XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods
Reply
Old 07-19-2007, 07:49 AM   #1
s e t h
Champion
s e t h's Avatar
Talking solderless vmods...a ghetto guide
I have setup this guide to illustrate an altenrative to traditional soldered mods. This method requires no soldering tools or skills & is completely removable. All that is required is time & a steady hand For this example I have used the mod on one of my graphics card, but keep in mind you could use the same application anywhere & I have seen it succesfully used for mobo mods as well.
tools are listed & shown in the image below:
1. multi-turn variable resistors
2. duct tape or insulation tape - note: my duct tape adheres FAR better than the insulation tape!
3. internal audio cable for cd-rom to audio card / mobo... You get one with every cd-rom / dvd-rom you buy.
4. a good pair of scissors
5. a razor blade
6. RS Components adhesive silver conductive paint (code 186-3593)... their global website > here <...available in many many countries
7. tools for applying the paint & pressing the tape into small grooves
The graphics card is my asus 8800gts 320mb. I will be doing vcore & vddr mods as well as read point for both. keep in mind that the stock cooler is not going to let you go much further no matter what your voltage, I simply upgraded the fans for a few more mhz. Ok, on with the mod:
I started by prepping the cables, you will need 3 of them here. Pull the 'jumper' from the one end of two of them & both ends of the 3rd one. Carefully use the razor blade to cut the full length of the shroud, remove the plastic shroud & the earth which should be wrapped around 2 cables. On the 2 cables that you kept the 'jumper' in place, this should leave you with the crimped cable on one end & the 'jumper' on the other, remove the crimped ends to three of the cables & join one cable to the crimped end, this should leave you with one crimped end with 2 cables attached & 2 exposed ends. We will use those for the vcore & vddr. With the last cable we only need crimped cables to one end & exposed wire on the other, these will be used for vcore & vddr reads.
Next I fitted the multi-turn vr's to the cd-rom 'jumpers'. To make my life a little easier I always install the vr's in the same way whenever i do mods, it just means you are always turning the same way to raise lower volts. As you look at the cd-rom cable 'jumper' with the exposed crimped areas facing you, make sure that the 2 cables are fitted to the left most points, thats 2 fitted on the left & 2 open on the right. Now the vr's only have 3 pins, I install so that the left & centre pin fit into the 2 cabled points on the 'jumper', the 3rd pin of the vr simply fits into an empty socket of the jumper. Make sure that your vr's are turned all the way to max resistance before turning anything on!
You should end up with this:
Next i started on the card. the areas that we will be working with:
vcore
vddr
vcore & vddr reads
So start of by carefully masking the areas out with tape, cutting small strips to get into tricky areas. The idea is that you are left with ONLY the indicated end of the resistor still visible. Make sure you push the tape down around the resistor so no paint seeps in, the adhesive paint is quite thick so this is unlikely, but lets rather be safe. Cut the shroud on the cable so that only the very tip (like 1mm) of cable is exposed, tape the cable up to the associated resistor point & make that 1mm exposed piece of the cable just touch the resistor, then tape again so that the cable is not moving anywhere. Once you are happy that everything is in place drop a pin head of paint at the resistor / cable contact point to bridge & hold the cable & resistor. Make sure not to contact any neighbouring points, if you have done the masking correctly this should not happen. The de-mister type conductive paint will NOT work here, its too thin & will bleed under the masked areas.
vcore
vddr
vcore & vddr reads
Finally tape the remaining slack on the cables down & you should end up with a card looking like this:
Once the card is installed you will need to push the read from you dmm into the crimped ends of the read points & tape up, this will give you live voltage reads, very handy.
When you are done with the mods & want a clean card again just use nailvarnish remover on a q-tip to dissolve the conductive paint and clean up.
my team ghetto benching partner TraX did most of the hard work for this thread
This is what my rig looked like once complete:
And then some bench results for those that want to stay on air:
asus 8800gts 320mb - vcore & vddr + modified stock cooler
dfi 965 -s
2gb team extreme
e6700
tuniq tower 120
raptor 150gb
antec NeoHE 500w
2001 = 69112
gpu @ 701 / 1008 / 1620 / 1.46v
cpu @ 510x8 / 1.68v
2003 = 42023
gpu @ 701 / 1008 / 1588 / 1.48v
cpu @ 505x8 / 1.68v
2006 = 12224
gpu @ 701 / 1008 / 1620 / 1.48v
cpu @ 505x8 / 1.68v
Under ICE the results are pretty good with the core going as high as 820
dfi 965 -s
2gb team extreme
e6700
raptor 150gb
aopen 700w
dryice to cpu & card - ghetto pots
2001 = 77497
gpu @ 820 / 1100
cpu @ 466x10
2003 = 45948
gpu @ 790 / 1050
cpu @ 443x10
2006 = 13775
gpu @ 820 / 1100
cpu @ 448x10
have fun with the ghetto vmods & thanks for reading
s e t h is offline   Reply With Quote
Old 07-19-2007, 08:11 AM   #2
Morais
very nice mods! Thanks for sharing
Morais is offline   Reply With Quote
Old 07-19-2007, 08:27 AM   #3
ibby
Annoyed
ibby's Avatar
good going
but i still feel better with solder mods
__________________
RIP GrandDad , I'll miss you -15/07/1985
RIP GrandMother, I'll miss you -08/08/2007
Sossaman Modfications Planned.
