Been working close with Tony, getting this thing up and high, have cracked ddr1000 1T cas 4, just need some work in finding stability, that is in sync mode btw @ 500fsb.
In any case, the best performance point according to Tony, and confirmed for me via my own experience is to run fsb at 1900-1920 in Sync mode, giving around ddr 900 to 917 1T. I'll leave the explanation of that stuff to the man who found the performance point via a lot of toil (Tony), since I don't believe in ripping off another man's work or IP and calling it my own.
Board boots out of bios @ 500fsb and above, I have not yet tried to find the maximum, as i have been concentrating on the performance point...
So Kudos, to Tony, Bingo13 and Rgone, Jimmy and Oskar who have worked tirelessly to get this board rocking hard. Those of you who will have the board for benching will soon find out that there are definite advantages to Oskar not picking up a reference design board
Back to the fun part this board is crazy fast, bear in mind I'm not even a great bencher or tweaker, I leave that stuff to the big boys.
Latency in everest is around a sweet 40.7 ns on the 1900fsb run, obviously 3d mk 03 won't make full use of the latency, but well maybe fun times and an indicator for the super pi fans especially 32m...
Components of interest that were used
X6800
NB water cooled with DD Chipset Cooler
2 GB OCZ Reaper 9200
SS cooling on cpu...
2x 8800 GTX @ 625/1000 NO LOD used at all, or any other tweaks, staright XP install, no tricks, hacks cheats or funky undisclosed cooling other than the SS unit.
first up a 1760fsb run in sync mode,
and another @ 1900fsb
