XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 05-31-2007, 06:05 PM   #1
davexl
davexl's Avatar
Arrow I found out why some Ultra-120 Extremes are loose [PIC]
I think I have found out why so many people are having problems with their Ultra-120 Extremes.
Some of them have a missing silicone washer/spacer.
I have bought 3 of these for my new Quadcores, and they have done an unbelievable job, but I have noticed some of them gave variable results and needed remounting. So looking at them I noticed that the mounts are different - both have exactly the same 17mm clearance, but one has a 1mm silcone washer.
The funny thing is that the last one I bought is missing this washer.
Either poor design decision or bad QC, or old stock
This mount needs work, but when it is on right, this thing rocks.
__________________
Intel Core 2 Duo 6400 & 6600's
6400: 2.1GHz overclocked to 3.360 Ghz, 1.450V Vcore, Asus P5W-DH Deluxe, Rev 67MOAG BIOS 1305 -TTBT
6600: 2.4GHz overclocked to 3.600 Ghz, 1.5375V Vcore, 3.708 Ghz, 1.5750V Vcore, Asus P5W-DH Deluxe, Rev 68MOAG BIOS 1602 - Ultra-120
QuadCore Q6600: 2.4GHz oc to 3.456 Ghz, 1.5625V Vcore, Asus P5B-Deluxe Wifi, Rev 1.03G BIOS 804 - Ultra-120 Extreme New Build, still testing.
Gskill F2-6400PHU2-2GBHZ (4 x 1GB)
Antec Truepower2 550w EPS
davexl is offline   Reply With Quote
Old 05-31-2007, 06:09 PM   #2
xenoasd
xenoasd's Avatar
oh great mines doesnt have a washer.....
__________________
E6600 - 3.6Ghz @ 1.4V
Thermalright Ultra-120 Extreme + S-FLEX SFF21F 120mm Fan
Asus P5B-Deluxe WiFi-AP
Crucial Ballistix DDR2-1000 2GB
eVGA 8800GTS SuperClocked 320MB 650/1900
Creative X-Fi XtremeMusic
Corsair HX520W
Antec 900 Case
3DMark06 - 13,078
xenoasd is offline   Reply With Quote
Old 05-31-2007, 06:24 PM   #3
njkid32
Hiding from the cops and people I ripped off
The one I have has the washer and is still very loose.. I did this little mod and it really helped the temps on my kentsfield.
__________________
njkid32 is offline   Reply With Quote
Old 05-31-2007, 06:29 PM   #4
fireice2
fireice2's Avatar
no wonder this thing wiggles.
__________________
Rig Specs
Intel Core 2 Extreme QX9650 4.0ghz 1.37v - DFI Lanparty UT P35 TR2 - 4x1GB Team Xtreem DDR2-1066 - Palit 8800GT Sonic 512MB GDDR3 256-bit
160GB Seagate Barracuda 7200RPM SATA II 8MB Cache - 320GB Western Digital Caviar 7200RPM SATA II 16MB Cache - Liteon 18X DVD-Writer /w LS
640GB Western Digital SE16 7200RPM SATA II 16MB Cache - Corsair HX 620W Modular PSU - Cooler Master Stacker 832
Auzen 7.1 X-Plosion - Zalman ZM-DS4F - Sennheiser HD212 Pro - Edifier M2600
Custom Water Cooling
Dtek Fusion Extreme CPU Block - Swiftech MCR-220 - Swiftech MCP655-B - Swiftech MCRES-MICRO Reservior - 7/16" ID x 5/8" OD Tubings
Dual Thermaltake A2018s 120mm Blue LED Smart fans.
www.mni-photography.site88.net
fireice2 is offline   Reply With Quote
Old 05-31-2007, 06:43 PM   #5
LuckyNV
hmmm i can't even remember, i installed it over a month ago
__________________
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Zotac GTX260-216
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music
Samsung SyncMaster 713BM (DVI)
LuckyNV is offline   Reply With Quote
Old 05-31-2007, 07:16 PM   #6
BobHarris
The HS moves because there is nothing to brace it on any of the sides. It is a poor design. Other HS are bolted on which prevent it from rotating.
BobHarris is offline   Reply With Quote
Old 05-31-2007, 07:16 PM   #7
davexl
davexl's Avatar
Good thread, and interesting that you have the washer and still had probs.
But I tell you, without the washer... it twists like a hula hoop.
__________________
Old 05-31-2007, 07:19 PM   #8
teyber
Xtreme Mentor
teyber's Avatar
wow! thats ridiculous!
teyber is offline   Reply With Quote
Old 05-31-2007, 07:20 PM   #9
Speederlander
Xtreme Mentor
Speederlander's Avatar
Ha ha. My washer CAUSED my problems because it was bigger than the clearance hole on the base. I removed it and it totally quit sliding around. That screwhead dropped right into that hole on the top of the heatsink base and I'm good. No kidding.
Speederlander is offline   Reply With Quote
Old 05-31-2007, 07:22 PM   #10
njkid32
Well I think what the washer provides is more friction so it makes for less movement. But, if the X bracket isnt set to the right angle it wont allow for the correct amount of pressure. This is why my penny mod worked. Also, with the first attempt at this mod I used a piece of cardboard with gave more friction than the penny did with just about the same amount of pressure. I think when I change cpu's again I'll use an 1/8" rubber washer with a dab of crazy glue on it so it sticks to the X bracket for a more perm aplication.. That should work quite well.
