After seeing what a few others have done with their Lian-Li 343B cases, I decided to use this case and implement three loops. The biggest challenge was where to locate the three DDC-3.2 pumps and the three MCRES-MICRO reservoirs. Since the case has a lot of room on the right side, I decided to put all three pumps and reservoirs in that area. I wanted to keep the pumps, reservoirs and plumbing away from the motherboard area.
I had a pump shelf made that holds the three pumps. When testing the pumps, I noticed that the bottom of the pumps got pretty warm. Because of that, I added a 60mm fan below each of the pumps. I know this is probably overkill, but what the heck, this is extreme, right?
Pump Shelf
The biggest problem I had initially was that the power supply got in the way of the pump shelf. I needed to mount the pump shelf very low because there wasnt very much room between the pumps and the reservoirs, and the tubing would become kinked easily. The solution was to rotate the power supply bracket 180 degrees and mount the power supply up higher. The pump shelf now is below the power supply and the tubing has room to route.
I tested the pumps last night and everything seemed to work very well with this setup. The only complaint I have is that running the three pumps are a bit noisy. I need to add some fiber spacers below the pump mounts so that the pumps arent directly contacting the pump shelf.
Here are a few pics of the initial pump tests. I am happy with the layout as this solved where to place all three pumps and reservoirs.
The next step is to send the case out for powder-coating and add the sound-proofing material. Thanks to mjassbong, virtualrain, and Mekrel for the info they gave me on their 343B projects.
Cheers!
