Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: 8800GTX and MCW60, what are people using to cool memory and vregs???
    Mar 2007
    Ontario, Canada
    My MCW60 came with 8 ram sinks, but I need more to cover all spots on my 8800GTX i think.
    so what are poeple doing with theirs?
    there is another 8 pack on the swiftech website for 20 bucks, a little high i think, any alternatives?
    CPU: Lapped QX6700 @ 4000MHz, bench @ 4250MHz
    RAM: Teamgroup DDRII PC6400 @ 1066 cas5
    MOBO: eVGA 680i SLI
    VID: eVGA 8800GTX + Zotac 8800GTX SLI...GPU voltmodded....Memory voltmodded (both cards)
    BOOT Drive: Seagate 320GB 7200.10 RAID 0
    Storage Drive: Seagate 640GB 7200.11 RAID 1
    Samsung Super Write Master
    Coolermaster Real Power Pro 850W
    Custom Bench Table
    LaCie 19inch CRT
    Single Stage Phase Change - CPU
    Water - VGA's
    I am Xtreme
    Oct 2005
    I have a GTS640 and have MC14s from Swiftech, they come in packs of 8, I used little under three packs per card for the RAM/VREGS etc.
    here is one of my cards:
    Before you ask, yes that is naked G80 core as well :-P using MCW60 on it.
    The "half" sinks are MC14s that I dremmeled.
    fermiNow Dave will see FERMI where ever I go
    Quote Originally Posted by jbartlett323 View Post
    So please return to the "Darkside of the Moon" and check your "Pulse" while you wait for the "Animals" that will be "Obscured By Clouds". And watch me wave as I say "Wish You Were Here" in "A Momentary Lapse of Reason"
    Mar 2007
    Ontario, Canada
    thats awesome how did you get the IHS off???...I am going to voltmod mine and would be interested in removing the IHS if its not too difficult, as warranty is already out the window.
    And I am assuming you bents those pins on the MC14's as well, and cut some of them in half?
    Any advantage to bending the pins like that?
    So if I buy two packs will that be enough for my 8800GTX, as I already have one, or should I buy 3 packs?
    Do you just use the thermal tape on the back of the mc14's, or did you cnhane it to something else?
    MOBO: eVGA 680i SLI
    Custom Bench Table
    LaCie 19inch CRT
    Water - VGA's
    I am Xtreme
    Oct 2005
    just two more should serve your purpose, if you use half sinks like I did, as the full size were to big because of how close the components on the card are.
    I used three razor blades, slow breathing and patience, with steady pressure.
    I am NOT say to do this, but if you want to, that is up to you.
    I posted in another thread all my steps and pics to show what I was talking about. Just to a search for naked 8800 gts.
    Apr 2006
    Hong Kong
    I run my ram chips naked - just 1 swifty hs on the i/o chip.
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
    Mar 2007
    Ontario, Canada
    a dtek unisink is cheaper than buying mc14 sinks, is a dtek unisink any good? or should i stay away.
    Also there are MC21 that are made for the vregs on 8800 cards, those would be better for the 4 vregs would they not?
    Do you use the stock sticky backs for mounting them...or upgrade to other thermal adhasive?
    MOBO: eVGA 680i SLI
    Custom Bench Table
    LaCie 19inch CRT
    Water - VGA's
    Banned
    Mar 2007
    In the land of Red....
    Phelan I did a search for naked 8800 gts and can't find jack. Is it in the Stacker Slacker thread??
    Xtreme Mentor
    Nov 2004
    Elma, NY
    GTS
    i7-2600k @ 4.8Ghz 1.38v L044A892
    ASUS P8P67 LGA
    16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
    1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
    Cooler Master UCP 1100 Watt PSU
    GTX 680 1300/7000
    Lian Li PC V-2000
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by phelan1777 View Post
    may I use this for advertising purposes?
    I love what youv'e done with the NVIO cooler.
    CEO Swiftech
    Oct 2005
    Mumbai, India
    OMG.
    @ Phelan
    How did you manage to warp those Fins on the MC14's like that???
    Please gimme a guide!
    CPU : E8400
    Motherboard : Abit IP-35 Pro
    Memory : GSkill DDR2-800 2GBHZ @ 1:1 445 4-4-4-12
    Graphics Card : Palit HD4870 Dual Sonic
    Display : Dell E228WFP
    Storage & OS : 1TB | Windows 7 64bit
    Sound Card & Speakers/Headphones : X-Fi Platinum (HotRod) > Zero DAC > BeyerDynamic DT990 Pro
    Peripherals : Razer ProType Keyboard | Steelseries Ikari Optical | Razer Goliathus Speed.
    Case : Coolermaster ATCS 840
    PSU : OCZ GamerXtreme 700W
    May 2007
    New York City
    LOL
    great ingenuity!
    but have to say... it looks like someone sat on it!
    still love it tho!
