Page 1 of 3 123 LastLast
Results 1 to 25 of 55
Thread: 580MHz FSB Air Cooled with Wolfdale on G33 Chipset
    Nov 2004
    Germany
    600MHz FSB Air Cooled with Wolfdale on G33 Chipset
    Want to share my Results with you
    Got 580MHz max FSB with E8500 Wolfdale on my HTPC mainboard. It´s a Gigabyte GA-G33M-DS2R
    CPU is Aircooled with an Freezer 7 Pro
    Mainboard is stock without mods.
    http://valid.x86-secret.com/show_oc.php?id=278277
    Got another wolfdale, a E8400 and give him a try. Max FSB on Air was 570MHz. While using setfsb and switching up to 575mhz fsb the system freezes.
    http://valid.x86-secret.com/show_oc.php?id=279136
    Little update, new CPU E8200 on air with boxed cooler.
    http://valid.x86-secret.com/show_oc.php?id=303518
    Sep 2003
    Edinburgh - UK
    Damn these E85's are looking better by the day
    Xtreme X.I.P.
    Aug 2004
    Chile
    :o impressive
    Xtreme Guru
    May 2007
    Ace Deuce, Michigan
    looks nice, lets just hope the retail perform this good, and especially that the lower models oc nicely too (ie lets hope no e6750 like products, only e6850 like if you get what I mean)
    Quote Originally Posted by Hans de Vries View Post
    JF-AMD posting: IPC increases!!!!!!! How many times did I tell you!!!
    terrace215 post: IPC decreases, The more I post the more it decreases.
    until (interrupt by Movieman)
    Regards, Hans
    Nov 2004
    Germany
    Itīs insane. This is the cheapest Board in the house but the board wich perfoms best with wolfdale cpu.
    Before it runs on Asus P5K-E, Asus Maximus Formula and Foxconn Mars but the max FSB was between 530-550MHz.
    Tomorrow I will give a short test on Gigabyte P35 DQ6.
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    damn thats impressive.. now i really cant wait for these chips to hit the shelves
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Aug 2006
    The Netherlands, Friesland
    580fsb on a G33 chipset mATX board and the board has half multiplier support?
    >i5-3570K
    >Asrock Z77E-ITX Wifi
    >Asus GTX 670 Mini
    >Cooltek Coolcube Black
    >CM Silent Pro M700
    >Crucial M4 128Gb Msata
    >Cooler Master Seidon 120M
    Hell yes its a mini-ITX gaming rig!
    Nov 2004
    Germany
    Bios for half multiplier ist just a few days old. Itīs version F7. I posted a few weeks ago in gigabyte forum that there is no bios for half multis and tadaa, one week later i got it
    Sep 2005
    Belgrade, Serbia
    Bravo for fsb on crapy mobo
    Born to overclock
    Feb 2005
    Quote Originally Posted by olDirdey View Post
    Got 580MHz max FSB with E8500 Wolfdale on my HTPC mainboard. Itīs a Gigabyte GA-G33M-DS2R
    Wa!!!!
    580 FSB air cooled cpu
    Xtreme Mentor
    Sep 2006
    How stable was this? Did it boot into this or was it set after? Can it run any apps? Also, what memory did you use there?
    Seems like 600+ FSB should be possible with phase.
    [SIGPIC][/SIGPIC]
    Mar 2005
    North West London
    For sure. 580 on air is simply amazing.
    Also hope that Yorkfield will have an improved fsb over Kensfield.
    ODOC
    Aug 2006
    Copenhagen - Denmark
    Looks really good .
    Keep pushing it.
    Nov 2005
    Germany
    i put the CPU today on a Gigabyte P35-DQ6, max FSB SuperPi 1M 570Mhz! (on air)
    On Foxconn Mars max FSB 1M 555Mhz (it need ~1.9v vNB )
    edit: on DQ6
    http://valid.x86-secret.com/show_oc.php?id=278685
    Sep 2007
    Belgium
    Is it 32M/orthos stable?
