Results 1 to 25 of 37
Thread: Finally the QX6700 WR is Norwegian.... and more..
Threaded View
    Feb 2005
    Oslo, Norway
    I recieved three QX's the a couple of days ago, and started testing.. The first ES I tested was good on Cascade, and managed 10.15 sec superpi@5005Mhz on cascade@about -92 degrees evap temp.
    The other one however... really su**ed on cascade.. so I strapped on my LN2 container and started benching..
    Equipment:
    CPU QX 6700 ES week 32
    Mobo: Asus P5K deluxe
    Memory: OCZ FLEX pc9200 (smokin' )
    PSU: OCZ ProXtream 1Kw
    Videocard: My good ole PCI 8MB from 1994
    Cooling: Stoolcan Rev 1 all solid copper .... and a good load of LN2..
    Here is SuperPi 1M with all four cores enabled
    Which i think is a VR in superPi 1m... and soon to be beaten..
    Then there was Wprime32M... Just missed OPB, but got K|ngp|n
    Wprime1024M.. Just missed Hipro..
    Pifast all cores enabled
    Then I left one core enabled...
    VR QX6700
    http://valid.x86-secret.com/show_oc?id=200450
    Then i started benching beyond the old record of 5307 Mhz
    Pifast VR on QX
    Superpi1M VR on QX (as far as I know..)
    So, all in all, a nice way to spend an evening in the garage..
    Not to forget... Thanks a lot Vic... you rock!
    Cool things in progress...
