XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Computer Cases
Reply
Old 12-27-2007, 10:40 AM   #1
phelan1777
BLAH!!!!!!!!!!!
The CM 690 Case Thread
hey guys, seeing as many are working on, have/own a 690, myself included.
Opinions on starting a 690 thread.
I am thinking similar to my Stacker thread.
My thinking is this, just to share pics/ideas so we won't have to search all over xs as there are more and more threads popping up.
I will be working on my case soon and it will be watercooled, though it will be my primary cruncher as my Stacker is my main use PC.
So, thoughts, opinions, pics also welcome?
__________________
Mammal brains are rather like the engines in American performance cars. We tend to use cubic inches to compensate for the lack of precision engineering.
Movieman's alter ego ---------> SUPER MOD NOOB ADMIN!
Originally Posted by nn_step View Post
(A Professor to a class of students)
"If you put the sand into the jar first," he continued "there is no room for the pebbles or the rocks. The same goes for your life.
Take care of the rocks first - the things that really matter. Set your priorities. The rest is just sand."
Originally Posted by Omastar View Post
Those chubby chicks can be amazing in the sack sometimes, you know. (waits to be sigged)
phelan1777 is online now   Reply With Quote
Old 12-27-2007, 11:02 AM   #2
pumpahhh
Well, i dont have one yet, but i am saving money to buy one!
When i first saw it, i liked it, really nice case!
pumpahhh is offline   Reply With Quote
Old 12-27-2007, 11:09 AM   #3
Asgard_thor
Asgard_thor's Avatar
Send a message via AIM to Asgard_thor
I agree with this thread
m getting one soon
and will start modding it..but wont actually get a mobo, cpu and gpu for awhile :-/
__________________
FREEDOM ISN'T FREE
Cruncher Support:
Utnorris
DarthBeavis
DEFRANCO NATION
_____________
E6750@ 3.0ghz- evga 750i FTW- 320gb- Swiftech MCR220 compact- 8800gts 512mb KO- 620hx - 4gb Crucial 1066- CM 690- 6 yate loons
E6600- Asus striker Extreme-2 x 750gb- Igloo 5710- 8800gt- antec 850w Quatro- 4gb DDR2 800- Antec 1200- 24/7 cruncher
**Wishes for a dual- quad core cruncher **
Asgard_thor is offline   Reply With Quote
Old 12-27-2007, 11:43 AM   #4
phelan1777
BLAH!!!!!!!!!!!
Well the thread is to be about teh case, so the rest of the hardware is not essential, though if a certiain piece of work, or mod does prove critical to a significan OC then by all mean post related information.
__________________
Old 12-27-2007, 11:53 AM   #5
Ethelred
Alright so here is my plan.
All of the "lines" in the case will be black (ie the vertical rails for the hdd rack as well as the 5.25" bays. The Mobo tray and flat surfaces in the case will be gloss white. The outside will be gloss black. I'll remove all of the 'rivets' and replace with screws as well as cut off all the fan grills.
I've put spots of black and white to indicate the color the parts will be. So from the ouside it will be a solid black (I'll debadge as well) in in the inside it will be a mixe with the black accents. Fans will be a black bodies will white blades, white screws where visible otherwise black screws. Maybe a light blue or black sleeving not really sure.
Feedback? Plan will most likely change a little as I dismantle and decide which lines will work or whether or not the colors (shades technically) will flow into each other smoothly or not.
Picture taken from xcpu's review.
__________________
CPU: Intel C2D E8400 w/Thermalright Ultra-90 and Sharkoon Eagle 1500 <Both Lapped>
Motherboard
: GA P35-DS3R F13
GPU: EVGA 8800GT
HDD: 2xSeagate 7.2krpm 250GB
PSU:PCP&C Silencer 610W
Case: CM 690 w/ 7 Yates
Source:Creative X-Fi XtremeGamer -> CMoyBB -> Audio Technica ATH-A900
Ethelred is offline   Reply With Quote
Old 12-27-2007, 11:57 AM   #6
leoftw
Xtreme Cruncher
leoftw's Avatar
Here is a updated pic. I plan to clean it up today and will post pics later. This is going to take up some hors of my day :P
The rest of these pics are old
http://i220.photobucket.com/albums/d...n/IMG_2585.jpg
http://i220.photobucket.com/albums/d...n/IMG_2584.jpg
http://i220.photobucket.com/albums/d...n/IMG_2501.jpg
http://i220.photobucket.com/albums/d...win/cm6902.jpg
http://i220.photobucket.com/albums/d...win/cm6901.jpp
__________________
Asus Maximus Formula SE (BIOS 907)
Q6600 G0 (@ 3.2GHZ @ V1.320 )
Crucial Ballistix DDR2 800 4x1GB (2 Tracers) @ 1200MHZ
Thermaltake Toughpower Modular 750W
Tuniq Tower 120 / Tuniq Thermal Grease TX-2
BFG 8800GT OC
Cooler Master CM690
Maxtor 7200.10 320GB PATA
WWW.LEOFTW.COM
leoftw is offline   Reply With Quote
Old 12-27-2007, 05:36 PM   #7
Asgard_thor
anyone know when the side panel will be out? I WANT IT!
