Results 1 to 21 of 21
Thread: How to mount a rad up top in a TJ07
Threaded View
    Mar 2007
    Durham, UK
    Just thought I’d show every body how to mount a Black Ice pro II up in the top case fan area without using any bolts or screws through the mess to hold it up there.
    Things are pretty tight up there and the only way to get the rad & fans up there is to reshape the grill to allow the rad to get as close as possible to the case top.
    The first thing I did was flatten the mess out, then cut it to the right size. The best way to flatten it out, is to turn the case upside down and bend it outwards, when you have done this then you need to finish it off on a bench to get it nice and flat.
    You then need to cut the mess just the other side of the screw holes, because you still need to be able to attach it latter.
    I used a Dremel with a fine cutting blade to lightly cut the mess.
    Next I had to make two brackets to fit either side of the rad.
    One is fitted to the runner that guides the motherboard tray in to place.
    The other bracket is fitted to the three holes that are on the opposite side of the case that would be used if you inverted the motherboard tray guide runner.
    I used a U shaped bracket to fix onto the runner guide; you have to drill a large two holes in the back of the guide so you can get to the bolts that tighten the bracket to the rad.
    The other bracket is L shaped and this one is fixed to the three holes on the opposite side of the case.
    You can see I’ve used a spacer on this side. It’s there to leave some room for the screws that hold the mess in place.
    Once I’d made the brackets, I fixed the U shaped bracket first and then marked the two holes for the rad.
    I then drilled and taped two 4mm threads and fixed the rad in place.
    I then fixed the other bracket in the same way.
    I would defiantly recommend using a pillar drill when drilling the holes in the rad, because you need to be able to control how deep you go through the side of the rad wall.
    Even fixing a rad this way still leaves problems attaching the fans because they can still come in to contact with to mofset coolers.
    I will be solving that problem in the morning, and will up date this thread as soon as I’ve finished.
    I hope this will be of some help to anyone who is thinking of mounting a rad in this area.
    If you would like to know any other details please don’t hesitate to send me a pm.
    Ps.
    It's 1.30 in the morning over here, so if I've made any daft grammar mistakes sorry.
ID:	59753   Click image for larger version.
ID:	59754   Click image for larger version.
ID:	59755   Click image for larger version.
