loops for a while now, and after a long couple of days figuring out how I'm going to get three radiators and three D5's in one armor case..I got it. I spent alot of time finally cutting some holes behind the MB to tidy up some wiring, but also mounting the third radiator up front and shifting some drives around and figuring out how I was going to stack the pumps.
I'm not a case builder, so it's more function that form...but it's working.
Just a few pics:
Loop 1
Danger Den MC-TDX
T Line (5/8" custom polished brass Tee)
D5 variable
MCR320 hanging on back left with yate loons
Loop 2
D-Tek Fuzion GFX
D5 basic
MCR320 hanging on the back right with yate loons
Loop 3
Danger Den MPC-Universal on SB
Danger Den MPC 680i on NB
D5 variable
MCR220 in front grill with yate loons
1) Fire up attempt one, no post -- LED code...hmmm
Forgot the CPU power connectors
Up and running now!!:thumb:
Who said you can't fit two triple rads, a double rad, and three D5's in an armor case...
Empty
Filled and bleeding
Obligatory Night Shot
Red loop is wierd because I just dropped more red dye in the T-line, will take a bit to dissipate. Trying a combination of Petras Long life Red and Petra's UV red dye....need more red..no pink for me!
- You may not post replies
- You may not edit your posts
Forum Rules
