XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Bandwidth
Reply
Old 10-13-2007, 07:42 AM   #1
eva2000
Memory Addict
eva2000's Avatar
Cool 2x2GB G.Skill F2-8000CL5D 4GBPQ 5-5-5-15
First time checking out a 2x2GB DDR2 kit of memory and the first contender to reach my hands is a 4GB G.Skill F2-8000CL5D 4GBPQ 5-5-5-15 dual channel kit fresh off the production lines according to serial number = 740 = week 40, 2007. Thanks G.Skill for supplying the kit
Product url http://gskill.com/en/f2-8000cl5d-pq.html
Specification:
  • Capacity 4GB (2GB x 2)
  • Speed 1000MHz DDR2 (PC2-8000)
  • CAS Latency CL 5-5-5-15
  • Test Voltage 2.0~2.1 Volts
  • PCB 6 Layers PCB
  • Registered/Unbuffered Unbuffered
  • Error Checking Non-ECC
  • Type 240-pin DIMM
  • Warranty Lifetime
Poor lighting forced me to use flash on my camera
From irev210's review photo here it seems to be non-Micron based ICs.
eva2000 is offline   Reply With Quote
Old 10-13-2007, 07:42 AM   #2
eva2000
Memory Addict
eva2000's Avatar
Some quick tests of Prime95 v25.4 and a barrage of Everest, Sandra 2008 XII and Super Pi benchmarks all done at 2.1v vdimm.
System
  • Intel Core 2 Duo E6850 ES - L723A347 G0
  • Scythe Infinity with modded mount + 120x25mm Spire 96cfm fan
  • Transpiper heatsink NOT installed
  • DFI LP UT P35-T2R 9/13 bios
  • 128MB Gainward FX5200 PCI
  • 2x2GB G.Skill F2-8000CL5D 4GBPQ 5-5-5-15 2.0-2.1v rated DDR2 kit
  • 80GB Hitachi 7K80 SATA
  • LiteON CD-RW
  • 700W OCZ GameXStream
  • WinXP Pro SP2
CAS5 - Prime95 v25.4
All subtimings on AUTO except tRFC which needed loosening to 48
@stock 500Mhz 5-5-5-15 at 2.10v
@510Mhz 5-5-5-15 at 2.10v
Old 10-13-2007, 07:43 AM   #3
eva2000
Memory Addict
eva2000's Avatar
@520Mhz 5-5-515 at 2.10v
Seems to be close to max at 2.10v memory voltage so far with AUTO set subtimings and manually set tRFC 48 value.
Super Pi - single & dual 32M
Old 10-13-2007, 07:44 AM   #4
eva2000
Memory Addict
eva2000's Avatar
Everest Ultimate 4.10.1052 beta
Sandra 2008 XII - Buffered & Unbuffered
CPUZ Validation
Not bad for <US$190 4GB kit with non-micron ICs. More tests including CAS4 to come soon
Old 10-13-2007, 07:57 AM   #5
r00n
r00n's Avatar
Send a message via MSN to r00n
It's Powerchip.
Everybody seems to be getting similar results. With that consistency the kit indeed is great value for money.
As always, great review George!
r00n is offline   Reply With Quote
Old 10-13-2007, 09:07 AM   #6
GAR
Xtreme Guru
Send a message via AIM to GAR
i was tempted to sell my 4x1gb of d9gmh to get these, but 520 just isnt good enough............will keep my d9's
__________________
XSMODSRLAME
GAR is offline   Reply With Quote
Old 10-13-2007, 09:12 AM   #7
BigRigDriver
BigRigDriver's Avatar
Wink
Are you interested in buying??
http://www.newegg.com/Product/Produc...8000CL5D-4GBPQ
__________________
BigRigDriver is offline   Reply With Quote
Old 10-13-2007, 09:30 AM   #8
kakaroto
Bandwidth Freak
kakaroto's Avatar
Nice testing eva2000! It seems the average 4GBPQ is good for a 10~20MHz OC @CL5. It suprises me that this memory runs better at Trfc=48 on the P35. Denny also tested his memory on a DFI P35.
I could'nt get my system boot with tRFC=48 at 520MHz 5-5-5-15. On my P5B Deluxe 965 I need at least tRFC=50.
I can't wait to see your CL4 tests.
kakaroto is offline   Reply With Quote
Old 10-13-2007, 09:41 AM   #9
EnJoY
Tyler Durden
EnJoY's Avatar
Send a message via AIM to EnJoY Send a message via MSN to EnJoY Send a message via Skype™ to EnJoY
Nice review Eva.
I have my kit now, been doing testing on it since Thursday night. I've actually had better luck on the overclocking side of things than most others have. I'll be posting my review within the next few days.
__________________
Follow TechREACTION on Twitter
EnJoY is offline   Reply With Quote
Old 10-13-2007, 12:27 PM   #10
irev210
Xtreme X.I.P.
irev210's Avatar
Originally Posted by EnJoY View Post
Nice review Eva.
sweet, look forward to seeing the results.
