05-24-2007, 08:32 PM
#1
Hiding from the cops and people I ripped off
Easy Mod For Ultra-120 eXtreme
Today I had to change cpu's and decided I was going to figure out a way to make this hs fit better  When I first mounted this hs on my Kentsfield it was soo loose (with the screws bottomed out) that I could wiggle it back and forth so much it was almost off the IHS.. Terrible design if you ask me. Anyway, since the design of the top X bracket is using the center as the point of pressure I added a piece of cardboard under it then screwed all 4 screws as tight as they would go.. This didnt warp the board it was a perfect fit with no wiggle.. I mean if I tried with force I could get it to move around but at least it was snug. Now, with changing my fan to the pull position I gained 3c but after mounting with the piece of cardboard under the top X bracket I am now under 60c loaded at 1.45v. Thats over 8c improvement.. Not bad  Sorry no pics camera was stolen
__________________
05-24-2007, 08:43 PM
#2
Xtremely High Voltage
Sounds like they need to work on the bracket to get more pressure.
Did Dave borrow your camera again?  j/k sorry it got stolen
05-24-2007, 08:45 PM
#3
I was originally going to add a few washers to the 4 screws for more pressure but thats really not where its needed.
__________________
05-24-2007, 10:16 PM
#4
XSDCMF
I bought #6 washers to use on my second 120 Xtreme. Maybe I'll try it out with both washers and cardboard ( and w/o the washers, but just cardboard ).
The design is kinda funky as far as the S775 goes. Because they made it swivel to fit in under the heatsink they lost strength there I think.
I'm not using mine for an AM2, but there AM2 bracket looks much more effective. It is all one piece and has a stronger looking, formed pressure point.
__________________
running octohamsters, some quadrohamsters, ... and, the kitchen sink!
Proud member of top-ranked XS teams! XS~WCG and XS~D2OL
I am DCManiak on the WCG team, ser on the D2OL team
05-24-2007, 10:17 PM
#5
XSDCMF
Eric, do you think something more rigid than cardboard would be more beneficial?
__________________
05-24-2007, 10:21 PM
#6
I was thinking that a Teflon washer or even just a metal washer would be much stronger.. I just used the cardboard temporarily to see if it would make a diff but I'll still need something for the long haul.
__________________
05-24-2007, 10:34 PM
#7
XSDCMF
Or a piece of hardwood, perhaps. How thick would you estimate it need to be?
__________________
05-24-2007, 10:38 PM
#8
Hmm maybe an 1/8th of an inch maybe more. I'd have to measure.. If its an 1/8th of an inch or thicker you'll still be able to adjust with the screws but getting the screws to start to thread may be a bit difficult.
__________________
05-24-2007, 10:51 PM
#9
XSDCMF
Maybe one of those case bezel punchouts from 5.25 drive spaces. Or two. Cut to size to fit in under there.
__________________
05-24-2007, 10:57 PM
#10
That might require to much work  If you flip over the top mount you'll see that there is a little screw and a plastic washer under it. I'd say all you need is one more of those washers stuck to the bottom. I know that those plastic washers with adhesive on the back are sold somewhere  But, either one or two of those should get the job done.
__________________
05-25-2007, 12:27 PM
#11
Great F'in Idea. I'm going to have to do the same, my temps suck. Since I'm using an ES QX6700 i'll lap the damn thing too while Im at it.
05-25-2007, 12:38 PM
#12
I'll try this out when I get my next mobo. I don't like how loose the Ultra Extreme fits on my P5B...
05-25-2007, 07:47 PM
#13
Guys please let me know if anyone has tried this.. I just want to know if you see an improvement or if mine was just a fluke.
__________________
05-25-2007, 07:57 PM
#14
good idea here
i noticed mine was loose also.
__________________
i7 860/True 120
GA P55 UD6/4gb Ripjaws
HD5850/Benq G2400WD
XFI Titanium/beyer dt770 pros
Klipsch PM 2.1/WD 640 Black
Corsair 750/HAF 932
HEAT
05-26-2007, 07:17 AM
#15
I just got my 2nd..RMA'ed the first, which was VERY loose. The first had the plastic washer, the new unit I put in last night DOES NOT. It fits VERY tightly...and cools 10C better. Now, Oc'ed, (3300, QX6700) I'm in low 40's under normal stress.