ibby is offline   Reply With Quote
Old 07-20-2007, 09:35 AM   #4
trans am
Xtreme Mentor
trans am's Avatar
I'm bringing your guide to radio shack and will try this weekend. Thanks man.
__________________
current computer crap:
I3 530 L939B675/ 540 L939B694
asus maximus III formula p55
gigabyte GA-P55A-UD6
single Diamond 5850 flashed to 5870 920/1300
lsi 9260-4I
2 x 64gb indilinx barfoot supertalent ME raid0
ST1000-P psu
gtx480/apogeeXT/mcp655 (bitspower d5/655 mod)
trans am is offline   Reply With Quote
Old 07-21-2007, 03:59 AM   #5
comment
comment's Avatar
Send a message via Skype™ to comment
Good work, flytek!
Just did a small article on this guide for the XS front page. Hopefully it'll be up soon.
__________________
  • DFI LANParty LT X38-T2R Rev. AA1
  • Core 2 Duo E8500 @ 4009MHz, 1.31V
  • TRUE @ 2x Scythe S-Flex SFF21F, 5V
  • 4 x 2GB G.Skill Pi PC2-8800
  • MSI R4870X2-T2D2G-OC
  • 3x 74GB Raptor ICH9R Raid0 @ 128KB Stripe Size
  • Plextor PX-716SA/T3KB DVD-RW
  • Auzen X-Fi Prelude @ TI OPA637AU - Thule - Dali/Ultimate Ears - Argento
  • SilverStone OP700
  • CM Stacker 830 Evo
  • Eizo FlexScan HD2441W - Audioquest DV-X
  • WinVista Ultimate 64bit SP1
comment is offline   Reply With Quote
Old 07-21-2007, 05:51 AM   #6
DFI pit bull
DFI pit bull's Avatar
Great guide, very usefull to me as my soldering skills are pathetic.
Thanks!!
DFI pit bull is offline   Reply With Quote
Old 07-21-2007, 02:45 PM   #7
comment
comment's Avatar
Okay, this guide just hit the XS front page. flytek!
__________________
  • SilverStone OP700
Old 07-21-2007, 11:48 PM   #8
I34z1k
I34z1k's Avatar
Send a message via MSN to I34z1k
Wooot Marc Nice stuff
__________________
920 c0
6gig Mushkin 1600 6-7-6-18 (Many thanks to TheGoatEater)
285gtx
Dfi x58 t3eh6
I34z1k is offline   Reply With Quote
Old 07-22-2007, 03:15 AM   #9
TraX
Champion
TraX's Avatar
the paint works well for all kinds of applications where solder or non-adhesive paints may have been used, including cpu pinmods & mods like the 7900 vgpu, it enables guys with no desire to solder to get into extreme cooling & benching territories:
7900gt vgpu
1333 fsb mod - by kunaak > here <
We've been using this method for years & love it
@ I34z1k, thanks, but seth put this guide up
__________________
hardware flux
TraX is offline   Reply With Quote
Old 07-22-2007, 05:00 AM   #10
I34z1k
I34z1k's Avatar
@Trax :P Whatever You confused me with your wife this morning... UNLESS :|
__________________
920 c0
285gtx
Dfi x58 t3eh6
Old 07-22-2007, 06:03 AM   #11
andyddr
andyddr's Avatar
Conductive paint reminds me of Athlon L1 bridge days. Thanks for the great guide, I for one will be using it.
__________________
"The only difference between me and a madman is that I'm not mad."
- Salvador Dali (1904-1989)
andyddr is offline   Reply With Quote
Old 07-22-2007, 11:24 AM   #12
hausner
hausner's Avatar
Send a message via MSN to hausner Send a message via Skype™ to hausner
Great job !
__________________
|::| i7 920 3849A914
|::|EVGA Classified 760
|::|G.Skill Trident 6GB DDR3-2000
|::|BFG GTX 275
|::|WD BLACK 1TBx2
|::|Ultra X3 1000W
|::|Powered by Heatkiller LT/Ek-Classified/EK 275GTX /Feser x360/MCP355x2
|::|LCD: Samsung T260
"Sharing your knowledge is always the best way to learn new things". OPB
hausner is offline   Reply With Quote
Old 07-23-2007, 11:43 AM   #13
trans am
Xtreme Mentor
trans am's Avatar
You should make a ghetto-container guide next.