http://www.coolermaster.com/products...te=215&id=3169
__________________
FREEDOM ISN'T FREE
Cruncher Support:
Utnorris
DarthBeavis
DEFRANCO NATION
_____________
Old 12-27-2007, 10:20 PM   #8
EvilBellyLint
EvilBellyLint's Avatar
This case is so versatile with respect to cooling options,
what I'd really like to see is what different peeps have
settled on as their optimal fan set-up.
Also any mods that involve custom shrouds, ducts, chimneys,
etc... as there seems to be infinite possibilities for airflow
design with this case
I'll be starting a new build very soon with the CM690, and STILL
I'm see-sawing back and forth on a couple different airflow
set-ups I've been mulling over. Maybe once I get everything
tested and running, I'll do some airflow pattern tests and post
my results.
EBL
EvilBellyLint is offline   Reply With Quote
Old 12-27-2007, 11:53 PM   #9
Death^Dread
I still can't decide what to do for airflow... I don't know what to do on the top that won't fight against my TRUE. I've held off on ordering fans until I decide what to do...
__________________
E6300 under TRUE|Gigabyte 965P-DS3 Rev. 3.3||ATI Radeon HD 4830 700/1200 24/7|2GB G.Skill F2-6400CL5S-1GBNQ|HIPER HPU-4K530-MS|CM 690
Death^Dread is offline   Reply With Quote
Old 12-28-2007, 09:53 AM   #10
Burn
Burn's Avatar
Send a message via AIM to Burn
I'm ordering five of the 140mm Yate Loon's (high-speed versions). Will be building my own small footprint, low-profile PWM fan controllers for them and mounting them with actual screws and such ("Fan" screws look ugly and make nasty holes, I'll be using socket head cap screws with rubber grommets). Fan controller will be modular, probably mounted very close to the fans themselves or in a location which is easily accessible and looks "good".
Eventually will be cutting a side panel out, will retain both 140mm fans in the side panel and hopefully it'll show off the goods I'm looking forward to what I'll be able to do with a dremel, grommets and a hole saw :p
Also will be drilling (as mentioned above) holes in the motherboard tray for grommets which will help with routing power cables and data cables (SATA). I am hoping to be able to make a really nice SATA cable routing plate which I saw in another thread, here:
http://www.overclock.net/case-mods-g...ml#post3055909
Except it'll be handling 6 SATA cables
Going to fill up the hard drive racks with 5 hard drives, as well as one SATA DVD burner.
My thoughts
__________________
CNC Waterblock Builder
Q9550, Rev. E0
Gigabyte EP45-UD3P
4GB G.Skill DDR2-1000
eVga GTX 260 Core 216 Superclocked
3 Western Digital 80GB, RAID 0; 500GB Seagate 7200.11
Silverstone OP750 PSU
Extreme Watercooling
Swiftech MCR-QP 360
D-Tek Fuzion v1
Laing D5
D-Tek Fuzion GFX rev. 2
Burn is offline   Reply With Quote
Old 12-29-2007, 02:31 PM   #11
leoftw
Xtreme Cruncher
leoftw's Avatar
__________________
BFG 8800GT OC
Cooler Master CM690
WWW.LEOFTW.COM
Old 12-30-2007, 12:03 PM   #12
Vice
Vice's Avatar
Send a message via AIM to Vice
I bit on one of these cases, got it from newegg for $34.99 shipped AR.
Expect a build log soon.
__________________
Core2Duo E6600 @ 3.0 - Load @ 32c°| Gigabyte P35 DS3P | 2gb Crucial Ballistix Pc2-8500| eVGA 8800GTX| X-fi Fatal1ty | OCZ GameXStream 600w | Custom Watercooled | Custom-built Case
Dtek Fuzion | DD Maze4 Acetal | Swiftech MCR-320 | DD D5
3dMark01 3dMark05 3dMark06 Aq3 SuperPi
Originally Posted by Movieman View Post
I don't beleive in passive cooling.
Vice is offline   Reply With Quote
Old 12-30-2007, 12:26 PM   #13
daedra1
daedra1's Avatar
Send a message via ICQ to daedra1 Send a message via AIM to daedra1
clubit has it for $5.99 and with shipping it's only $20.00. Better hurry though I think today is the last day for the sale. This is the second one I have bought and I still can't believe how cheap there letting these cases go.
daedra1 is offline   Reply With Quote
Old 12-30-2007, 01:15 PM   #14
EvilBellyLint
Me neither. They're worth paying MSRP for.
