Results 1 to 5 of 5
Thread: HIS HD3850 IceQ3 Turbo measure points ?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Question HIS HD3850 IceQ3 Turbo measure points ?
    Finally got around to taking backside photos of my card which has a blue PCB. Any ideas where to measure GPU and Mem volts ?
    All photos at http://i4memory.com/reviewimages/vid...CEQ3/backside/
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    Click image for larger version.
    Note that only the other of the two points that label "more accurate vMEM reading" is vMEM, the other is ground. Can't tell which is which from the pic.
    You were not supposed to see this.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thanks largon
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    To be exact, each GDDR chip has 4 relatively easily accessible measuring points on the backside, each chip has 4 surface mount capacitors that are bigger than the rest. The other pole is always vMEM, the other is ground. So the label "more accurate vMEM reading" applies to all of these 4 capacitor per GDDR chip and all GDDR chips - not just the one cap it points to in the pic.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Thanks largon