    Jun 2007
    To fit my 3/4" OD tubing onto my Swiftech MCW60, I had to use 3rd party barbs (D-Tek). With the stock swiftech ones, the tubing would not clear the MC14 ramsinks right infront of the block.
    Bending the MC14s is an excellent idea. I wish I had thought of it.
    May 2007
    hey DNottis, what are those blue sinks on your card?
    For the record I am not sick, nor am I a gamer, nor am I a sick gamer. That name just sounds really cool to me but dont put me under that stereotype at all.
    nevermind... addicted to COD4 and Free Online Games baby!
    Mar 2006
    Sweden
    Quote Originally Posted by sick_g4m3r View Post
    Looks like the alu vram heatsinks from zalman.
    http://www.zalman.co.kr/eng/product/...x=139&code=013
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    Phelan's heatsinks remind me of different Haircuts; Here's my visual approximation:
    Use the power of your CPU and GPU to contribute to science! Become a member of one of the most competitive teams in the world of distributed computing, help find cures for diseases and various other charitable scientific causes. It's as simple as running a program! Go visit the World Community Grid and Folding at Home Forums for more information on these projects. CRUNCH 'N FOLD!
    Feb 2007
    Australia
    hahaha kevin. that's hilarious
    My Rig
    CPU: Intel Core 2 Duo E6600 L626A175 3GHZ 1.30V real
    RAM: Crucial Ballistix PC2-8500 stock speed and timings
    Motherboard: Asus P5E X38 333MHZ FSB x9 multi
    Video: Gigabyte 8800GTS 320mb stock speeds
    Soundcard Creative Soundblaster Audigy 2 ZS
    Hard Drives Seagate 250GB 7200.10 SATAII (boot) > Samsung HD501J 500GB SATAII (Storage)
    Case: Lian Li PC-S80
    Powersupply: Corsair HX620W 620watt
    Optical: Samsung SH-S182D DVDRW 18x
    Monitor: Asus MW221U 22" LCD
    Mouse: Logitech CF G7
    Keyboard: Logitech G15
    Speakers: Logitech Z5500
    The water cooling
    CPU waterblock: Swiftech Apogee (original with custom top and mounting plate)
    GPU waterblock: EK FC8800GTS Acrylic
    Pump: Laing D5 Vario "3" speed setting
    Radiator: Swiftech MCR220 w/ 120mm Yate Loons D12SM-12 running at 7V
    Resevoir - Swiftech MCRES Micro - Pentison G11
    Banned
    Oct 2006
    Houston, Texas
    Very good Kevin.
  18. #18
    Xtreme Legend
    Mar 2005
    Australia
    ROFL 5 stars for entertainment value on this thread
    interesting about cendric not having any heatsinks at all
    Team.AU
    Got tube?
    GIGABYTE Australia
  19. #19
    Xtreme Legend
    Mar 2005
    Australia
    OH btw
    here is the IHS removal thread
    http://www.xtremesystems.org/forums/...d.php?t=122273
    Team.AU
    Got tube?
    GIGABYTE Australia
  20. #20
    Aug 2006
    Canada
    OMG Phelan! Wow! What else can we say about it ? Thats freaking Xtreme! LOL
    • - Asus P8Z68-V PRO
    • - Intel I5 2500k @ 4.5Ghz (for now)
    • - Asus Geforce 580GTX DirectCUII Fermi
    • - 16GB Corsair Vengeance Low Profile
    • - Ultra X3 1000 Watt
    • - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
    • - Corsair Vengeance 1300 Gaming Headset
    • - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
    • - CoolerMaster 690II Advanced
    • - Dell UltraSharp 24''
    • - Noctua NH-D14
    January - SLI Rig Of The Month (2008)
  21. #21
    I am Xtreme
    Oct 2005
    Really there is no secret to bending and shaping the SINK pins.
    I used a Molex tool, its just a little wider then the pins and you can insert the pin @ varying depth to bend how you want. I used a pair of pliers to hold the bard in one hand (tiny hard bastages) and just bent here and there till I got a look I wanted or liked.
    Quote Originally Posted by kevinbo03 View Post
    Dude that was awsome
    Dinos found my IHS removal thread, with pics to help.
  22. #22
    Xtreme Legend
    Mar 2005
    Australia
    phelan never made note on the temps in that thread which is probably an indication they weren't that much better heheh
    Team.AU
    Got tube?
    GIGABYTE Australia
  23. #23
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    I was looking at all my new shiny WC stuff, and came upon the Ramsinks...
    I present a demonstration of the "Jock" Haircut, Seen here in styrofoam form:
    I think I'm done.
  24. #24
    Xtreme Mentor
    Mar 2007
    I think I'm done.
    lol... did you take off the 3M sticky tape from the enzotech sinks?
  25. #25
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    No, I'm waiting until I have my video card in my hands, So I can tell whether I will need to bend any or not.
    PS: They are Swiftech
