Page 1 of 3 123 LastLast
Results 1 to 25 of 66
Thread: 7900 GS / GT Volt Mod
    Oct 2006
    Atlanta GA - USA
    This mod applies to nvidia reference PCBs (XFX usually does not apply)
    XFX New PCB VMod Here
    Materials...
    Conductive ink
    lead pencil (6B Work the best , Any will do)
    Some good music
    Chips and dip
    Heres the backside of the card with the mod spots marked off
    Take your conductive ink and draw a trace connecting these three components
    Close up of Memory Resistor Shading mod
    AND, For those of you with stock cooling or halfway decent air cooling
    Here are smaller vmods , same traces though
    on stock I wouldnt recommend going above 1.3v unless you have extremely low ambient temps
    Heres The Cooling im using Gets me 32c idle and 34c load with 25c Amb
    Results so far
    Now Give yourself a Pat on the Back and have a nice Sandwich
    Thanks for reading , Please leave feedback Also if you tried it please share your results
    Heatware -> http://heatware.com/eval.php?id=51939
    Ebay -> http://myworld.ebay.com/onewhoisplug
    Feel Free to hop in my ventrio server and chat with us
    Vent6.gameservers.com:4498
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    Very cool!
    I've got a GS right now with stock cooling, And I may be getting a new Air HS \ WC setup... What voltages would you suggest for Air? 1.4?
    Also, what are the specific diagrams for Mem volt mods?
    Dec 2002
    ithaca, ny
    what vmem are you using to get 1000?
    E8400 8x500=4000 | ABIT IP35-E
    2x2GB Tracer PC2-6400 1:1 500MHz 5-5-5-15 2.0V
    Galaxy 8800GT 800/2000/1100 1.3V | 80GB X25-M G2 + 1.5TB 7200.11 | XFiXG
    Fuzion | MCW60 | DDC2+Petra | Coolrad22T+BIP1
    Merom 13x133=1733 1MB L2 0.950V
    Feb 2007
    Denmark
    Uff 1Ghz mem, how are you cooling the samlle chip?
    Getting a FC79 too, so ill be doing the big mod too.
    Oct 2006
    Atlanta GA - USA
    Its under the EK Waterblock , Im using about 2.3 (if im not mistaken) on the memory
    I have to cool about 4 different chips on the top of the card now , one of them never used to get hot ????
    Only Extreme Need Apply
    Nov 2006
    Singapore
    haha its tt grp of ics at the vmem mod there right? cool them down to get less artifacts in 3dmark
    Buildin
    Feb 2007
    Denmark
    Quote Originally Posted by Cupcake View Post
    Im a bit unsure now, are all the chips that have to be cooled under the FC79?
    Just got mine today YAY!
    Feb 2007
    Denmark
    How much cooling does the mem chip need?
    (I assume its the one with "6549CBZ P548C4D" on it)
    I have some Zalman VGA sinks, would one of them be enough?
    http://www.levicom.de/xilence/en/xpram.htm
    Oct 2006
    Atlanta GA - USA
    It would most likely be enough , I have some pretty cheap copper sinks on mine and they get pretty damn hot but not hot enough that im worried
    I run 2.3v BTW
    I would say a zalman sink would be enough as long as you have some airflow around it
    Feb 2007
    Denmark
    Ok, nice.
    But just to get it allll straight.
    All the chips that have to be cooled, get cooled by the FC79, exept the mem chip.
    And am i looking at the right mem chip? the one with "6549CBZ P548C4D" on it?
    Oct 2006
    Atlanta GA - USA
    that depends.... whats the FC79 ? lol
    but actually I use 3 ramsinks on mine
    I will get pics of where they are in a minute
    Oct 2006
    Atlanta GA - USA
    Here you go mate, I put little comments about what im using
    Id ask someone with more experience which chips actually need to be cooled
    Feb 2007
    Denmark
    I thougt you use a EK FC79 waterblok?
    Many thanks, a very usefull picture Ill put sinks on all of them
    Hm, maby the Xilence sinks are not even enough
    Oct 2006
    Atlanta GA - USA
    I just didnt know it was called the FC79
    Jun 2006
    Even the Rev2 boards still have that heat problem by those chips but not as hot as rev 1
    Oct 2006
    Atlanta GA - USA
    im guessing mines a rev 2 cause I only got it about a month ago
    Dec 2006
    Can you clock your core higher?
    mine clocks 630 on default voltages
    EDIT: ops stupid me, 500 is the default
    so how high can you clock your core with the volt mod?
  18. #18
    Oct 2006
    Atlanta GA - USA
    oh , 720 stable
    I hit 850 once but it froze up in seconds
    wish I had a screenie of that
  19. #19
    Feb 2007
    Denmark
    I am looking all over Denmark for a decent pencil, and i think i found something.
    But befor i start, i just wont to know, it the chips that heat op at the buttom of the image, do they only heat up when you do the memVmod?
  20. #20
    Oct 2006
    Atlanta GA - USA
    I think the ones at the bottom of the picture get hot from the mem mod and the top ones get hot from the core mod
    Im not sure so feel them after doing your mod
  21. #21
    Jun 2007
    Athens
    hey i cant find here a condactive pen if i do the mod and just wired the will it work ? i don't have any problem to solder a wire on the
    CPU : Q9550 / Board : Asus P5E64 WS Evolution / Ram : 2x1 OCZ D9GTR DDR3 / Vga : HD 4870 / PSU : PPC&C 750W / SSD Ocz Vertex 30Gb / All under Water & Tec's
    Overclockers Wannabe Athens Dept...
  22. #22
    Dec 2002
    ithaca, ny
    sure
  23. #23
    Jun 2007
    Athens
    thanks man i have already soldered it tomorow i will try the 1,4 mod i just hit 620/900 memmory on 2.1 core on 1.3 not bad it gave me 23.174 on 3Dmark 03
    and the temps i hink they are good 45 idle 58 on load with one zalman 900cu led (i think this is the name)
    thanks again
  24. #24
    Jun 2007
    Athens
    ok i need some help now i set 1.4 the Vcore and 2.4 the Vdimm how much up can i go now safe i have 660Mhz on the core and 1000Mhz on he ram i have hynix chips can i raise more voltage on the rams chips is it save to go above 2.4 Volts ?
  25. #25
    Dec 2002
    ithaca, ny
    2.4v is WAY TOO MUCH. i wouldn't go higher than 2.2v or so.
    the 7900 isn't memory bandwidth starved anyway, so raising memory that high would net you hardly any improvement.
    Also, if you raise vram to 2.2v or beyond, you should put a heatsink by the ic next to the mod, because it will get very hot and cause instability.
    as for core, what temps are you getting under load? what are you using to cool it? if you have good cooling, you can give 1.45v or 1.5v a go.