Doc
05-26-2007, 07:48 AM
#16
any1 got a picture? XD
__________________
E6600 - 3.6Ghz @ 1.4V
Thermalright Ultra-120 Extreme + S-FLEX SFF21F 120mm Fan
Asus P5B-Deluxe WiFi-AP
Crucial Ballistix DDR2-1000 2GB
eVGA 8800GTS SuperClocked 320MB 650/1900
Creative X-Fi XtremeMusic
Corsair HX520W
Antec 900 Case
3DMark06 - 13,078
05-26-2007, 08:51 AM
#17
Xtreme Mentor
Doc
What does it have in place of the washer?
05-26-2007, 12:01 PM
#18
Nothing...but it now fits like a glove. I'm thinking the washer..being plastic, allowed it to slide/spin. Doesn't look like they changed anything else. But if I had my original still, and it moved alot or isn't cooling like the badass it's supposed to be, I'd remove the washer, if possible, and try it that way. It's cooling pretty well right now. I'm throwing a Delta 150 CFM on it later this week. THEN we'll really see! and hear! I am also changing cases...[url=http://www.newegg.com/Product/Product.asp?Item=N82E16811103011[/URL]..I think airflow is key with this BIG tower. Need another case anyways! But with my case closed my temps go up 2-3C...
Doc
__________________
X-CLIO Windtunnel
EVGA 122-CK-780-A1 LGA 775 NVIDIA
Intel Core 9650
Thermaltake Ultra Exteme
CORSAIR Dominator 4GB(4x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
Ultra X31000
3 8800GTX eVGA triple SLI
Vista 64
05-26-2007, 12:43 PM
#19
Someone please put up some pics. Mine is too loose. There's got to be a good working solution that someone can film.
__________________
The little air system that could.
05-26-2007, 01:16 PM
#20
Here is a pic of the spring and the scissors clamp.
This was ordered when they came back in stock from newegg.com over a week ago, maybe someone can compare with one that is loose.
__________________
i7 920 @ 4.0GHz
Scythe MUGEN-2 with Push/Pull
Gigabyte EX58 UD5
3X2GB G-Skill DDR3
eVGA GTX 260
24" Acer HDMI LCD
Corsair TX850
Lian-Li PC-V1000
Core 2 Duo E6600 (L629F) @ 3.690GHz
Thermalright ultra 120 Extreme Yate Loons Push/Pull
ASUS P5K DELUXE/WIFI
4X2GB A-DATA PC2 6400
ATI HD 2600
22" Hanns.G HDMI LCD
Corsair HX620
CM Stacker 810
05-26-2007, 01:36 PM
#21
The cardboard spacer is a great idea. Kudos. If you wanna get every bit of efficiency out of your setup I would recommend lapping both your HS and CPU. I got about 2 °C when I lapped my Ultra-120 Ex, but the largest gain of ~8 °C came from lapping the IHS on my Q6600 which was moderately concave.
Here is another thread about someone lapping their Ultra-120 eX as well.
05-26-2007, 01:43 PM
#22
Great minds think alike! I too was thinking about doing this, except I was gonna use some folded loose-leaf paper lol. I never got around to doing it, too lazy, and too sick of opening up my computer case. I'm also gonna try it out soon, maybe right now. I'll keep you guys posted.
__________________
"Do not ask to find fault, ask to learn. For if the ignorant man asks to learn, then he is more knowledgeable than a knowledgeable man, who asks to find fault." - Commander of the Faithful Imam Ali A.S.
05-26-2007, 03:57 PM
#23
I'm a man of my word, I lapped her up to 1000 grit, (I lapped her correctly before anyone asks) and I placed a another washer in between HS and the Clamp/Xbracket. I used coollabs liquid pro again and here are the comparo temps
Before mod+unlapped HS Idle temps 46/42
After mod+lapped HS Idle temps 43/41
Take it for what it is... a half-assed before and after test. I didn't bother with load temps, simply because I suck. The reason my temps are so high is because its about hell degrees celsius in my house. I had to drop my OC from 3.6 to 3.4 and lower the voltage a tad.
__________________
05-26-2007, 04:48 PM
#24
The washer is on the OTHER side of the bracket, where the screw head is. I's RMA it, but if you want to play with it, try to get the screw out...won't be easy though.
__________________
X-CLIO Windtunnel
Intel Core 9650
Ultra X31000
Vista 64
05-26-2007, 06:56 PM
#25
Xtreme Mentor
You could leave it and cut the washer edges until they are even with the edges of the screw.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
