XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Reviews
Reply
Old 05-04-2007, 10:42 AM   #1
hixie
Where's me Beer?
hixie's Avatar
3R System Iceage 120 Heatsink Review
Got a new heatsink to do some testing, from 3R Systems. The first impression i got from the heatsink was that at best it would be a few degrees highers than my Tuniq Tower. However, i carried on with the testing anyways.
http://www.3rsys.com/
To start with, i did a extremely unfair comparison against my Turniq Tower.
Now to get maximum heat i used one of my hotest CPUs, with 2 Seventeen or Bust clients running and 2 Prime95, here's the spec.
System Specs:
Intel Pentium D 940 3.2Ghz @ 4.3Ghz (270mhzX16)
Asus P5WD2 Premium
Kingston DDR-667 1GB X2
My Turniq Tower had a delta fan inside and i got 61C at full load.
Then i tested the Iceage 120, and i got 58C full load and 42C Idle . Ok, something is wrong so i went back and dusted off my Turniq Tower, and after a few tries at remounting the heatsink my best temps were 58C full load and 43C Idle.
Ok, so this new heatsink is good, very good, but what will happen if i placed my delta fan on the iceage?
Full load temps were 56C and idle temps were 42C. So this new heatsink beat my Turniq Tower, why?
Well this heatsink uses a new design, the heatpipes are not on top of a copper plate like most heatsinks, this heatsink has heatpipes that are directly in contact with the CPU if you look at their website you'll see what i mean.
This heatsink is the best heatsink i have tested yet, the original fan is designed to be silent but still provides temps that match my turniq tower with a 3700rpm delta fan inside that says something doesn't it?
If you're the type that wants every last drop of performance, get yourself a delta fan, you won't be disappointed.
This heatsink is now in my main rig, and i love it.
Here is a direct link to the heatsink, have a look. If you're in the market for a new heatsink give the Iceage 120 a try.
http://www.3rsys.com/english/product...ler&idx_num=83
Here's a recap:
Turniq Tower with Delta fan 43C Idle and 58C Full load.
Iceage 120 with original fan 42C Idle and 58C Full load.
Iceage 120 with Delta fan 42C idle and 56C Full load.
hixie is offline   Reply With Quote
Old 05-08-2007, 10:10 AM   #2
ineedaname
ineedaname's Avatar
Looks petty good so far.
The mounting system looks a bit weak tho.
__________________
CPU: Q6600 @ 3.6ghz G0 Week 37B
Mobo: Asus P5k Deluxe
Cooler: TRUE 120 (150cfm Delta)
2xHR-05
2xHR-09
Mem: G.Skill 4x1Gb 6400HZ
Vid: HIS 4850
HDD: 80Gb 16mb Cache Raptor
500Gb 7200.11 Seagate
PSU: Enermax Noisetaker 600w
Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
3dmark06: 16k
ineedaname is offline   Reply With Quote
Old 05-08-2007, 11:16 AM   #3
Nosfer@tu
OCTeamDenmark Staff
Nosfer@tu's Avatar
Send a message via MSN to Nosfer@tu
Very nice temps.
is the price fair to ?
Mounting looks like it is for OEM usage
__________________
OCTeamDenmark.com Staff
Cooled and sponsored by Coolerkit.dk
Gigabyte EP45 Extreme | QX9770
2x1 Gb G.skill DDR3 PC3-16000
2xFoxconn 3870, Vcore,Vmem,OCP,Cap mods.
22" Samsung 225BW | Antec 1000 Watt
Mach 2 GT (moddet by t!m) | MX510 - Func F10s
Nosfer@tu is offline   Reply With Quote
Old 05-17-2007, 07:37 PM   #4
Pinmod
Pinmod's Avatar
Send a message via MSN to Pinmod
temps look fine to me
__________________
um..... i'll get to it later
Pinmod is offline   Reply With Quote
Old 05-17-2007, 07:42 PM   #5
hixie
Where's me Beer?
hixie's Avatar
The mounting bracket does look a bit weak, but hasn't caused any problems so far.
The price is about HKD100 less than say a turniq tower.
Old 05-23-2007, 11:19 PM   #6
ineedaname
ineedaname's Avatar
for the size i have 2 say this cooler is looking very good.
I wonder how it stacks up against the ultima 90 ad the ultra 120 extreme tho.
__________________
2xHR-05
2xHR-09
Vid: HIS 4850
3dmark06: 16k
Old 05-24-2007, 07:05 AM   #7
Lestat
I am Xtreme
Lestat's Avatar
Send a message via AIM to Lestat Send a message via MSN to Lestat
i have the extreme and i am not impressed with it one bit.
but they fit too lose on the cpu so who knows.
anyways,, nice temps.
post some pic's
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
Lestat is offline   Reply With Quote
Old 05-29-2007, 08:56 AM   #8
hixie
Where's me Beer?
hixie's Avatar
Pics added! Placed the iceage 120 with my new board.
Sorry for poor pic quality, my camera is no where in sight, so i used my phone.
Old 05-29-2007, 01:19 PM   #9
xoqolatl
Thrusters on full!
xoqolatl's Avatar
Send a message via MSN to xoqolatl
That "Direct Touch Heatpipe" seems a good idea to me. This may be the next step in Heatsink evolution; but I can imagine base flatness problems that gives; and would it benefit from lapping at all (there are areas between the pipes that don't touch the IHS/core).
__________________
Originally Posted by miahallen View Post
FurMark is a waste of time.....it's not ranked on HWBot
W3520 on Rampage II Gene | hardmounted TRUE + 2x 120mm push-pull | 3x 2gig of HCF0
Zombie GTX280 | look mom, i has no IHS | Thermalright HR-03 GT
Lian-Li PC-A70B | Brushed aluminium tank
MOA 2009 Poland #2
Test bench: Clarkdale, several AMD Confidentials
xoqolatl is offline   Reply With Quote
Old 07-10-2007, 03:45 PM   #10
DoomSayer
DoomSayer's Avatar
100HKD thats like 9.3 euro you sure thats correct ?
__________________
.:: Core i7 920D0 4Ghz :: Gigabyte GA-EX58-UD5 :: OCZ Platinum 3x2GB DDRIII :: Thermalright Ultra-120 eXtreme+Zalman ZM-F3 BL Push/Pull ::.
.:: Powercolor HD5870 :: LG L226WTQ-SF 22" :: Corsair HX850W :: WD Velociraptor 300GB / Areca Arc-1210 4TB [RAID5] ::.
DoomSayer is offline   Reply With Quote
Old 07-11-2007, 12:06 AM   #11
hixie
Where's me Beer?
hixie's Avatar
Read carefully, 100 dollars and 100 dollars cheaper makes a huge difference.
Old 07-11-2007, 02:01 AM   #12
DoomSayer
DoomSayer's Avatar
ha indeed my mistake.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