__________________
Old 05-31-2007, 07:32 PM   #11
Speederlander
Xtreme Mentor
Weird. My washer was teflon or something. Super slippery.
Old 05-31-2007, 08:53 PM   #12
Fallengod
Damn that sucks. Perhaps this is one of the reasons so many people have inconsistent results. TR seems like they have some QC issues on those things. Ive seen many pics of ones people bought with unflat bases. Now missing washers as well? Geezz.
Fallengod is offline   Reply With Quote
Old 06-01-2007, 07:57 AM   #13
Eagleclaw
Eagleclaw's Avatar
I don't have the washer on mine...
@ njkid32 great tip I will give the 1/8" rubber washer a try
In the pics you can see even with the washer the head of the bolt still sticks out so thats not good either.
__________________
i7 920 @ 4.0GHz
Scythe MUGEN-2 with Push/Pull
Gigabyte EX58 UD5
3X2GB G-Skill DDR3
eVGA GTX 260
24" Acer HDMI LCD
Corsair TX850
Lian-Li PC-V1000
Core 2 Duo E6600 (L629F) @ 3.690GHz
Thermalright ultra 120 Extreme Yate Loons Push/Pull
ASUS P5K DELUXE/WIFI
4X2GB A-DATA PC2 6400
ATI HD 2600
22" Hanns.G HDMI LCD
Corsair HX620
CM Stacker 810
Eagleclaw is offline   Reply With Quote
Old 06-01-2007, 06:11 PM   #14
davexl
davexl's Avatar
It goes into the bevelled hole in the top of the heatsink - it is not the only point making contact.
Still needs more though..
__________________
Old 06-02-2007, 12:29 AM   #15
cozwin
for a company thats meant to be "the best" its a pretty bad school boy error tbh.
cozwin is offline   Reply With Quote
Old 06-02-2007, 12:29 AM   #16
cozwin
and when it costs so much tbh it should be perfect, for next to nothing more you could get the amanda which is pretty much perfect.
Old 06-02-2007, 12:47 AM   #17
Solarfall
Xtreme Guru
Solarfall's Avatar
Send a message via AIM to Solarfall Send a message via MSN to Solarfall
great find davexl. good thing that the missing plastic washer is pretty easy to replace with something else. and no heavy modding is required
__________________
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
Solarfall is offline   Reply With Quote
Old 06-02-2007, 05:04 AM   #18
davexl
davexl's Avatar
Yeah, it is a pain, but hardly the end of the world. And the point is still that you can get world beating temps with this cooler.
I just remounted on a new motherboard, and found a great one - 2 strips thick of gaffer tape on the mounting bracket, then one large patch to cover the whole top of the heatsink base. The shiny sides of the gaffer tape then face each other, and provide a great grip, and the first time I have seen my quadcore temps all within a degree of each other under Prime95 load.
__________________
Old 06-02-2007, 06:43 AM   #19
crossg
Good find. My temps are not even close between Core 0 and Core 2. (4 cores at 100% folding). Hopefully some of the suggestions above will help. To me this mod will be easier to do first than lapping the cpu and heatsink. if the fit isn't tight then I don't imagine lapping will help that much, but that's just my opinion.
__________________
CPU: Q9650
CASE: Antec Nine Hundred Ultimate Gamer.
Cooling: CPU: Thermalright Ultra-120 eXtreme/ Scythe S-Flex.(Lapped)
MOBO: ASUS P5Q Deluxe.
RAM: 4GB Crucial Ballistix PC 8500.
GFX: EVGA GTX 295.
SOUND: X-FI XtremeGamer. Harmon/kardon speakers.
HDD's: 1.5 TB, + 500 GB Seagate Barracuda's 7200.11
MONITOR: Samsung 22" T220
PSU: Corsair TX 750W.
OS1: WinXP Media Center Edition 2005 SP2. OS2: Vista Home premium 32 Bit.
crossg is offline   Reply With Quote
Old 06-02-2007, 06:50 AM   #20
LethalSmite
Those temps seem fairly high ^^^
or am i wrong?
Do you have a fan stuck on that?
LethalSmite is offline   Reply With Quote
Old 06-02-2007, 07:01 AM   #21
crossg
or am i wrong?
Yes sure do. Scythe S-FLEX S-FDB 120mm, 1600 Rpm (Push)
I actually backed off the 3100Mhz OC because temps were 60+ under load. This CPU seems to run a lot hotter than the C2D.
__________________
CPU: Q9650
GFX: EVGA GTX 295.
Old 06-02-2007, 07:39 AM   #22
njkid32
Yes, those temps are a bit high.. I have a kentsfield at 1.43v (ES B3) idle temps are 39c and loaded temps are 58c since I did my penny mod.
__________________
Old 06-02-2007, 07:56 AM   #23
lawrywild
Xtreme Cruncher
lawrywild's Avatar
Send a message via MSN to lawrywild
lol his temps are not at all high for 24/7 folding at stock volts on a quad core..
__________________
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
lawrywild is online now   Reply With Quote
Old 06-02-2007, 08:02 AM   #24
njkid32
lol, I didnt realize those were his loaded temps
__________________
Old 06-02-2007, 08:27 AM   #25
crossg
Great temps for that voltage. Are your CPU and heatsink lapped?
Yeah mine is loaded temps but I should have posted a task manger performance screenshot to avoid confusion.
__________________
CPU: Q9650
GFX: EVGA GTX 295.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
