Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: R650, 65 nanometre comes in Q3
    Mar 2007
    A new hope at 800MHz+
    ATI is working hard to bring a new high end card and this one is scheduled for Q3. This is basically the R600 done right and is nothing much more than R600 shrinked to 65 nanometre.
    ATI obviously mastered 65 nanometre and is ready for mainstream and entry level DX 10 at 65 nanometre production. The next step is to release the real high end card clocked at more than 800 MHz core and 1024 MB GDDR4 memory.
    The next high end card is R650 and it should be out until September in the worst case scenario. Let's hope that things will go right this time. Some of our sources indicated way higher clocks than 800 MHz, closer to 1000 MHz.
    Source
    Now how can i go out and buy the R600 after reading this. Looks like my current card will have to do for some months more.
    Apr 2005
    Gold Coast, Australia
    finally a card that can do 1000 mhz stock cooling.
    Intel Core 2 Extreme QX9650
    Gigabyte ep45-ud3lr
    Sapphire HD6970
    Team Xtreem 2*1gb 1300
    1TB Western Digital
    Xtreme Guru adamsleath's Avatar
    Nov 2006
    Brisbane, Australia
    65nm gpu ...wasn't expecting that this soon.
    i7 3610QM 1.2-3.2GHz
    Xtreme Member EternityZX9's Avatar
    Sep 2006
    Nursing Student -or- Beta Testing Escape From Tarkov
    oooo nice...but wasn't this supposed to be out January of this year? And second what happens when the G90 comes out?
    Sep 2006
    But this is from FUD. FUD hates ATi with a passion.
    Xtreme Mentor
    Sep 2006
    I really feel sorry for AMD/ATI. They just need to get REAL PRODUCT out in a timely manner. It feels like Intel and nVidia are eating their lunch in the meantime.
    [SIGPIC][/SIGPIC]
    I am Xtreme
    Jul 2005
    If this is true the only real advantage of 65nm is manufacturing cost, not necessarily better cooling or OC. Unless they revamp the arch some how to accommodate better cooling or OC'ing. If it's true they are doing this (taking with a grain of salt) making this nothing more then a die shrink, there is no tangible advantage for the consumer.
    [SIGPIC][/SIGPIC]
    Xtreme Mentor
    Aug 2006
    HD0
    Quote Originally Posted by Eastcoasthandle View Post
    ehh
    lower chip complexity/size = lower likelyhood of errors in manufacturing.
    everytime there is a dieshrink, somebody wins and usually the consumer is one of the winners(think trickledown effect)
    Xtreme Monster
    May 2006
    United Kingdom
    Kind funny XT2900XT just good in synthetic benchmarks like 3D06. I hope they will make tests on Vista rather than WinXP, as for 65nm maybe 2900XTX will flow like water. Well I think the only card to get benefit from 65nm process will be 2900XTX.
    May 2004
    ILLinois
    q3 of what year?
    Sep 2006
    Surat, India.
    Quote Originally Posted by mion View Post
    q3 of what year?
    I think thats not yet decided
    Sound: Asus Essense ST | Wharfedale Diamond 9.1 | Norge 2060 Stereo amp | Wharfedale SW150 sub (coming soon)
    Camera Gear: Canon 6D | Canon 500D | Canon 17-40L | Canon 24-105L | Canon 50mm f1.4 | Canon 85mm f1.8 | Rokinon 14mm f2.8 | Sigma 10-20EX HSM | Benro A3580F + Vanguard SBH250 | Bag full of filters and stuff
    Apr 2005
    Orange County, CA
    Quote Originally Posted by ANP !!! View Post
    Q3 2010.
    Current Setup:
    -9850 GX2's in Quad SLI config
    -Asus P5N32-SLI MB
    -2x512mb of PC2-5300 DDR2
    -Intel Celeron D OC'd to 3.2Ghz
    -Windows Me with XP theme
    -WD Caviar 20GB Hard Drive
    -Zip drive
    -Jazz drive
    -3.5" floppy drive
    -5.25" floppy drive
    YouTube Addict
    Aug 2005
    Klaatu barada nikto
    Smaller process size has several benefits, the most popular and common is more clock speed. Then of course you have trade offs. For example do you use the extra transistor budget to get more performance out or do you get better yields
    Fast computers breed slow, lazy programmers
    The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
    http://www.lighterra.com/papers/modernmicroprocessors/
    Modern Ram, makes an old overclocker miss BH-5 and the fun it was
    Jan 2005
    Grand Forks, ND (Yah sure, you betcha)
    Quote Originally Posted by nn_step View Post
    Or more importantly:
    LOWER POWER CONSUMPTION @ similar clock speeds.
    Of course obviously the smaller die size usually translates to a higher clockspeed at similar voltage because there is less heat, but I think AMD will welcome the former.
    It looks like the current 80nm R600 will overclock very well on the stock cooler and stock volts, and is underclocked to stay in the 2x6-pin power envelope of <225W. It seems to me overclocking is disabled with 2x6-pin because of this, but yet with >225w it soars way above the set ~750mhz default clock with the stock cooler, and even higher given proper cooling; but that's a given considering it has the leg-room to use up to 300; although granted we don't know how much is actually used with a high overclock and proper cooling. The point is, what's holding it back is the power usage AND heat.
    The shrink to 65nm screams to me that power-suckage will drop dramatically, perhaps to around 175W or so, that this will no longer be an issue compared to current parts. Heat will obviously as well be less of a factor. It may clock better overall, but I imagine we'll see a default clock jump to below what the current 80nm chips are capable of just to keep, as you mentioned, yields high, but more importantly power consumption low(er). One can assume the default vGPU will be lower, with a nice trade-off between clocks and power usage. The situation may have turned out different if the R600 wasn't inherently a power hog, but it is, so this to me seems the only way AMD can go.