I am re-testing on gigabyte x38 today
__________________
CPU: Intel CORE 2 Duo E6550 @ 3.6GHz w/ 1.29vcore (517*7)
Motherboard:
Gigabyte P35-DQ6
Memory:
Crucial 8500's
Video:
Nvidia 8800GTX
PSU:
Zippy 700W (fan modded of course)
irev210 is offline   Reply With Quote
Old 10-13-2007, 08:05 PM   #11
GAR
Xtreme Guru
irev, how are the results with the x38???
__________________
XSMODSRLAME
Old 10-13-2007, 08:41 PM   #12
GAR
Xtreme Guru
i just ordered this kit, will be here hopefully tuesday.....i will do some tests with the x38
__________________
XSMODSRLAME
Old 11-10-2007, 01:28 PM   #13
Akuma2000
Akuma2000's Avatar
I want to buy these, but I can't find a shop in the Netherlands that provide these kits.
In Germany I can't find a shop which has these kits on stock.
Also not on stock in the shops I searched in the UK (also in UK veery expensive).
Newegg has these on stock and very nice price, but doesn't ship international
Anybody any suggestions for a shop that has these kits on stock and can ship it to the Netherlands?
Thnx in advance!
Akuma2000 is offline   Reply With Quote
Old 11-10-2007, 01:51 PM   #14
eToh
Xtreme Cruncher
I've been able to hit 900@ 5-4-3-12@2.2v stably with command rate at 1t.
Gonna see if I can push it further. Will post ss later.
eToh is offline   Reply With Quote
Old 11-11-2007, 04:06 AM   #15
Akuma2000
Akuma2000's Avatar
Oh menn... I really want these modules
Somebody please help me find a shop who has these on stock and can ship to the Netherlands, so I can have it asap
Old 11-15-2007, 06:50 PM   #16
Richard Dower
Xtreme Mentor
www.memoryc.com
They ship anywhere in Europe...if you do order, might i ask you tell them i sent you over to the website.
__________________
Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
Richard Dower is offline   Reply With Quote
Old 11-15-2007, 06:51 PM   #17
Richard Dower
Xtreme Mentor
http://www.memoryc.com/products/desc...kit/index.html
__________________
Old 11-16-2007, 12:35 AM   #18
Akuma2000
Akuma2000's Avatar
yes thnx. I've already contacted them before, but they didn't had in on stock.
But now they do
It's a bummer that the currency for Euro - UK Pounds is not good for me
__________________
---------- Click Here For My Build Log ----------
--------- DangerDen Waterbox Lanbak ---------
Old 12-13-2007, 01:36 AM   #19
Spyrus
Any CL4 results yet?
__________________
My Rig:
E8400 TRUE120@Asus Maximus Formula@2x2GB Geil Evo One PC6400 4-4-4@Corsair HX 620W
Connect3D HD4850 512MB@Intel X25-M G2 80GB@Casetek 1022-5@LG 19"1970HQ TFT
Creative Inspire 5.1 5100@Samsung SH-S203B SA@Microsoft Business Hardware Pack
Spyrus is offline   Reply With Quote
Old 12-13-2007, 01:43 AM   #20
eva2000
Memory Addict
eva2000's Avatar
been too busy.. lots of toys to play with .. will get back to them when i have some more time
Old 12-13-2007, 03:51 AM   #21
Akuma2000
Akuma2000's Avatar
CL4 gives me bluescreens
(@ 850Mhz and 2.1V)
__________________
Old 12-13-2007, 04:12 AM   #22
eToh
Xtreme Cruncher
(@ 850Mhz and 2.1V)
Try 2.2v. Although don't expect to get much higher then that at CL4.
Old 01-29-2008, 01:47 PM   #23
ATT
Sorry to bring this thread back from it's slumber
but I'm having issues with this memory and my Abit IP35pro
timings where set 5 5 5 15 in bios with 2.1V-2.2v under vista x64 it seen fine no blue screen but under winXP x64 i keep getting Disk.sys stop: 0X00000050 after bit of research it's now doing little better with 5 5 5 15 TRFC 45 but yesterday i got my first blue screen again after 1 whole day of been blue screen.
my question is if i wanted to run @ DDR 1000 speeds what are the best stable timings should i use for stable system.
got to give to MS looks like vista handles error better then XP.
(i do notice my system bit feels slower then my X2-4400+ running vista 32bit my guess the memory is affecting it cause there both have the same tweaks and system with more Ram should be smooth not to mention 4 cores)
my specs are
Q6600
abit IP35 pro bios 16 B4
8GB of Gskill F2-8000CL5D-4GBPQ
7300le "for now"
Audigy 2 ZS
Dual Antec true 550
i do see timings posted on the first few post but guessing those are set for best performance squeezing out the last MB is there any timings for stability.
thx
PS here a thread i started on abit forums http://forum.uabit.com/showthread.php?t=133965
i blame the board but looks like it's the memory who is to blame
ATT is offline   Reply With Quote
Old 01-29-2008, 02:58 PM   #24
EnJoY
Tyler Durden
EnJoY's Avatar
TRFC at 48 or higher.
And in the future, to avoid those problems, always use memtest.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
{vb:raw chatroll.html}