__________________
lsi 9260-4I
ST1000-P psu
Old 07-23-2007, 12:08 PM   #14
comment
comment's Avatar
__________________
  • SilverStone OP700
Old 02-05-2008, 04:13 PM   #15
maxwolfie
Nice work mate, I'll give it a shot later today.
Can I just confirm that this will also work, instead of the RS stuff?
maxwolfie is offline   Reply With Quote
Old 02-05-2008, 10:39 PM   #16
maxwolfie
Card fried
The fluid somehow got under the tape and completely made a mess of everything
Oh well
Old 02-05-2008, 11:02 PM   #17
s e t h
Champion
s e t h's Avatar
yeah one has to be very very carefull that only the right point is contacted...sorry for your loss
Old 02-05-2008, 11:23 PM   #18
maxwolfie
Not your fault, I'm sure it's an still an easier method compared to soldering!
Old 02-06-2008, 08:43 AM   #19
natedog420
natedog420's Avatar
Card fried
Oh well
dont use the pen to apply it if you did witch is what it sounds like to me. take a bottle cap or something like that and put a little bit of the conductive ink in there then use a tooth pick or something similar and just take ur time and do little by little. little dabs at a time and eventually it will work and NOT fry anything. that sucks but you learn from your mistakes so remember this one.
__________________
cpu: e8400@4ghz(450x9) 1.48 idle/ 1.45 loaded
mobo: biostar tforce tp45hp
ram: 2x1gb crucial ballistix 8500 4-4-4-10 Corsair fan
gfx: asus 8800gt 700/1850/1600
psu:corsair 520hx
case: antec 900
cpu cooling: tuniq tower
temps:cpu 38c idle/60c load - gpu 31c idle/39c load
500mhz cas 3 club: http://valid.x86-secret.com/show_oc.php?id=235630
p4 511 2.8ghz@ 5004mhz WR:http://valid.x86-secret.com/show_oc.php?id=124434
p4 541 3.2ghz@ 4909mhz :http://valid.x86-secret.com/show_oc.php?id=157470
natedog420 is offline   Reply With Quote
Old 02-06-2008, 12:09 PM   #20
metro.cl
Xtreme X.I.P.
metro.cl's Avatar
Send a message via MSN to metro.cl
Great guide i really like it.
What do you use so the cables wont move? just tape? and the silver ink makes the cable "solder" to the resistor? is it strong?.
__________________
metro.cl is offline   Reply With Quote
Old 02-06-2008, 12:19 PM   #21
natedog420
natedog420's Avatar
if its taped good and close to were your connecting the wire the conductive ink will hold it. you can always put a drop of super glue right before the spot your connecting to holding the wire in place. super glue comes off pretty easy. never had any problems with getting it off the pcb.
__________________
psu:corsair 520hx
case: antec 900
Old 02-06-2008, 11:16 PM   #22
s e t h
Champion
s e t h's Avatar
the silver conductive paint from RS is thick liquid.
it doesn't run anywhere and it dries in a few minutes max.
the tape is the primary means of holding the wire...obviously a glue gun will work too.
the paint does make a bond with the contact point and the wire but it cannot be considered strong.
using the thinnest wire you can is the best as then it doesn't have much strength itself and the paint will then hold best.
Old 02-06-2008, 11:45 PM   #23
maxwolfie
I've sent off the card to RMA - Hopefully I'll get a new one back within a month or so
Then I can try again
Old 02-07-2008, 01:36 AM   #24
Jumba
Jumba's Avatar
Hey gents (flytek, Trax, I34z1k, andyddr) - thanks for posting the guide up here! Chances are I'll give this a go on my 8800GT.
__________________
Q6600 G0 L726A849 (3.8GHz 24/7)
DFI LP UT P35-T2R
2GB Mushkin
HD4870
OCZ GameXtream 700w
X-Fi
Custom Water
Jumba is offline   Reply With Quote
Old 02-16-2008, 08:58 AM   #25
Lestat
I am Xtreme
Lestat's Avatar
Send a message via AIM to Lestat Send a message via MSN to Lestat
nice mod Fly but i hate to say this but your scores suck big hairy a$$.
i mean seriously you have that 8800GTS cranked to hell and all you got was 13k in 3dmark 06 ?
maybe im looking at something wrong here but that 320mb card should be getting way higher scores.
my 8800GTX gets 15k and all its running is stock air cooler @ 615/1000 which is only a small bit over stock.
maybe i just havent paid attention to the 320mb cards... :\
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
Lestat is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