    Hopefully the 225W wall (I'm thinking R650 will def be 2x6-pin or 1x8-pin) doesn't hurt their ability to clock the 65nm part higher at stock, or from overclockers with xtreme cooling from doing their thing past the default like the current (is 9 days still the future?) cards seem to be with the up to 300w allowance.
    That is all.
    Peace and love.
    Live Long And Overclock
    Sep 2004
    Most likely not before Q1 08...they won't need the R650 till then.
    Perkam
    May 2005
    Quote Originally Posted by perkam View Post
    Perkam
    If the R650 is all they have for 1st/2nd quarter of 08(and they sit on it until then), then they're in deeper trouble than they were the past 7'ish months on the high end, however, AMD stated we'll see the refresh within a few months of the R600 in the press conference...
    I've said it before and I'll say it again, there's still more big fish in the sea this year from both camps. Both are merely baiting the hook with the first run of the year, being the 2900XT and 8800Ultra... The amount of fish seen depends on each camps moves.
    The battle is likely to run all the way until Q1/Q2 08.
    Quote Originally Posted by Leon2ky
    "dammit kyle what's with the 30 second sex lately?" "Sorry sweetie, I overclocked my nuts and they haven't been stable since"
    Quote Originally Posted by trinibwoy View Post
    I don't think his backside has internet access.
    Quote Originally Posted by n00b 0f l337 View Post
    Hey I just met you
    And this is crazy
    But I'm on bath salts
    And your face looks tasty
    Jan 2005
    H108 brings R700, and supposedly either 55nm or 45nm, depending on which way the wind is blowing.
    R650 is a Q4 product at worst, I think late Q3 sounds right from what we've heard lately, although I expected RV670 before it, also in late-ish Q3.
    True enough, R650 better have the clocks to compete with surely a 512-bit and/or highclocked and/or G80-type beast with more scalars.
    That is all.
    Peace and love.
  18. #18
    Jan 2005
    Stafford, UK
    Exactly like the X1800/X1900 "strategy".
    Poor AMD, getting spit-roasted from both sides by Intel and nV atm
    VENOM: DFI LP LT X38-T2R ~ Core 2 Duo E8600 @ 4.00GHz ~ 4GB OCZ Blade LV DDR2-1150 ~ Radeon R9 380 4GB ~ Crucial C300 64GB ~ Seasonic X-750 ~ Dell U2913WM 29" ~ Win 7 Ultimate x64
    LAIKA: Alienware Alpha R2 ~ Core i5-6400T @ 2.20GHz / 2.80GHz ~ 16GB Ballistix Sport LT DDR4-2133 ~ GeForce GTX 960 4GB ~ Crucial MX300 275GB ~ LG OLED55B7A 55" TV ~ Win 10 Home x64
    BLADE: Razer Blade 14" (2013) ~ Core i7-4702HQ @ 2.20GHz / 3.20GHz ~ 8GB DDR3-1600 ~ GeForce GTX 765M 2GB ~ Samsung 840 EVO mSATA 500GB ~ Win 7 Ultimate x64
    E-MAIL
  19. #19
    May 2005
    Quote Originally Posted by turtle View Post
    Sounds similar to the word going around here as well. The rest of the year should be rather interesting.
    Hey I just met you
    And this is crazy
  20. #20
    Apr 2006
    So what it will be facing..
    Not much info about its competition?
    Its been half year since 8800..
  21. #21
    Dec 2005
    Netherlands
    Interesting if true... But if it's slated for Q3 that means they officially state the R600 sucks donkeyballs and those who actually buy a R600 card will see their investment go down the drain in 6 months...
    I'm sorry but I'm not going to buy a $500 GPU and see it devaluate by half in 6 months..
    Lian Li V2000+ Modded
    Intel Core I7 920 @ 3.8Ghz 1.325v Thermaltright Ultra 120 Extreme RT1366
    Asus Rampage Extreme 2
    OCZ 3x2GB DDR3 1600 Platinum
    EVGA GTX460 768MB 850/1700/2100Mhz SLi
    EVGA 8800GT SSC 730/1800/2000Mhz
    Corsair HX850W
  22. #22
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    Quote Originally Posted by NightCrawler™ View Post
    if nVidia had competition, the price of their cards would have gone down to around 50% of release value. Stop complaining. To have a GPU last 6 months at high price isnt bad for the high-end
    you sigged that?
    why?
    ______
  23. #23
    Dec 2002
    80nm 900mhz seems avialble with stockcooling, 1ghz then its watercooling time.
    For extreme clockers 80nm using cold and ln2 stuff the heat will not be an issue at all
    4670k 4.6ghz 1.22v watercooled CPU/GPU - Asus Z87-A - 290 1155mhz/1250mhz - Kingston Hyper Blu 8gb -crucial 128gb ssd - EyeFunity 5040x1050 120hz - CM atcs840 - Corsair 750w -sennheiser hd600 headphones - Asus essence stx - G400 and steelseries 6v2 -windows 8 Pro 64bit Best OS used - - 9500p 3dmark11 (one of the 26% that isnt confused on xtreme forums)
  24. #24
    Banned
    May 2006
    Skopje, Macedonia
    a FUDzilla is not a source of news. It is a source of speculations and most of them are BS.
  25. #25
    Dec 2005
    Sweden
    Quote Originally Posted by gOJDO View Post
    Well said my friend
    AMD Opteron 165 (0615 DPMW) 1800 @ 2831 MHz with 1,4 v | Asus A8N-SLi Deluxe | eVGA 8800 GT "Vanilla" @ 700/1728/1000 | 2x1gb G.skill 2GBZX | FSP Epsilon 700W | 760 GB Harddrive-space