But something tells me Coolermaster may be having some
cash-flow issues... seems every one of their products has
been heavily rebated for the past couple months... they
may just need the cash more than they need the inventory.
EBL
Old 12-30-2007, 02:36 PM   #15
Vice
Vice's Avatar
If you'll read my post above, ClubIT is sold out.
__________________
Old 01-01-2008, 05:10 PM   #16
Xvys
yep, you have to wonder about CoolerMaster selling this case for $5.99. Considering the heft of these units, it has to be worth at least that much in scrap metal value! And with their crummy Extreme power supplies (which they often discount to 1/3 of their MSRP), will surely tarnish their good name, so you have to wonder?
I hope some of you guys with your 690's pictured here realize, that the 120mm fans on most power supplies is an INTAKE fan, which exhausts passively out the front (and out of the computer). The manual suggests that you install these ps upside down, so the fan draws hot air out of the computer box. If you install it rightside up, the intake fan is pushed up against the case bottom and the airflow is probably being partially restricted, which may increase heat and reduce the longevity of your ps.
Xvys is offline   Reply With Quote
Old 01-01-2008, 06:28 PM   #17
JasoN!!!
i want to paint the two side panels a different color should i sand it before painting it or should i take a spray can and just spray it
JasoN!!! is offline   Reply With Quote
Old 01-01-2008, 09:02 PM   #18
dkx64
Theres big rubber footing on the bottom of the case which gives it about an inch and a half of clearance and also if you haven't seen from (nude case) pictures, there are vents down there as well, so theres no air being restricted at all. The way its designed, the PSU will be pulling in cold outside air from the bottom and exhausting it out.
Jason, I'm in the process of painting my case right now. I just got done sanding the side panels down because they are sheet metal. I'm not sure if its necessary, but most of the guides recommend it. This is my first time tring to paint anything. For the front and top covers, they are plastic, so i just painted over it. I only put one coat on right now but it looks good so far.
dkx64 is offline   Reply With Quote
Old 01-02-2008, 03:14 AM   #19
Blasar
Blasar's Avatar
Originally Posted by leoftw View Post
Can you close the side door with the fans mounted on?
It was easy to mount the tuniq in that board? I ´ve read somewhere that are some "issues" with the
Tuniq and the ASUS Maximus e P5E. Can you, please, clarify this to me?
TIA
__________________
Sorry for my poor english.
Blasar is offline   Reply With Quote
Old 01-02-2008, 04:21 AM   #20
LuckyNV
TIA
only the VGA side fan will fit, tall heatsinks like the Tuniq, IFX14, TRUE etc... will not accommodate the CPU side fan
__________________
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Zotac GTX260-216
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music
Samsung SyncMaster 713BM (DVI)
LuckyNV is offline   Reply With Quote
Old 01-02-2008, 07:53 AM   #21
EvilBellyLint
My thoughts
very nice, BTW
EBL
Old 01-02-2008, 08:08 AM   #22
naokaji
Guest
Posts: n/a
they make money form the uk... 105$ for the CM690 on this side of the pond...
Old 01-02-2008, 01:23 PM   #23
JasoN!!!
Can i see picture and what grit of sand paper you used
Old 01-02-2008, 03:53 PM   #24
khellandros66
ModdersHQ Staff
khellandros66's Avatar
Send a message via AIM to khellandros66
As far as airflow my results are great
Top 2x120 exhaust Scythe
Rear 120mm Exhaust Stock
Front Intake Stock
Bottom Intake Stock
Bottom Side 120mm Intake Scythe
Side 80mmx15mm Exhaust Zalman (slightly modded)
HSF 120mm Scythe (duh look at sig)
Nexus Controller to control rate of intake and exhaust for maximum performance.
Noise at 2m = 31dB A and 39dB C Weighted, yeah I am that good...
~Bobby
__________________
MSI K9N4 SLI-F / AM2 6000+ / OCZ Gold PC6400 2x1GB + A-DATA 2x1GB = 3.25GB with PAE Enabled XP Pro
EVGA 8800GTS 320MB / Auzentech Xplosion / 200GB Maxtor ATA133 / COOLER MASTER RC-690 / Scythe SCNJ-1100P / Antec 650w Trio Power
khellandros66 is offline   Reply With Quote
Old 01-02-2008, 11:19 PM   #25
dkx64
I just picked up an assorted sanding pack at Autozone, as well as the spraypaint, it included a 40, (2) 80 and 180grit sheets. The 40 was enough to get all the paint off and expose the sheetmetal. 80 will give it that shine, and 40 will smooth it out a bit. It had a brushed metal look to it, i thought it actually looked pretty good for a while, but since the top and front panels of the case are plastic, i couldn't pull off that whole look.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
