Winter is truly here in Brisbane Australia tonight![]()
Normal night time room ambients = 25-30C
Tonight room ambients = 14-18C
Corsair Nautilus 500 external water cooling gets a reversible modification. At first I tried to replace the stock 120x25mm 44cfm fan, but it uses very small Torx screws to hold the fan in place so couldn't replace the fan. So I removed the entire lid, grabbed one of my Thermochill HE120.3 single 120mm fan shrouds and a Spire 120x25mm 96cfm fan and sat it on the radiator itself
This is how it turned out and the Asus P5K Deluxe setup.
Resulted in low 30-40ish idle coretemps in windows for the whole bench session
Just doing some super pi runs for now. Will try wprime as well if I'm lucky to get similar cold ambient temps tomorrow
System
- Q6600 QUPT B3 ES
- Corsair Nautilus 500 3/8" ID lid removed with Spire 120x25mm 96cfm fan
- Asus P5K Deluxe 0311 bios
- 128MB Gainward FX5200 PCI
- 2x1GB Team 6400C3 3-3-3-8 dual channel kit
- 74GB WD Raptor 8MB on SATA 1 port
- Pioneer DVR-08 Burner
- Sony FDD
- 1KW PCP&C SLI psu
- WinXP Pro SP2
@3600Mhz
@3904Mhz at 1.60v bios set
@3936Mhz at 1.6375v bios set
@3952Mhz at 1.6375v bios set
@3977Mhz at 1.6375v bios set
Everest Bandwidth only
@4002.6Mhz at 1.6375v bios set
@4009Mhz at 1.65v bios set
cpuz validation
I had 4021Mhz but system rebooted before i could save cpuz validation
But bloody fast Super Pi 32M times for a Quad core kentsfield B3 step cpu considering they're slower clock for clock then Core 2 duo dual core B2 stepping cpus for single instance Super Pi
