The multiple screen Wallpaper topic!: http://www.xtremesystems.org/forums/...d.php?t=190723
The System wallpaper topic!: http://www.xtremesystems.org/forums/...d.php?t=180050
is that 3/8" tubing?
nope, 8mm tygon 34 tubing![]()
Nice setup thereI really like that black tubeing. Where did you get it at ???
why didnt you use bigger tubing? 1/2'...7/16???
CPU: Lapped QX6700 @ 4000MHz, bench @ 4250MHz
RAM: Teamgroup DDRII PC6400 @ 1066 cas5
MOBO: eVGA 680i SLI
VID: eVGA 8800GTX + Zotac 8800GTX SLI...GPU voltmodded....Memory voltmodded (both cards)
BOOT Drive: Seagate 320GB 7200.10 RAID 0
Storage Drive: Seagate 640GB 7200.11 RAID 1
Samsung Super Write Master
Coolermaster Real Power Pro 850W
Custom Bench Table
LaCie 19inch CRT
Single Stage Phase Change - CPU
Water - VGA's
Lovely mate! But... hoseclips?????![]()
Intel E8400 Wolfdale
4 Gb OCZ Flex
8800 GT
Abit IP35 Pro
530w Tagan
Apple Core Duo Project Log @ Bit-tech.net
Ahhh, much nicer pics. Nice setup. I like the thinner tubing ... looks different that what most of us are using.
nice black tubing. looks uber clean in there...
Thanks for the feedback! I shall try to make some better pics with my camera...can't someone join me with a 500$ camera?this sucks. I think I'm going to make a new topic next week with a camera from my m8.
Yeah, dis'y radical has it. I have some but want to see how my loop bleeds before I'd use it.
Dnb#,
Got to say, nice setup, the second set of pics only do it justice, the first set is to blurry and dark to make it stand out.
One suggestion though, if you like it, is to line the trace on the pcb of your 8800gts with blue uv ink, so that you see them in the uv lighting, i think that would look sick. I've seen it done before and really liked it then. Just don't overdo it.
Specs :...............................................Chilled by :
MB : Asus Striker Extreme.......................Heag-Cooling 1/4 HP R404 Compressor
CPU : Intel Core Quad Q6600 @ 3.0 Ghz....15 dgr water temp @ Full load.
RAM : 2048 MB OCZ FLEX XLC PC9200.......Aquacomputer Cuplex XT DI for CPU/NB/SB&Mosfets.
VGA : MSI 8800 GTX @ 650 / 2100............Aquacomputer G80 Fullcoverblock.
HDD : 1 TB Harddiskspace........................Liquid cooled RAM
CASE : Silverstone Tj-07 (BTX,MODDED)...
And yes, i know its an expensive setup. Leave a comment or PM on what you think about it.
