hey guys getting some new gear(mobo,case,watercoolin) so gona be doing a small bit of modden !
going to be spraying the internals of the case black.cutting the top to fit a PA360.going doing some smaller stuf like modding the fan holders and cable sleeving also cutting some holes for me cables !!!
so here's the parts:
Lian Li PC-A70B
Asus Maximus x38
120.3 Rad Grill with Mounting Holes
Sunbeam Rheobus (Black)
loads of heat srink and braid
loads of paint
Watercooling:
Ek supream(hopefully the new best block on the market)
Masterkleer 7/16" ID
ThermoChill PA120.3
Ek res
Laing ddc3.2 with petra top
Maze 4
first off i soldered/sleeved my 3 yate loons to 1 3pin header.
here are some pics of the gear :
EK Supream
see how well lapped it is.
EK 150 Res
The res is smaller then i toughtbut it will do.
Chilled pc rad grill
OK started preping the case to be primed and then sprayed.
here is a template i made for cutting the holes for the PA120.3
here is a pic of the case after the 2nd coat was applied,all the parts you see here have been coveredand the parts where the paint ran has been sanded and reaplied
My asus maximuss
but it will do.