    System: E8400 // P5Q-E // Ballistix // HD3850 // HX520 http://valid.x86-secret.com/show_oc.php?id=419486
    Thermochill pa120.3 // D-tek FuZion bowed+ costum nozzle // MCW60 // EK150 // dcc1 18w w/top
    Nov 2004
    Germany
    Quote Originally Posted by Speederlander View Post
    Running it with 2GB of PC2-8500 ballistix. Boot up with 560MHz and then used setfsb. But never tried to but with higher fsb. Tomorrow I can test a E8400 and will try how stable it is at high fsb
    Quote Originally Posted by DFI pit bull View Post
    Normally I have running a Q9550 on this board. It can do max 463MHz on this board. With 464MHz it will boot but is only super pi 1m stable. On Asus P5K it can do max 471MHz fsb.
    Xtreme Guru adamsleath's Avatar
    Nov 2006
    Brisbane, Australia
    haha mATX classic.
    i7 3610QM 1.2-3.2GHz
  18. #18
    Jul 2007
    Maaseik, Belgium
    Quote Originally Posted by Chri$ch View Post
    edit: on DQ6
    I love the speed with that needed VCore !
    Just great CPU's...
    And still I will not own everyone[/FONT]
  19. #19
    Feb 2007
    In an Octopuss' Garden
    This is VERY promising! I really hope the retail versions of these chips do something close to these numbers.
    I do have one question though. Why doesn't anybody post the temps on these OC threads? I sure would like to know what the core temps were at 1.34vCore and 580 fsb with 7.5 multi for a speed of 4.3Ghz.
    Main Rig - i5 2500K@42x (Turbo)...2x2gb Corsair DDR3-1600...Asus P8Z68-M Pro...Corsair HX620 PSU...Hanns-G 19" LCD...80GB Intel SSD...2 x 1TB Samsung HDDs...Zalman CNPS9700...Ultra Aluminus (black)...Win 7 Ult x86
    HTPC - AMD A6 3650 stock...2x1gb G Skill DDR3 1600...Asus F1A75-V Pro...Corsair HX520 PSU...2x80gb WD Sata2 RAID0 HDD...Silverstone LC17 B...Olevia 42" LCD 1080P...Yamaha HT Receiver...JVC 5.1 speakers and sub...Win 7 Ult x86
  20. #20
    I am Xtreme
    Feb 2003
    Netherlands
    Quote Originally Posted by jimmsch View Post
    I think you're missing the point, this topic was started to show what max fsb is possible on new 45nm cpu's.
    Temps are somewhat irrelevant and depent to much on cooling solution and ambient temps, current cpu's can still be stable over 70C.
    What does it tell you if he gets 30C idle?
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
  21. #21
    Mar 2005
    Imladris
    These wolfdale chips look to be something really special.
    The little air system that could.
  22. #22
    Jul 2006
    Just amazing, I got my similar but never stable evan @ 350. How do you set the voltages? E'rythings max out?
  23. #23
    Apr 2005
    Germany, Bremen
    Nice FSB and CPUs
    What is the maximum clock with the E8400?
  24. #24
    Nov 2004
    Germany
    Quote Originally Posted by Thanh55 View Post
    Nothing is maxed Out. vMCH is Normal, vFSB is +0.1V
    But I think the key to get as such high fsb on wolfdale cpu is the GTLREF Ratio. I set it from 0.636 to 0.603.
    Raising the MCH voltage will end in blue screen, same thing if I set the vFSB voltage to +0.2V
    At the moment I am testing max stable fsb. Prime95 is running since 30min with 560x6
    Quote Originally Posted by SeLecT View Post
    Nice FSB and CPUs
    Thank you Never tried till yet to get the maximum clock. But tried this night to boot with 560x8 and 1.55V set in bios. No go Will figure it out later.
  25. #25
    Feb 2007
    Quote Originally Posted by Zeus View Post
    Obviously idle temps don't really say much, but if he would mention his room temps and post his core temps (he already mentions what he is using for a cooler) and it showed that at 4.3Ghz under load he was under 40C it tells me these 45nm chips run MUCH cooler than the 65nm and that means alot to me.
    But I gues I am missing the point. This has nothing to do with MAX fsb. It is just something I like to know.
